FILL WATER TANK ERRORon my TREVI DIGITAL PLUS Ex. I have opened the unit and connected a 2 prong plug with the wires twisted together to the #4 Spot on the Computer board. STILL DISPLAYS FILL ERROR.
6ya staff
SOURCE:
Anonymous
  • 13 Answers
SOURCE: generator plugs doesn't match cord
Hey steve. do you really need 240 volts for 120 v. circuits. the reason you have to have an adaptor plug is because on your 220 volt plug in , 2 of tthose prongs are hot and 1 is ground. for safety you need to get a plug adapter ( a regular 120 volt plug end ) run a ground from adapter to ground on 220 adapter. same with nuetral. you also need to ground your generator. there is usaully a ground lug on the bottom of the gen. Another way. if you dont really need 220 v. is to use both 120v. recepticals on gen. Run 2 chords to tranf. switch. and hard wire it in to switch. another way i did mine . when i lost power in this hurricane. i ran two # 10 chords from my 2 120v. recept on my gen to my breaker panel. when you do this you have to pull the service meter, if you dont when power comes back on it would backfeed through your gen.then i turn all my 220v. breakers i was able to run lights ,ciling fans, freezer, ice box,washing machine and gas dryer , tv's computors etc. . but to do this, you probably need someone that knows what they are doin.
Posted on Sep 19, 2008
Anonymous
  • 57 Answers
SOURCE: I bought a roper with a 3 prong but i need a 4
The laws in most states are changing to where the NEC Code requires the use of this 4 prong plug. It is quite common to see this 4 prong plug installed in new apartment buildings and rental properties because of this law requirement.
So what you have is a red, black, white and green wire on the dryer side of this wire plug.
The red and the black wires are your hots (110 volts) and shall be connected on each outside screw of the drier electrical terminal and the white wire (neutral) shall be connected to the center screw.
So now you are left with an extra green wire with no place to hook it huh?
I suggest just loosing one of the drier electrical terminal mounting screws and hooking it there. The ideal here is to ground the outside body of this machine to prevent possibility of electrical shock if water is present (like a leak somewhere nearby).
In actuality this really serves no viable purpose because the white wire does exacly the same thing, just in a different manor,,, but hey,,, our law makers are not certified electricians either. They just like new ways of stimulating sales and profits.
Note: if you are in a rental property and this 4 prong wall receptical is installed, I would not suggest you remove it or change it in any manor, as this will open yourself up to possibile legal liabilities if an incident were to occur,, like fire.
Posted on Oct 11, 2009
Joe Hogan
  • 10865 Answers
SOURCE: I'm replacing a non-hydronic electric baseboard
Hello. The red and the black are the hot wires. Therefore, connect one of your conductors to the red and the other conductor to the black. Use wirenuts. The bare ground wire should be solidly attached to the new unit's green wire using a wire nut.
Regards, Joe
PS: please rate my answer. Thank you.
Posted on Jan 06, 2010
Testimonial: "Excellent Reponse"
Anonymous
SOURCE: GE digital timer. Instructions say to: 1)
Find the Hot wire:
Your switch has 2 wires. One of these wires is Hot, and one goes to load. Disconnect wires from switch. Turn on power. Do not stand on wet surface. Test each wire to bare copper wire. When tester lights up, that is Hot wire. The other wire goes to load.
Connect wires:
Hot wire goes to Black timer wire
Wire to load goes to Red timer wire
White wire connects to white wires that are twisted together
Bare copper wire connects to Green wire from timer
How to connect white wire to white wires that are twisted together.
a) Strip white timer wire so you have 1-1/2 " of bare wire. Stranded wire will wrap around other wires easily.
b) Remove wire nut. DO NOT UNTWIST wires.
c) Hold all whites together so bare copper lines up. Wrap stranded copper around the twisted wire.
d) Replace wire nut, or use larger wire nut. Twist real tight. Do not use tape. You can solder the connection.
e) When done, pull on white time wire to make sure it is held tight. Push whites back into box.
Posted on Sep 26, 2010
Joe Hogan
  • 10865 Answers
SOURCE: My Powermate 6250 has the 4-prong 220v outlet, but
. Hello jflash...There are several ways to solve this problem. Perhaps the easiest is to go to an appliance store and purchase a power cord with a 4 prong 220v plug. if you go to a large RV sales site they may have an adapter for this purpose. Otherwise back to rewiring that waterpump:
3-Prong or 4-Prong ? The Difference:
3-prong color code:
BLACK (HOT ? 110-120VAC) ? May also be referred to as L1
RED (HOT ? 110-120VAC) ? May also be referred to as L2
WHITE (NEUTRAL ? 0VAC) ? Usually grounded to the equipment frame via a jumper wire or metal strap.
