It could be a bad connection that shows up when the screws are tight that hold it together. Put one screw in, test, next screw, test, etc till you find the one causing the issue.
? 2:49
https://www.youtube.com/watch?v=Qba7_YHnXwM
Dec 2, 2013 - Uploaded by ozzysslayer
42" Vizio TV flickering strobing easy way to repair VW42L HDTV10A LCD TV ... EASY How to Fix Samsung LCD TV Flashing Flickering Screen!Missing: vp422hdtv10a snow
You TV will not be able to send photos, as it has limited functions and is not set to work as a full computer. You however can view (receive photos for viewing on the tv screen.) If your TV has a USB port, you can transfer your photos from your computer or camera to a thumb drive (A USB memory storage stick) which you then can plug into the USB port on your tv.
There are other ways to send photos to your tv, but there is not space here to get into how to do that.
While the set is on, pull the power plug. Then hold and depress the power button in for about a minute. Then replug set and turn it back on. If that does not reset the tv then you do indeed have a serious issue with the set.
unplug tv for 10-15 min to reset....have you updated the vizio (if its less than 6 mos.no need to) ...this is free...you need a blank flash drive..you go to the vizio web site look up your model for the latest if any firmware out ..download it to flash drive...shut tv off (in this case its off)...plug in flash drive to tv (it will read the flash and update).......when finish the tv will come on like normal...
