Question about Hardware & Accessories
#052-7218-8 I plugged this in to an outlet, plugged in my Christmas lights and nothing happened. The dial is turned to ON.
Posted by Carol Boutilier on
5 Related Answers
Jaime Hernandez
  • 2337 Answers
SOURCE: AKAI 32" LCD HDTV WILL NOT TURN ON
The only solution at this point would be to get the power supply repair since new boards are not longer being manufactured. In about 95% of the time if the LCD doesn't power up or turns OFF by itself or need to be unplug for some time to make work again; those are the symptoms of a dying or defective power supply.
I service these power supplies, for more info write to [email protected]
Posted on Nov 27, 2008
premtech
William Rayburn
  • 934 Answers
SOURCE: AKAI LCT3201AD
Find and replace the following caps, Ec18, 19, 20 / 1000uf/16v,
Ec9, 10 / 1000uf/35v, Ec14, 25 / 470uf/35v should resolve the problem. You can get the caps at almost any electronics supply.
This is a common problem in this unit.
Good Luck!
Happy Thanksgiving!
Bill
William Rayburn, CET
Premium Technologies
PO Box 442
Long Beach, WA. 98631
360-642-4993
[email protected]
Anonymous
SOURCE: Tomtom 510 will not activate. tried it with
After posting my problem, I did some more browsing and came across this on the amazon webiste:
31 of 32 people found the following review helpful: stars-4-0._v45457020_.gif Cure for not able turn on the Go 510, 16 Jun 2007 By Sirius (Essex) - See all my reviewsI like the tomtom so far the only niggle was it would not turn on once.
No troubleshooting on instructions, found cure on internet,reset button
underside. With the tomtom turned over and the card slot on top right hand
side there is a small rubber foot at the half moon shaped enterance, up at about the 10 o'clock position from the foot,but before the green circuit
board there is a small half round cut out with a hole under you need to press in this hole for a few seconds with a paper clip to reset. I wonder how many people have sent their tomtoms back that would not turn on.
Tried it & worked a treat!!! Newcastle here we come again ...
Posted on May 05, 2009
Anonymous
SOURCE: Won't turn on. When I plug it into the outlet and
Free with the help of a friend with knowledge. Thank you.
Posted on Nov 03, 2009
Anonymous
  • 22 Answers
SOURCE: got new 4piece set for christmas put battery on
Check for warranty, they are warranted at least a year, to get a new one .
Posted on Jan 23, 2011
Ge timer 15131 buzzing
Copy following link to see array of GE analog timers, including 15131: Model numbers and designs change as products are updated to meet new marketing objectives.
http://waterheatertimer.org/GE-timers-and-manuals.html#15119
Information about 15131 analog timer:
Plug timer into different outlet to eliminate outlet-wiring as possible suspect.
If timer makes noise only when connected to one outlet, then test outlet for loose wires, and feel is outlet is warm, or circuit breaker is warm to touch to indicate electrical problem.
GE15131 is ordinary analog timer with small clock motor inside that rotates timer dial. Motor gears are plastic, and generally very quiet.
So the timer has small motor that could cause humming noise.
There is also a switch that could be partially burned, from use-and-age or overload, and that could be flickering, but you would expect that to happen only when light was ON, and light would probably flicker, or not turn on.
Buy another timer if noise is annoying. These timers have 1 year limited warranty, and can stop functioning within a year or two, just like a $10 Christmas toy might not function very long.
Analog timers sometimes work for many years.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
Nov 20, 2012 | Hardware & Accessories
I have a EI600WC timer installed (by electrician) in my garage to control outdoor christmas lights (outlets in eaves). The switch will not turn the lights on!
Yes 100' maximum is problem. To work around problem, you can use timer to turn on a contactor, and then the contactor is not limited to 100' distance.
Copy following link to see wiring diagram, and you can wire it yourself:
http://waterheatertimer.org/images/Dawn-dusk-120Volt-pump2-300.jpg
http://waterheatertimer.org/H230A.html
Assuming timer was installed correctly ... did timer work when first installed, and then die?
This timer cannot be exposed to freezing temperatures because the battery will die in cold temperatures.
Ei600 timer is 5-year warranty version of ST01C timer, and both have same wiring and same battery.