4-prong color code:
WHITE (NEUTRAL ? 0VAC) ? DO NOT ground to equipment frame.
GREEN (GROUND) ? Attach to equipment frame.
Which One to Use: According to the National Electrical Code (NEC), Article 250, installations after the year 2000, require the use of a 4-prong plug which incorporates a separate ground and neutral wire. If you currently have a home that uses the 3-prong receptacle and cord, you can continue to use it. You will have to upgrade to a 4-prong configuration, however, if you plan on relocating your current receptacle, or if the internal wires of the receptacle become damaged in any way and require repair.
Converting from 3-prong to 4-prong: Make sure you UNPLUG the appliance prior to any repairs. CAUTION: Voltages dangerous to life are still present even with the appliance turned off and still plugged in. Notably in the area of the terminal block where the power cords are installed. You will need to remove the old cord by following these steps:
  1. With the appliance UNPLUGGED, remove the access panel on the back of the unit where the power cord enters.
  2. With the cover removed, you will see a terminal block where the power cord is attached. The terminal wires will be colored with the WHITE wire in the middle, and the BLACK and RED wires on either end. NOTE: There should be a green jumper wire or metal bonding strap attached to the NEUTRAL (white) terminal wire.
  3. Remove the terminal lugs holding the old power cord wires in place. CAUTION: Use care not to drop any nuts or screws inside the appliance.
  4. Remove the bonding strap or ground wire from the Neutral terminal lug. NOTE: If disconnecting a ground wire, make sure you re-attach it to the appliance frame.
  5. Loosen the screws on the strain relief connector that holds the power cord in place and remove old power cord. NOTE: If your appliance does not have a strain relief that clamps down and hold the power cord in place, it is highly recommended that you install one. This prevents chaffing of the power cord against the appliance casing, and prevents the terminal wires from being pulled and broken loose. This could pose a potential shock hazard or cause damage to the appliance.
  6. Install new power cord by threading it through the strain relief connector and tighten down the screws.
  7. Connect the new power cord to the corresponding colors at the terminal block (Black goes to Black, Red goes to Red, White goes to White). The difference is going to be a Green (ground) wire that will connect to the appliance frame. There?s usually a green grounding screw for this. NOTE: If you disconnected a green grounding strap in Step 4., you can connect these two wires at the same point.
  8. Re-install access cover. Turn off the service breaker to the appliance PRIOR to plugging it back in. With the breaker in the off position, plug the appliance in, and THEN turn the breaker on. In the event, something was wired incorrectly, it is far better to have your hands away from the receptacle and controlled from a distance. Safety first.
These steps will work for nearly all appliances that require a 220-240VAC power cord conversion. The power cords are usually rated at 250VAC, 30 amps, and are carried by any hardware store or appliance parts retailer.
ADDITIONAL NOTES:
  1. If you desire to convert an appliance from a 4-prong to a 3-prong, make sure you reconnect the bonding strap and/or ground wire to the Neutral (white) wire at the terminal block.
  2. On some newer appliances, it is REQUIRED that you use a 4-prong plug in order for the timer or clock circuits to function properly due to the way they are configured. Refer to your owner?s manual for the correct recommendation. Even if you currently have a 3-prong receptacle, you still may be required to upgrade to a 4-prong if you encounter this situation.
  3. In many circumstances, new appliances are NOT sold with the power cord due to the various power configurations in homes. Always refer to the contents description on the shipping container the appliance comes with to see what additional items or tools may be required for installation.
I hope this information is found to be helpful. Joe
Thanks for choosing Fixya!
Posted on Jan 12, 2011
I have hoover Optima wmh139 with lights flashing from left to right it's 1 2 5 how do you read fault
here are what the numbers mean. 5 is probably throwing the others but you'll need a service tech to know for sure.
have you unplugged/cut off power to it for 10 min to see if it may possibly reset? Worth a try anyway.
