Question about Electrical Supplies
Best way to fix or replace a leaking garbage disposal?
5 Related Answers
jsrock516
Jeff Rockwell
  • 5911 Answers
SOURCE: How to knock out garbage disposal plug
Turn off the power source to the garbage disposal. Take the drain hose from the dishwasher off the connector going to the disposal (if connected). Insert a flat blade screwdriver in the drain hose fitting and tap a few times with a hammer. The plastic plug will pop off inside the garbage disposal. Reach inside from the top of the disposal to retrieve the plastic plug. Sometimes you have to use a little force to tap the plug out. Hope this helps you.
Posted on Apr 08, 2008
KMusselmann
KMusselmann
  • 247 Answers
SOURCE: garbage disposal leak
Don to install a new one.
don't think it is a DYI and by the time you call for service it would be cheaper and use your DIY.
Hope this is a FixYa
Please rate the answer
Kurt
Posted on Mar 23, 2009
Anonymous
  • 63 Answers
SOURCE: I have a small leak coming from the bottom of my garbage disposal
replace unit...period
Posted on Apr 06, 2009
heatman101
D. Floyd Kolb
  • 43501 Answers
SOURCE: InSinkErator Badger 5, 1/2 HP Garbage Disposal: leaking out the bottom...
Here is a tip that I wrote about how and where a garbage disposal will leak andwhat can be done to fix it.
Garbage Disposal Leak from bottom of motor
heatman101
Posted on Sep 23, 2010
Macmarkus
Mark MacDonald
  • 2605 Answers
SOURCE: the dishwasher does not drain, i just replace my
Hello, Welcome to FixYa. I just came accross your post and immediately I thought, " drain plug in garb not punched out" this is very common when a new garb or dishwasher is installed..so much If I had a dollar for every one I saw or heard about I could be paid a couple of trip charges. If you haven't already done so, remove the drain hose from the garb and knock out the stop inside the spout. See your installation guide/owners manual ( for the garb/disposer ) if you still have it, that should show you "where" and "how". Let me know either way and I'll help further if necessary. Regards, Macmarkus :)
Posted on Feb 22, 2011
Can my garbage disposal be fixed?
Replace disposal because parts are not available and gasket is broken?
http://waterheatertimer.org/How-to-repair-and-install-Garbage-disposal.html#install
Gene
h
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
Jul 18, 2014 | In-Sink-Erator InSinkErator Badger 5 1/2...
Tip
If you have a garbage disposal and you find that it is leaking then you need to first of all figure out where exactly the water is coming from. The reason is that depending on where it is leaking from will determine whether it is easily fixable or if it would be better to just replace the entire garbage disposal.
With this is mind the best way to find the leak is to put the plug in place and fill the sink with water. Then place a food coloring or non-toxic dye into the water. Red often is a very easy color to spot under your sink. Then let the water down the sink with the disposal running. If the water runs down the side of the garbage disposal then you have a leak at the seal where the garbage disposal hooks up to the sink. This can easily be fixed by removing the garbage disposal, cleaning the old plumbers putty off of the ring and sink bottom, and then reinstalling the garbage disposal.
If you do not see any water coming down the sides, but it comes out the drain pipe, then the drain may be clogged and/or the seals for the drain piping are bad. The seals can easily be tightened. They may have come loose from the vibration of the motor or just the expansion and contraction that occurs from hot and cold water going down the drain lines. If the drain lines are clogged a garbage disposal safe drain cleaner can be used or the drain can be taken apart, cleaned and snaked.
If you have the dreaded water coming out of the bottom of the garbage disposal then you have the worst problem. The internal seals that are to prevent the water coming into the motor where the shaft goes through to the actual grinding chamber have deteriorated to the point where they no longer keep the water from coming into the motor. The water will make its way down through the motor and run out the weep hole or the reset button.
These seals are replaceable, but a new motor is needed for a complete fix on many garbage disposals. Because of this, many times the parts to repair this leak will be at least 75% the cost of a new garbage disposal. This makes repairing your garbage disposal, not a very good option. Replacing the whole unit is often the best way to go to make sure you have a fix that will last for a longer period of time.
That should cover all of the potential ways that your garbage disposal can leak. Hopefully you are able to pinpoint the leak and make the correct call to fix your leaking garbage disposal.
on Sep 23, 2010 | Kitchen Appliances - Others
Water leaking from my kitchen aid garbage disposal
Disposal must be replaced. It has rusted out:
Add a comment and say what you discover
May 05, 2013 | KitchenAid Kitchen Aid - KCDB250G Food...
My garburator works but is leaking water. It has a crack in the body.The garburator is only 4 yrs old. How can we fix this ?
You will need to replace it...
Here is a tip that I wrote about how and where a garbage disposal will leak and what can be done to fix it.
heatman101
Sep 16, 2010 | Ace Hardware InSinkErator Badger 5, 1/2 HP...
Water leaking on bottom of disposal by wire connection
heatman101
Sep 09, 2010 | Buck In-Sink-Erator BADGER 5XP BADGERVEXP...
heatman101
May 17, 2010 | Ace Hardware InSinkErator Badger 5, 1/2 HP...
I just noticed that my insinkerator Badger 5-75
heatman101
May 13, 2010 | Ace Hardware InSinkErator Badger 5, 1/2 HP...
Water leaking from bottom of disposal where
heatman101
t
Feb 12, 2010 | Ace Hardware InSinkErator Badger 5, 1/2 HP...
Electrical Supplies Logo
101 people viewed this question
Top Electrical Supplies Experts
Marvin
Marvin
john h
Are you an Electrical Supply Expert? Answer questions, earn points and help others
