Question about Furniture
Koldfront TWR181ES wine cooler is very noisey, about a year old noise coming from top fan.Is it replaceable?
Posted by Robert Sticha on
5 Related Answers
Anonymous
SOURCE: U-Line 15WC Wine Cooler Problem
I just had the same problem. Also, I was getting a burning smell. The coil on the unit was blanketed with dust and dog hair. First, I cleaned it all out and tried it. It really didn't do much and I still had the burning smell. I then opened the back and recognized that the fan was not working. Turned out to be really dirty. Cleaned it and no it is working fine.
Posted on Oct 18, 2008
Anonymous
  • 1122 Answers
SOURCE: WINE COOLER NOISE
when the fan comes on so does the compressor,hold the fan with a rag and see which one is making the noise-mike
Posted on Nov 11, 2008
Anonymous
  • 3 Answers
SOURCE: Noisy Wine Fridge
The problem is likely with one of the two fans. A new fan is available from Danby (1-800-263-2629). My noisy fan is the condensor fan located at the bottom rear of the device. After removing the cooler from under the cabinet, the source of the noise was obvious. You will need to tell them whether it is the upper fan or lower fan. Leave the cooler upright for a few hours before you plug it in so that you do not damage the condenser. Price for the fan from Danby is $20.15 including shipping. Users Manual is available at http://www.danby.com/manuals/DWC512BL.pdf -Ron
Posted on Apr 13, 2009
Anonymous
  • 340 Answers
SOURCE: wine cooler makes noise and runs hot
The price looks fine for my area its about a 3 hour job done properly. you should consider a new wine cooler and cut your losses because if their only replacing the compressor they should be replacing the cap tube and liquid drier if the cap tube is not replaced could be a waste of money
Tom
Posted on Jun 17, 2009
subdriver
  • 101 Answers
SOURCE: I have the Marvel 70 bottle wine cooler and it is
I believe the 6SBAR has an evaporator fan located behind the evaporator plate ( the cooling plate) inside the unit. They had some issues with the bearings in those fans failing and will sound like a small jet engine sometimes (high pitched whine). When you hear the noise, open the door and if the noise level changes (either gets louder or goes away) then it is the evaporator fan. If your noise is coming from the compressor area and does not change when you open the door, it is most likely the condenser fan blade is loose. The evaporator fan looks like a small computer cooling fan and is located near the bottom center of the evaporator plate (out of site). The factory sells a replacement kit with a much better fan and new power supply. You can reach them at 800-223-3900. Good-luck.
Posted on Jan 09, 2010
Plugs in but wont turn on
Koldfront 12 Bottle Stainless Steel Slim-Fit Thermoelectric ...
www.amazon.com/Koldfront-Bottle-Stainless-Slim-Fit...
Amazon.com, Inc.
Rating: 3.7 - ‎42 reviews
Koldfront 12 Bottle Stainless Steel Slim-Fit Thermoelectric Wine Cooler - Black/Stainless Steel ... Item model number, TWR121SS .... the fridge. so you hvae to take out a wine bottle to reach it an usually I would like the controls on the door and only turn in .... The door can be reversed which the description did not mention.
www.edgestar.com/Koldfront-12-Bottle-Stainless-Steel-Slim-Fit-Thermo...
Koldfront 12 Bottle Stainless Steel Slim-Fit Wine Cooler Primary Image ... steel, the Koldfront 12 Bottle Slim-Fit Thermoelectric Wine Cooler (TWR121SS) is ... cabinet and stainless steel accents ensure that this freestanding unit will look ... Power: 70 W/0.95 A .... Unfortunately, your browser does not support video elements.
www.walmart.com/.../Koldfront-12-Bottle-Stainless-Steel-Slim-F...
Walmart
$109.99 - ‎In stock
Jan 20, 2016 | Koldfront 12 Bottle Stainless Steel...
Wine cooler not cool
Take a look at: https://edgestar.zendesk.com/hc/en-us/articles/200604529-My-beverage-cooler-is-not-cooling-below-50-degrees-How-do-I-get-the-temperature-lower-
May 11, 2013 | EdgeStar TWR181ES
Edgestar wine cooler eh error code
You can download the owner's manual at: http://www.edgestar.com/TWR215ESS-EdgeStar-21-Bottle-Dual-Zone-Wine-Cooler/TWR215ESS,default,pd.html?cgid=Wine_and_Beverage-Wine_Refrigerators
Apr 10, 2013 | EdgeStar TWR181ES
I have the Marvel 70 bottle wine cooler and it is making loud whining noise like if you put a stick in the wheel of spinning bike spokes when it is cooling down sometimes. it does not seem to be the fan...
Nov 19, 2009 | Marvel (6SBARBSG) Wine Cooler
Noisey, loud shrill
If you just got the unit you should contact your dealer for warranty service. The only noise you should hear is a slight hum of the compressor and the soft blowing noise of the condenser fan. It sounds as if the evaporator fan on this unit is toast. That is also why is it having a hard time maintaining temperature. The temperature indicated is actual air temperature sensed so it will go up and down a couple of degrees above and below setpoint but when operating correctly the product temperature will be very stable.
If the servicer does not fully understand the new digital system, make sure he/she contacts the factory technical assistance rep. at 800-428-6644.
Jul 16, 2009 | Marvel (6SBARBSG) Wine Cooler
Loud noise
The compressor fan is making the noise and causing overheating as well. Easy fix. Call Danby with model # and they can figure out correct fan. Part will cost around $10 and is easy to replace. Plug and play with screws. Good luck
Apr 21, 2009 | Danby Silhouette DWC512BL Wine Cooler
WINE COOLER NOISE
Nov 11, 2008 | Danby Silhouette DWC512BL Wine Cooler
Furniture Logo
117 people viewed this question
Top Furniture Experts
Tom Chichester
ray gallant
Are you a Furniture Expert? Answer questions, earn points and help others
