Question about Kenmore Kitchen Ranges
Kenmore stove control panel won't come on?
Stove works by no control panel or oven
Posted by Carol Busich on
Aron
  • Kenmore Master
  • 1,571 Answers
The thermal fuse can't be reset if the fuse has or is blown, it must have to be replaced. One of the wires that supply power to the oven element or igniter might be burnt out. These wires will generally burn out near the heat source. To determine if a wire has burned out, inspect the wires leading to the element or igniter.
Posted on Aug 08, 2020
5 Related Answers
Anonymous
SOURCE: Frigidaire stove
I believe the oven it has a power surge protector within the appliance. Try to unplug it and plug it back in. It should solve the problem.
Posted on Dec 20, 2008
Anonymous
SOURCE: stove oven does not workit,s a kenmore stainless steel
I have experienced a f30 code on my oven...I was told to change the oven sensor probe which i did....The code still comes up!!! SEARS IS NOT ANY HELP
Posted on Jan 03, 2009
localwonder
Michael Masters
  • 6784 Answers
SOURCE: Kenmore gas Range -- Control Panel not working
Hi. your assessment is correct. when you have normal operations with the stove top and the control panel is blank or non operational, this will confirm either a wiring harness issue or a dead control circuit board. The wiring harness can sometimes become lose or the connectors can become corroded but, in this issue, i am sure its the ECB(electroninc control board). In this case, you will have to replace the board it self.
Please rate and god bless:)
Posted on Apr 16, 2009
Anonymous
SOURCE: water spilled down the stove top causing the oven
ater spilled (4-5 cups) on the stove top running down into the stove control panel face (where you view oven temp, timer, etc). No water ever dripped into the oven or oven window. The stove top still works but the oven, warming drawer, clock are all non responsive after three days. No buttons on the control panel work at all. What repair is needed?
Posted on Apr 04, 2010
Anonymous
SOURCE: Frigidaire electric stove, burners work oven does not. No clock
one of the stoves does not work. What could be the problem and how to fix it?
Thanks
Posted on Sep 13, 2010
Kenmore Oven and stove not igniting
If both top and oven are not igniting, then most likely you need an ignitor board. I should be located behind the left side of the console as you are looking from the front of the stove. I will look it up to be sure. There should be a tech sheet on the back panel of the stove to help in checking the boards.
Thanks/Mike
Dec 02, 2007 | Ovens
Where are fuses in Kenmore stove C970
Stoves generally do not have internal fuses they rely on the house circuit breaker to protect the circuit. Some stoves have what is called a thermal fuse. These can trip when the oven or broiler has overheated. Some are located on the back panel and some are located on the top panel under the top of the stove. Since this is a smooth top model there may be one on the back panel. More than likely there is a problem with the oven control circuit possibly in the electronic control. The relays can go bad on the control and the oven will not work.
Oct 11, 2014 | Kenmore Electric Smooth Top Stove
My Kenmore stove, model #79095680301, was baking some food when it made a loud popping sound. Since then, the control panel doesn't work (and we can't turn on the oven without the control panel). The stove...
Joe,
Sounds like you need to contact a qualified Kenmore technician. It could have burned out an element, wires to the element, etc., but you'll need to be fairly skilled to check these components.
Try contacting Kenmore directly here:
Kenmore Customer Care Customer Service Information
Feb 08, 2018 | Kenmore Electric Smooth Top Stove
How to remove oven thermostat on whirlpool stove
You don\'t need to remove the top. The thermostat is the long skinny tube in the oven that comes up to the railcock behind the oven control knob, remove the front panel to get the railcock/thermostat out which has the tube attached to it.
Mar 20, 2014 | Whirlpool Stove / Oven / Range Cooktop -...
Water spilled down the stove top causing the oven
Jan 06, 2010 | KitchenAid KDRS807SSS Dual Fuel (Electric...
Kenmore elite double oven control panel
I just purchased the kenmore elite double oven with the touch pad control centre. Has anyone had any problems with the control panel on these ovens?
Dec 13, 2008 | Kitchen Ranges
Stove works, oven does not
in repairing Kenmores there is a relay well 2 small black an square in the head unit of stove one for stove the other is for oven anyway they go out alot a setback to the kenmore digital controls take upper panel off where controls are look at the green board an you can see them some green some red or blue to tell if one is bad be careful an turn the stove on u will hear the relay click then try oven if you do not hear a click its bad do not i repeat do not touch it while its on
Aug 31, 2008 | Kenmore 40494 / 40495 / 40499 Electric...
Problem with Kenmore Electric stove
I have kenmore stove mod.790-95660103 you turn on any top burner . T he small one inside the big burner comes on Roy
Nov 24, 2007 | Kenmore 40494 / 40495 / 40499 Electric...
Kitchen Ranges Logo
144 people viewed this question
Top Kenmore Kitchen Ranges Experts
Marvin
Marvin
Michael Thomas
Michael Thomas
Are you a Kenmore Kitchen Range Expert? Answer questions, earn points and help others