Copy following link to see programming, wiring, and battery replacement
http://waterheatertimer.org/ST01C-program.html
If cold battery is problem, suggest using GE 15312 timer from Home Depot that has same 100' maximum and same load rating characteristics and same programming capability as Ei600 and ST01C, but GE timer is powered by the circuit and not a battery.
http://waterheatertimer.org/How-to-wire-GE-15312-timer.html
You can install timer yourself.
Nov 29, 2011 | Intermatic EJ500C - Indoor Digital Wall...
WHERE CAN I FIND DIRECTIONS TO PROGRAM TIMER #0148373
Open following link to correctly identify product:
http://cgi.ebay.it/UTILITECH-2-OUTLET-TIMER-0148373-15-AMP-LOT-OF-4-/290468257053
Utilitec 0148373 timer is plug-in type timer.
Set on-off times by moving pins.
Pins are located on dial and stick up. They can be moved back and forth like stick-shift on car.
See example of pins at following link:
http://waterheatertimer.org/Woods-timers-and-manuals.html#Pins-tabs
Instructions:
Turn ON lamp.
Light bulb is good.
Plug lamp into timer.
Plug timer into outlet.
Move some pins outward.
Then manually rotate dial clockwise to watch how lights turn on-off.
That will tell you if lights turn on or off when pins are set outward.
To set current time, rotate dial clockwise until current time lines up with arrowhead located on inner dial.
Dial turns as time passes.
Lever on top of timer is moved to 'Timer'
Dec 19, 2010 | Hardware & Accessories
How do I use SKU: 15112 timer
GE 15112 timer manual:
http://www.jascoproducts.com/support/manual-downloads/applications/DocumentLibraryManager/upload/Outdoor-15112-Manual-eng-spn.pdf
Same as Tork 652A manual
http://waterheatertimer.org/pdf/651A-652A-manual.pdf
Made for permanent outdoor usage. Outdoor usage only.
Timer has 2 grounded outlets located bottom of timer, maximum wattage for both 1000Watts
50-mini-bulb string of Christmas lights is 25 Watts
Plug timer into 125 Volt GFCI protected outlet.
Do not plug timer into extension cord.
Indicator light shows when timer has power.
Timer turns ON automatically at dusk.
Plug lights, small pump, fountain, motor into grounded outlet located bottom of timer.
Rotate dial to choose timer function.
Rotate dial to select timer function
- ON at dusk & OFF 2, 4, 6, 8 hours later - Rotated dial to number shown on dial
- ON at dusk, OFF at dawn - Rotate dial to dusk-dial
- ON continuously - Rotate dial to ON
-OFF - Rotate dial to OFF
Dec 03, 2010 | Jasco Ge 8HR Mechanical Blk Timer 2 Outlet...
Can't get the timer to turn on
Woods timers:
You posted under Woods 59383.
Plug timer into wall after setting timer.
Maximum load 500 watts, used for indoor or outdoor
Set current time, rotate dial until current time lines up with black triangle.
Around outer edge of dial are segments.
Pull up all segments for times you want timer OFF
Leave segments down for times you want timer ON
Locate switch on timer.
Push switch so the V shape is down.
Plug into wall outlet, plug Christmas lights into timer
Drink ale and eat turkey legs.
Add a comment if this is not your timer, or if you need more help.
Nov 23, 2010 | Woods INDUSTRIES 59383 OUTDOOR MECHANICAL...
I need a manual for UTILITECH #0148373.. and i need it now! PLease help me..i need to know how to use this product. HELP PLZ!
Instructions:
Turn ON lamp.
Light bulb is good.
Dec 30, 2009 | Kitchen Appliances - Others
Artificial Christmas tree comes in 3 parts A B C
You can probably find instructions online, depending on the maker. What kind/brand of tree is it? Do each of the power cords plug into the next one down, or is there a large multi-tap outlet somewhere (either halfway up the tree or at the base)?
Dec 19, 2009 | Solar Christmas Tree 6 Outlet Foot Switch...
AKAI LCT3201AD
Good Luck!
Happy Thanksgiving!
Bill
PO Box 442
360-642-4993
[email protected]
Nov 27, 2008 | Akai LCT2715 27 in. LCD Television
Nov 27, 2008 | Akai PDP4294 42 in. EDTV-Ready Plasma...
Hardware & Accessories Logo
121 people viewed this question
Top Hardware & Accessories Experts
Tom Chichester
ray gallant
Are you a Hardware and Accessory Expert? Answer questions, earn points and help others
