Question about Freezers
My coldspot freezer seems to run all the time.I do hear a click when I turn the thermostat up and down but the fan never shuts off? Is the fan suppose to run all the time?
The unit is an upright freezer about 30 years old and is frostfree.
Posted by [email protected] on
Steve Novak
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 153 Answers
When it runs all the time it usually means it is running low on freon.
Posted on Nov 22, 2020
5 Related Answers
douglas smith
  • 1462 Answers
SOURCE: Indesit fridge freezer (2 years old) not getting cold
if compressor is running, then you are correct in saying no point in replacing stat. by sounds of it you have a faulty compressor fault or a syatem fault - impossible to dignose by remotely. this is not a diy job i'm afraid
Posted on Jul 25, 2007
Anonymous
SOURCE: Indesit fridge freezer not getting cold (2 years old)
how to fix my indesit light inside the fridge reply asap
Posted on Sep 19, 2008
kachbibi1
Bill Dickerson
  • 979 Answers
SOURCE: problem with upright freezer not freezing
It sounds like the unit is low on freon or the compressor is going bad. You have several other components that could be affecting this as well. Make sure the coils are free from dust and clean underneath. This is a bit premature for you to have problems now, especially since it is a Sears product.
Posted on Feb 17, 2009
kachbibi1
Bill Dickerson
  • 979 Answers
SOURCE: FREEZER ALARM WILL NOT SHUT OFF
You can try 2 things. Unplug it for about 2-3 minutes and then replug it. It should reset itself. You can silence the alarm or muffle it. Silencing it should be hard. Disconnect it from its source. You may want to find out why it is alarming constantly. Have you called Sears and asked them?
Anonymous
  • 288 Answers
SOURCE: My Frigidaire upright freezer is only 4 years old & isn't working
freezers have safety devices to protect themselves. The compressor has an internal overload to keep it from overheating. some have external reset buttons and some do not. either way the cause must be corrected. if the freezer was low on refrigerant you would see signs of oil near the coils, tubing, or compressor. If there is no leak, it overheats when there is airflow restrictions(dirty coils) or a fan has stopped working. only a few screws keep you from seeing all there is to see. If it is clean and the fan is running, then the compressor may just be the culprit
Posted on Nov 27, 2009
Testimonial: "Thanks so much for your advice. Freezer seems to be working after being thoroughly thawed. Fingers are crossed."
My frostfree Kenmore upright freezer has been beeping alarm since the power was off for three hours this morning and showing -3 as temperature. What do I do to reset?
On some models the beeping will not stop until it gets to normal temp. The -3 is more than likely the set temperature of the unit. you can try to change that with the control. The best thing to do is get a thermometer to check what the actual temperature is.
Aug 20, 2017 | Kenmore Freezers
Why are the sides of my frostfree freezer so hot
the sides is were the condenser is it is called a hot wall condenser try to keep things from the sides so it can run more efficeiant
Jul 25, 2014 | Frigidaire 14.1 cu. ft. Upright Freezer...
Frigidaire upright frostfree freezer stored several years unplugged, restored power last night alarm keeps ringing and freezer is not getting cold.
Clean the unit entirely, coils, filter, etc. Then retry. You might have a faulty control board since it has not been used in many years. All depends on the location and humidity. That can tear up a thermostat and control board.
Jul 28, 2012 | Frigidaire 20.3 cu. ft. Upright Freezer...
Frigidaire upright frostfree freezer keeps icing up, needing to be defrosted. whats wrong with it?
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigeratornot Cooling or Fridge not Cooling
How to Defrost Refrigerator DefrostTimer Problem
WaterRunning in refrigerator from Freezer
Refrigeratoror Freezer not Cooling or Getting Cold
heatman101
Jul 05, 2011 | Frigidaire 20.3 cu. ft. Upright Freezer...
Same as post in Dec 09, I have water freezing at the bottom of my frostfree upright freezer (whirlpool).
Could be the drain is blocked, Otherwise the water would drain away and evaporate from the compressor unit.
Mar 27, 2010 | Kenmore 13.7 cu. ft. / 388 liter Upright...
I have a upright frostfree Woods freezer. It is only around 4-5 years old and this year it is making very loud running noises. It is not keeping things fully frozen.
Is your circulating fan working?
Sometimes they stick and need a shot of WD 40 and then work
it back and forth a little until it wants to take off again. Keep me informed
and PLEASE give a Thumbs Up for the effort. The Raz Shack
Mar 15, 2010 | Woods Upright Freezer MU07W
Water in bottom of freezer
the drain needs to be check for any kind of blockage. if the drain is blocked or frozen over this needs to be cleared
Sep 16, 2009 | Woods Upright Freezer MU07W
Frost buildup around the inside top of the door of an upright Frigidaire Commerical Frostfree Freezer Mod# FFU20IC8Cw2
This happens when your thermistor gets frozen along with the coils or there is a clogging of the freezer drain which causes Ice to build up and spread to the system. Another issue is that your thermistor may be faulty, telling the system inaccurate temperature. Incorrect freon pressure can also be a cause. I would advise first to have the ice melted by letting the unit stay unplugged and have it cleaned while at it.
Aug 11, 2009 | Frigidaire Freezers
Frostfree hoover fridgefreezer
If its freezing at the back that indicates refrigeration is good. it sounds like you have a thermostat control problem. Replace the thermostat.
Jan 12, 2009 | Engel Freezer 22 Qt. Fridge/Freezer
Frost in frostfree freezer
Make sure your rubber seal around the inside lip of the freezer is clean and sealing properly! this can be the first cause of frost !
Dec 10, 2008 | Kenmore Freezer 20.3 cu. ft. Frost Free...
Freezers Logo
142 people viewed this question
Top Freezers Experts
Dennis Boxerman
Muntejaya Ginting
Muntejaya Ginting
Marvin
Marvin
Are you a Freezer Expert? Answer questions, earn points and help others
