SOURCE: Low volume
> Open Control Panel
> Sound Properties
> Speaker Properties
> Enhancements
Loudness Equalization : on
Equalizer: Choose one (Jazz seems to be loudest setting but sounds of hallway effect so I use powerful for clarity.)
This has more than doubled the level of volume on my acer 5570.
- verc
SOURCE: ipod volume
not at all ,On your ipod there is a volume CONTROLL LIMITER so look for that feature on the ipod and u would see that it is low and it possible that u can raise the volume.
SOURCE: volume is low on my turntable
You have to amplify the output from your turntable output to the input of your amplifier. To do this you can buy what is known as a pre-amp. Radio shack probably still sells them.
Be sure to ground your turntable to your amplifier and not the pre-amp. This should stop any hum or at least diminish it. Bear in mind that your records will not sound as loud as your CD's. Hope this helps.
SOURCE: Volume is too low, even then it is turn up to the max.
Have you looked at the menu on your cable or satellite box to see if there is a seperate volume control for the box?
Usually it is found under
Settings>>Audio>>STB Volume
SOURCE: Suddenly my speaker volume is low and scratchy
Congrats, you yourself is a good troubleshooter. Just pinpointed your problem. What you just diagnoist can be easilly checked just by taking other good known speaker. If that works your speaker is short check for audio output wires. If not your card needs replacement. If need further clarifications just comment.
