SOURCE: Ice Dispenser - in door
Yes that repair is quite common and not too difficult you need a Maytag Fountain door Kit dont have the part# hear but can be researched available at all appliance part retailers........comes with the solonoid, new flapper door and outher redesigned pieces also an instrunction sheet A solved rating is great motivation to continue giving priceless advise........
SOURCE: ice dispenser
Replace the "fountain ice /door kit" ,it will come with every thing you need. Please rate this !
SOURCE: Ice Dispenser "Flapper" is loose--How does it reattach?
the plastic arms that move the flapper door open and closed are broken. I had this happen to me some months back. You will need to buy a repair kit from your local dealer. Explain what is broken and they can look up their part/kit number. You can't buy just the plastic door. Mine cost about $30 but was worth the price of getting my ice maker dispenser operating again. Very minor mechanics required to open this portion of the mechanism. Mostly some removal of screws and a spring or two. Good luck.
SOURCE: frost buildup inside freezer door at ice dispenser
you are still not getting a seal on that flap. It sounds as if it may be warped. THe reason the frost and ice is building up is due to the flap not sealing there isn't any other reson for your problem. Good luck on your repairs
Dave
SOURCE: door flap and latch to ice maker and water
the parts you need can be found a www.apdepot.com part # 32 is door but latch / is ?? but in the diag you will be able to see what you need . hope this helps mm. . tip after reassemble try using food grade silcone on moving parts and shute this prevents freeze up .. mm
