Do you have the Chamberlain 248735S garage door opener? Chamberlain doesn't have a 2487355 garage door opener; there are the 248735 and 248735S openers.
There is no way to get to your battery. Apple makes their phones really closed. To replace a battery you must have special tools and special skills. and to replace the battery, you first have to buy one. You won't find these batteries in a phone store.
If you insist in doing it yourself, feel free to visit ifixit.com, to see how they open an iPhone for repair and battery replacement.
Battery Replacement Instructions 1. Turn over the scale and open the battery door. (Push ribbed switch and pull up) 2. Replace old batteries with two new 3V Lithium batteries (CR2032). 3. Close battery door. 4. Properly dispose of old batteries.
There is nothing holding the batteries in place once the battery door is opened. If the batteries are difficult to remove, use a small screwdriver to gently pry up on the battery or simply after opening battery door invert the scale and shake.
Remove the hidden key by slipping a small screwdriver or knife under the metal endcap and lift. The key will come out. To replace the battery, pry the two halves of the main plastic housing apart, exposing the CR 2032 battery.
Sounds like you uwant to change your CMOS battery. You should bring this to a professional so as to not damage your computer. If you don't know what you are doing to will cause more damage than a worn out CMOS battery
Found this link that may help you out. Seems like they are made to be used then tossed out. What a waste. Anyway the battery replacement issue is a common problem...
http://k0lee.com/2008/04/replacing-remington-and-norelco-shaver-batteries/
Open the shaver:
1) Use a small flat screw driver pry off the bottom (where the cord plugs in)
2) Remove the silver sides
3) Using a small torq driver remove the 4 scews
4) Open shaver
5) Remove circuit board with batteries
6) Remove and replace circuit board with batteries (or solder in the new batteries)