Error 1 Door safety lock error
  • Check door is closed and latched correctly
  • Check wiring
  • Check door lock
  • Check drum braking device if fitted
Error 2 Not filled in preset time allowed - washing machine does not fill
  • Check mains water pressure
  • Check inlet hoses for kinks
  • Check inlet filter
  • Check water inlet valve
  • Pressure switch fault
  • Wiring fault
Error 3 Not drained in time allowed - washing machine fails to drain water
  • Check that filter is not blocked or obstructed
  • Check drain hose is clear of any blockage or obstruction
  • Check wiring to drain pump
  • Check drain pump is not defective
  • Check level sensor or switch
  • Check wiring to level sensor
Error 4 Multiple instances of anti-flood contacts in pressure switch being made
  • Check for overfoaming evidence - can trip pressure switch
  • Check pressure switch is not defective
  • Water inlet valve locked open
Error 5 NTC fault - temperature sensor detected as either open circuit or shorted
  • Check wiring to temperature sensor
  • Check thermistor
Error 6 EEPROM failure - defective electronic controller
  • Check wiring
  • Check electronic control PCB
Error 7 Motor fault detected
  • Check motor connector block
  • Check wiring
  • Check motor carbon brushes
  • Check tacho connections
  • Check motor
Error 8 Motor tacho fault - washing machine motor tacho detected as open circuit or shorted
  • Check wiring
  • Check motor
Error 9 Short circuit motor triac on electronic module
  • Check wiring
  • Check electronic controller
Error 12 Communication error between electronic control boards and wiring
  • Check wiring and harness between control boards
  • Check electronic control modules
Error 13 Communication error between boards and wiring
Error 14 Water heating error detected
  • Check wiring to wash heater and thermostats
  • Check wash heater for continuity
  • Check NTC (temperature sensor) probe
Error 15 Defective control module - Not programmed Cuore control
  • Reprogram electronic controller
  • Replace electronic controller
Error 16 Water heating element detected as short circuit
  • Check for defective electrical insulation
  • Check water heating element
  • Check water heater wiring
Error 17 Wrong signal from motor tachometric generator
  • Check wiring
  • Check motor
Error 18 Defective control module - also can be wrong electrical input frequency
  • Check wiring to electronic controller or both if two used
  • Check electrical input frequency
  • Check mains electrical supply
Feb 26, 2018 | Hoover Washing Machines
The 220 plug has 4 leads and my 220 compressur has 3 wires how do i make the conection
The four wire 220 twist lock receptacle Two hot wires, one neutral, and a safety ground. Depending on your generators setup the neutral and ground are bonded as one; unless, it setup for a floating neutral.
You would normally connect the two hots and neutral. and leave the ground open on the four prong twist lock plug. Just make sure the compressor is earth grounded on its end.
Feb 12, 2015 | Coleman Powermate Powermate 5000W...
I have a Maytag dryer with a 3-prong plug. My new
The following link explains how to convert a 3-prong cord to a 4-prong:
http://www.fixya.com/support/r793520-3_prong_4_prong_power_cord_conversion
The main difference is how the Neutral (WHITE) and Ground (GREEN or BARE) wires are installed. In a 4-wire configuration, the neutral and ground are INDEPENDENT of each other and are not connected together.
Read through the link and let me know if you have questions. I hope this helps you.
Sep 02, 2009 | Dryers
Samsung Home theater goes into Protection mode
no and yes . there is a short in the circuit board where the fan is. i had the same problem and i fixed it by takeing a power adapter out of a old alarm clock.(part where it plugs in then a little box with two wires.)i cut the outlet plug(big thick wires) off about 6 in down from the little box.then striped the wires and hooked them to the outlet plug on the surround system.(just twisted them where it connects to the large power adapter)(i used some electrical nuts to fasten them down)then i screwed it somewhere on the side and then striped the skinny wires and cut the fan wires at the base and attached them to the skinny wires.(twist them together a and put electrical tape around it)problem with this is that the fan won't go off unless you put a switch on it.if you got any questions feel free to email me at [email protected]
Jul 25, 2009 | Samsung HT-TQ85 Five DVD 5.1 Channel Home...
I have a 4 prong pigtail
Here is what I believe you have.
The 3 prong plug on your dryer is configured with 2 lines of power and 1 ground. The 4 prong receptical is 2 lines of power, 1 neutral, and 1 ground.
You will have to turn off the breaker to see how the receptical is wired by pulling it out and looking at it. You can then buy a 4 prong plug to match it and only wire up the 3 prongs you need for your dryer and leave the 4th prong empty.
Good Luck and hope this helps
Apr 18, 2009 | Speed Queen AES28AWF Electric Dryer
Connection
the green wire will attach to the dryer cabinet. The white wire will attach to the middle and the other two(red& black) will attach to the outside of the terminal block.
Good Luck!!
Feb 23, 2009 | Dryers
Generator plugs doesn't match cord
Sep 18, 2008 | Coleman Powermate Premium Plus 6250W...
MAYTAG DRYER ELECTRICAL CONNECTION
how do you change a 3 prong plug to a 4 prong plug when the colors dont match on the wires to the dryer?colors on the wires are red white black and green. colors on the terminal of the dryer are a black and yellow tied together a white in the middle and 2 blues tied together. this is a maytag atlantis dryer. thankyou chad....
Jul 30, 2008 | Maytag Atlantis MDE7400AY Electric Dryer
Washing Machines Logo
55 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
Marvin
Marvin
