SOURCE: I want to replace belt from motor to transfer shaft
Hi. I presume your talking about the 2 clutch belts. Difficult to explain so try this site it has manuals to show you how. http://dysonmanuals.inc.io/
SOURCE: Transfer Belt vs Transfer Roller
Its a bogus message. Simply open and close the front cover of the machine. It resets it and the message disappears.
SOURCE: I'm replacing drum, developer, drum cleaning blede
After replacing the drum, do these SPs: ?? SP 3001-2: ID sensor initial setting ?? SP 2810-1: Grayscale Setting
SOURCE: Lexmark C522n Laser Printer stating "83 replace transfer belt"
how do you reset the transfer belt of a Lexmark C522 colourlaserjet.
Thanks
Alex
SOURCE: HI HAVE SHARP MX 3501N COPIER , TORE TRANSFER BELT
You really dont want to do this. It is tricky. The new belt can be pinched and ruined extremely easily, and you are required to apply it with a special lubricant. In case you really want to, The supply item is MX-4501Y1. That is just the belt. There is another kit for the transfer rollers inside. If you want to buy. $150 email me.
Remember, kit wont work without lubricant
[email protected]
