Washing Machines Logo
Top loading GE color profile washer (wpse4200a) won't fill
Top loading GE color profile washer (wpse4200a) will try to fill, but never get there. It will try for a while, and then eventually stop. This happens on the initial fill cycle and the fill prior to the rinse cycle. (Currently, I manually move it to the next cycle by flipping the rotary selector after the fill cycle stops.) Recently timed the attempt to fill going into a rinse cycle and it was well over 45 minutes.
Posted by walshe_home on
Charles T Nevin
  • 4,070 Answers
You may have a water supply problem. There is a mesh screen in the hoses where they hook to the washer. Make sure they aren't clogged up
Posted on Sep 19, 2009
1helpful
Where is the lint screen on a GE prodigy profile top load washer?
most top loader flint collectors are in the top of the agitator where you put in the comforter fabric softener. Pull this section up and the lint sock will be at the bottom of it
Will fill but won't wash
Sounds like the timer,that is the brains of a washer,if the time fails it will not run certain functions,in you case it is the spin .
2answers
My GE Profile Prodigy WPSE4200A Washer does not spinning for drying and it smells like burning rubber. But it does aggitate for washing. It is a belt issue or could be some electronic device issue?
Problems with a washing machine not spinning or not draining are often interrelated..
If you are having a problem with your top load washer then check out thistip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkoutthis tip...
Front Load Washing machine not draining and or not spinning
heatman101
GE top load Profile washer. Spin cycle not
If you are having a problem with your top load washer then check out this tip...
Washing Machine2_bing.gif does not Pump or Spin
http://www.fixya.com/support/r4617986-washing_machine_not_pump_or_spin
If you are having problems with your front load washing machine2_bing.gif then checkout this tip...
Front Load Washing Machine2_bing.gif not draining and or not spinning
http://www.fixya.com/support/r4784376-front_load_washing_machine_not_draining
heatman101
GE profile top loader, agitator and spin start and stop
Is this a newer model washer? I have one of the newer models and it does the same thing. It is supposed to do that.
4helpful
Washer only spins
Have you tried to unplug the machine, sometimes the control boards can get stuck and if you unplug it for say 30 seconds then plug it back in, it may reset itself. otherwise you may have to call someone these are very complicated machines.
1helpful
2answers
Ge washer # WBVH6240FWW
We have a GE washing machine that works fine with no load, but will not finish the cycle with a full load.
GE Profile Prodigy filled with water & won't start
If you don't hear a click when you close the lid, replace the lid switch.
Washer stalls while filling, must press start button to get it going again
How is the water tempture is it hot water when you have it set on hot?? and vice versa?? you may have a clogged fill valve screen you will need to shut off the water and remove the fill hoses and check the screens that are in the water inlet valve use a opened paperclip to hook and puul them out to cleans Hope this helps If not plz let me know and we can go futher into the mach
Kenmore Top Load Washer
You say its a Kenmore, but have GE Listed, so will hope you have a Kenmore. Sounds like if its just not working in one cycle, its more than likely a timer issue. Would need a model number to look up the part, but they usually range in price from $100 to $165 in price. They are not usually that hard to replace, so if you want to replace it, let me know and will get you directions, etc for that. Good Luck!!!!
Top Washing Machines Experts
Marvin
Marvin
john h
