Lands Phones Logo
M
Mujib Posted on Nov 21, 2019
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
When I join the electric line and display show off program but how can I solve it
Not Me
Level 3:
  • Master 3,158 Answers
  • Posted on Nov 21, 2019
Not Me
Master
Level 3:
Answers
3158
Questions
0
Helped
163409
Points
31816
Can you please reword your question with more detail about the problem, and include the make and model of your device.
I NEED TO SET UP 4 PHONES TO HAVE A LINE 5 AND A LINE 6. THE BUTTONS FOR THE EXTRA LINES ARE PROGRAM WITH SOMETHING ELSE. HOW DO I PROGRAM THE PHONES TO HAVE LINE 5 AND 6.
Programming is done on M7310, M7324 and T7316 sets.
To set up line appearence you need to enter programming by pressing the feature key followed by **266344.When prompted to enter the password enter 266344.
The screen should say TERMINALS&SETS. The 4 top line/feature keys are now used for programming.
At the terminals&sets prompt,
press the show key (top right arrow).
The display should now ask for an extension number. Enter extension number you wish to program ringing on.
Press the show key (top right arrow)
The display should sat LINE ACCESS
Press the show key (top right arrow) .
The display should say LINE ASSIGNMENT.
The display ask for a line number. press list
The display should say line 001: appear & ring
press the next key (bottom right arrow) till it says 025(or 031):unaaign press the chng key till the screen says appear&ring
Press the next key(bottom right arrow)
The display should say line 026(or 032): unassign
repeat the procedure the same as line 5 for line 6
press the release key when finished
1helpful
I have the T7316E system and one of teh extensions does not ring which feature code turns teh ringing back on?
To set up ringing you need to enter programming by pressing the feature key followed by **266344. When prompted to enter the password enter 266344.
The display should say line 001: appear only
press the Chng key till it says appear & ring
press next key (lower right arrow)
The display should say line 002: appear only
repeat the procedure the same as line 001 for the remaining ringing lines
7helpful
Phone will not ring
To set up ringing you need to enter programming by pressing the feature key followed by **266344.When prompted to enter the password enter 266344.
5helpful
How do i make all lines ring at certain desks for a norstar m7324 phone?
Programming2_bing.gif is done on M7310, M7324 and T7316 sets.
3helpful
Norstar Meridian M7100 incoming calls - no ringing tone
At the terminals&sets prompt, press the show key (top right arrow). The display should now ask for an extension number. Enter extension number you wish to program ringing on. Press the show key (top right arrow)
press the Chng key till it says appear only press next key (lower right arrow)
The display should say line 002: appear & ring
4helpful
How do you get a t7316e phone to ring
1helpful
Power went off in our office over the weekend. Now my phone doesn't ring on all the incoming lines. Help!?
THE PHONE FLASHES BUT DOES NOT RING? We had a power cut the other day and since the phones have not rung, just flash? Anyone know why? We have 3 lines coming into the building. The lines have all been...
The 4 top line/feature keys are now used for programming2.gif.
press next key (lower right arrow)The display should say line 002: appear only
repeat procedure for remailing active lines
If your system uses the older programming template,
then Enter programming by pressing the feature key followed by **266344.When prompted to enter the password enter 266344.
the display says A. Configuration
the display will say1. trunk/line data
Press the next key (bottom right arrow) .
the display will say 2.line access
the display will say line assignment
Press the next key 2 times(bottom right arrow) .
The display should say ringing.
Press the show key (top right arrow).
the lines should be listed as appear only change to appear and ring
press Rls when finished
1helpful
How do you program so that when the phone rings you are able to pick up the call without hitting a button. Also when you make an outgoing call and you pick up the phone you get an active line instead of...
Sets that are programmed to ring should automatically have ringing line preference.
press the heading key (top left arrow) til the screen says terminals&sets again
Prime line assignment is also programmed at the terminals&sets prompt.
press the show key (top right arrow). The display should now ask for an extension number. Enter extension number you want to change the prime line on.
The display should say Line Access
The display should say Line Assignment
The display should say Line Pool Access.
Press the next key (top right arrow)
The display should say Prime Line
Press the Chng soft key till you get to the desired line or pool to pick up on
Press the release key when finished
34helpful
How do I turn off the ringer on a Nortel T7316E?
If you want to temporarily turn them off use do not disturb (feature 85, feature #85 to turn DND off)
Turning off the ringing permanently will require you to program the set. Programming2.gif is done on M7310, M7324 and T7316 sets.
The display should say line 001: appear & ring press CHNG til it says appear only.
Repeat same procedure as line 001 til all available lines are done
Top Lands Phones Experts
k24674
Are you a Lands Phone Expert? Answer questions, earn points and help others
