SOURCE: How to connect unpowered subwoofer to receiver with RCA sub out?
In order for this to work, you will need an external amplifier. Your receiver is set up to use a "powered" sub. With only speaker connections on the sub, it is a "passive" sub requiring a separate amp.
Dan
SOURCE: trouble with speakers (Samsung 2.1) to 52" sony bravia lcd
that is the simplest way. please rate, thanks and have a good day
Testimonial: "very fast, thanks for the help!"
SOURCE: Hi. I got a Bose Acoustimass
Do you have any plan to use the Bose Acoustimass 20 sub/amp in it original form?
Please double check the pins count.
Popular Bose unit has 8,9 or 13 pins.
A Bose third party vendor does sell a direct cable from the Bose Acoustimass 20 to two RCA and 1/8" stereo jack.
You can open the link HERE
Full site HERE
I'm sure you can find other cable vendor at a lower price.
I do not recommend you to open the Bose Acoustimass 20 and get the two set of wires out of the box.
It may cause damage to the casing.
On the DIN plug.
With notch / dimple facing the ground.
From let to right
1 = RED negative
2 = White negative
3 = RED positive
4 = White positive
5 center = un-use.
Please use an ohm meter to verify the resistance between1 to 4 and 2 to 4 before you start hooking up to the amp.
Please keep my posted on the project via email.
SOURCE: Acoustimass Subwoofer has a low "hummm" sound when turned on.
By chance did you get to the bottom of this issue have the same problem. ????
