GPS Logo
g
geoff Gray Posted on Nov 19, 2019
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Navman smart RM5296T-LMB will not connect to satellite to show current location. Locked in factory tutorial
Terry
Level 3:
  • Navman Master 11,377 Answers
  • Posted on Nov 20, 2019
Terry
Navman Master
Level 3:
Answers
11377
Questions
Helped
4626060
Points
152765
Sky+hd box isn't getting a satellite signal
have you checked the cables to the lmb ( dish ).... or take the dish cables out of the back of the sky box. wet your finger and put finger on to the centre and out part of the cable connector that some times works. faling that the sky box may need a factory rest or is damaged or the lmb has gone.
3answers
Screen is showing computer, usb connection, navman which are joined together by a serious of dots with the computer screen to usb connection showing green lights
The F20 Desktop Software and Service pack on the CD's from navman do not work, as you have seen. The solution is to go to the navman website and download this Service Pack
Be sure your f20 is connected to the USB cable and turned on displaying the USB Connection screen. Leave it on during the entire process.
Once downloaded, run this self extracting file and let it install automatically. After it is installed and ran.....you will see the same error again of failure to connect.
At this point you must reinstall the driver manually. Right click on your "My Computer icon, Select Devices, then properties on the navman. You should see a yellow "?" next to a statement "Unknown Device" in the USB devices. Click on the "Reinstall Driver" and select a specific location or the Have Disk button. The USB driver is now located in C:\program files\Navman\f20servicepack\USB directory.
You should get a button that now says Okay at the bottom, click onto it and allow the MS program to update the drivers. You should see the device screen change and say "This device is operating properly". You can then close the windows and run the F20 desktop program. It should connect then.
Jul 06, 2008 • Navman GPS
Will not find city or locations
Hello.
Solution to the problem.
With the right piece of hardware and software, it ispossible to triangulate your location anywhere on earth using satellitenavigation. These gamin devices cansuccessfully guide you from one place to another, or they can simply use theconnection with the satellite to tell you your exact current location. Thelatter function requires you to know how to locate the GPS device using theoptions onscreen.
1 Purchase a GlobalPositioning System (satellite navigation) product. There are manymanufacturers, including TomTom, NavMan and Garmin.2 Turn on the GPS and leave itfor a minute or so as it establishes a connection between the device and thesatellite.
3 Navigate to the"Current Location" option in the "Tools" or"Settings" menu (the exact pathway to this option depends on whichGPS device you have). The satellite signal will now successfully locate yourGPS device.4 Type a ZIP code or placename once you have located your GPS device. The gamin can now successfully guide you to your finaldestinationThanks.
3helpful
3answers
My navman won't charge or turn on, any ideas?
screen shows computer to navman all the time
1helpful
I am in Sydney and the navman can't establish a signal. it remains stuck on the location it last got 'lost' on and cannot find a location.
in Australia you have to hold it upside down!
Seriously though the battery has to be fully charged to obtain a signal also in the middle of the city it may not be able to see clearly the birds . Other electronic factors can screen out connection.
Is it reporting a valid antenna connection in the pic that shows the satellite connections beoing made?
thanks for using FIXYA
Sep 27, 2009 • Navman F15
Cannot find satellite.
Hi have you tried doing a factory reset.I had the same on a lowrance and after do the reset it worked fine.
Apr 05, 2009 • GPS
2answers
3helpful
Navman S reset
Please go to Preference option on your navman. From the main screen you can setup the following preferences.Now scroll to 3rd page of the prefrences.There you will see the following options:
  • Start Up – enable/disable the tutorial and language selection screen that appear when the system is switched on.
  • Saved Info – here you can delete recent locations, favourites, avoidances and reset to factory defaults.
  • Bluetooth – this option allows you to setup bluetooth pairing with a mobile phone.
  • Tutorial – run the tutorial that appears at startup.
  • Shop Demo--runs a demo so you can see the Navman S50 in action.
Just select the SAVED INFO option and then you will see a RESET TO FACTORY DEFAULT OPTION.
Jul 23, 2008 • GPS
Navman
Jul 23, 2008 • GPS
2answers
Nav-cam 7700 returning to main menu after planning route
i have the same problem, turn the speed cameras off im afraid
Top Navman GPS Experts
ZJ Limited
ZJ Limited
ExpressFiX
ExpressFiX
Mike Cairns
Mike Cairns
Are you a Navman GPS Expert? Answer questions, earn points and help others
