TV Samsung. Model Code : UN55J6200AFXZC. Version : US02. S/N : 04KF3CAGB01546L. I would like to known if you think is the power supply my problem or anything. I found a power supply on a website at $49. Maybe it's worth trying to replace it?
SOURCE: TV does not turn on; red light blinking.
your problem is a more technical problem you will need a tech to look at your set if you are not a tech you wont be able to do it your self. contact a tech to repair your set the problem is in the power supply or related circuit.good luck.
SOURCE: blinking red lights
Take out all the cables (HDMI,POWER,RCA,etc...) and then plug just the power back in and see if the TV turns on, and make sure when you take the power cable out, take it out from the back of the TV, when you plug it back in it should click.
If the TV powers up then try plugging in your HDMI cables and see if that works.
SOURCE: LG 26lx1d tv will not turn on. Power supply is
Have an LG26Lx1D for about 3 years, dropped off by my son.(Figures).Power light just blinking, but went back to red.Removed back panel, and metal cover. Just above antenna/cable input, its a small fan,mine was full of dirt. Blow off dirt, and make sure its turning freely.
Install back the covers, an voila....its a miracle...its working again.
Good luck
SOURCE: insignia tv light blinking red and blue
you have a faulty parts inside..try to disconnect one by one the supply of all board until you get stable lights..
