Question about Marvel Refrigerators
Marvel Scientific fridge, model SA24RAS5LS displaying cE error message
Posted by Erin Mowatt on
Tom Chichester
    Top Expert:
  • Marvel Master
  • 57,285 Answers
Indicates a communication error. You may have to have a servicer determine what needs to be fixed.
Posted on Aug 09, 2020
1 Related Answer
Anonymous
  • 107 Answers
SOURCE: GPS Error Message on Start Up Model GM-7-1
sounds like your firmware or sd card is corrupt, unfortunately this is common on these. I created a dvd with the map and program data to reload everything in your unit, it also updates the map data to the last version issued. you can find it in ebay by searching for finedrive 400 map...
Posted on Jun 07, 2008
The fridge is displaying 59-Ce & there are no lights inside. Water & ice do not work
Hello friend, thank you for your post!
I see that you are having issues with your Electrolux refrigerator displaying a code of "59-CE" and nothing is working. That is not a valid error code. However, "CE" stands for a communication error and this can be cleared out by a reset on your refrigerator. In order to reset your refrigerator you can disconnect power from it for roughly ten minutes. If the reset does not help correct your issue it could be a possible problem with your main control panel or UIB (User Interface Board). I would recommend having a technician out to your home to perform a diagnosis and repair. This will help you avoid any part purchases that are not needed for a repair. I hope this information is helpful to you. -Matt
Mar 13, 2015 | Electrolux Refrigerators
Fridge digital display is showing CE, WATER DISPENSER BOT RUNNING WATER AND MOTER IS NOT ON
Hi berniekeenan -
Error code CE typically indicates a communication issue between the user interface and main control board. Try unplugging the unit or flipping the household circuit breaker off. Wait approximately ten minutes and turn the refrigerator back on. If the error code continues, I recommend scheduling service so a technician can accurately diagnose and repair your refrigerator.
Apr 20, 2013 | Electrolux 25.9 Cu. Ft. Side-by-Side...
Oregon wmh90 error eep
The message "error eep" is display on the main unit. I checked and changed the all the batteries, I pressed the reset button both on the main unit and on the outdoor unit and this message is still displayed.
Can someone help me
Thanks
Jan 25, 2013 | Oregon Scientific Measuring Tools &...
CE error code on electrolux refrigerator
Hello Alan Rapp - Typically error code CE indications a communication error at power up. You would need to contact a professional to check the wiring between the main control board and user interface board. Technician will need to move forward accurately and either part will possibly need replacing.
Jan 02, 2013 | Electrolux 25.9 Cu. Ft. Side-by-Side...
What does a CE error code on an Electrolux refrigerator (model EW26SS65GS) mean?
My fridge was having the same problem with CE being displayed, light and touch selector not working. With the assistance of one of my sons, we tilted the fridge back slightly and removed the control circuit board. Two of the three 470 u F capacitors were toast. My son drilled out the plastic brads holding the circuit board in the pan, then removed all three of the 470 u F capacitors. He soldered 3 new capacitors in place (0.59 cents each) and used 4 small screws/nuts to secure the board in place. After looking at the capacitors, he said a power surge had caused the damage. We went right out and bought a surge protector for the fridge. My fridge works perfectly now. While protecting tvs and computer from surges, I had never even thought of using a surge protector for the more costly fridge! Hope this helps someone else avoid an shamefully expensive parts replacement.
May 09, 2011 | Electrolux 25.9 Cu. Ft. Side-by-Side...
Error message CE displaying. Machine will not run.
Hi, concerning the CE error, the tech sheets indicate this is a problem with the motor control board with a blown fuse on the board. The solution is to replace the board....
Oct 01, 2010 | Whirlpool Calypso GVW9959K Top Load Washer
LG WM-2277HW Front Load Washer CE error message
Hi
The CE is for Child lock system error. i just had one on my WD-1049C. It is a system used to prevent children from pressing the buttons.
the way I fixed it on mine is by holding the temp button and the option button at the same time.
Jun 28, 2009 | LG WM-2277HW Front Load Washer
My light for my marvel wine fridge will not turn off?
There is also a light override ON/OFF button next to the door switch to allow the light to remain on for display setups. Make sure that switch is off. If it is off, then your door switch must be shorted out and should be replaced.
Jun 18, 2009 | Marvel (6SBARBSG) Wine Cooler
Jun 01, 2008 | Fine Digital FineDrive 400 GPS Receiver
Refrigerators Logo
131 people viewed this question
Top Marvel Refrigerators Experts
Marvin
Marvin
ray gallant
Are you a Marvel Refrigerator Expert? Answer questions, earn points and help others
