Question about RCA D52W20 52" Rear Projection HDTV-Ready Television
D52W20BYX1 Green problem
When powered on the screen will go completly green and within a few seconds shut off. Does this three times before going off for about 3 or 4 minutes before you can turn back on to see the same thing. If I turn the green adjust all the way down the tv will stay on but stay green with sound. If I unplug the green adjust wire, not focuse, the tv will stay on but with a lot of green tint and sound. I've replaced the CRT board, and the Tube. Also tried a different Yoke. If I plug the green adjust wire in while the tv is on the tube will charge up and shut down the red and blue. The CRT board I bought was used but was told worked. The Tube I bought was also used and was told worked. Both were bought from "different" people. Tried
  • 3 more comments
  • blaine1916 Sep 19, 2009
    Yes. if i pull the crt board off the bottom of the tube the red and blue tubes come on and the the tv wil work in the blue and red. If i plug the crt board back in, the green tube draws all the power and the red and blue shut off and the entire screen goes green. eventually shutting off the tv.
    I have "not" replaced the focuse block. I have tried to take the green and red adjust wires and change the two so the green wire would be inserted into the red output. No change though. The green tube would still draw all the power, screen would then go green and eventually shut off.
  • blaine1916 Sep 21, 2009
    Okay, So per suggestion from a tv repair shop. I tried to use the red crt board hooked up to all the red connections. Basicly just pulled the red crt board from the red tube and pluged into the green tube. Not unpluging any wires. And the tube powered up right and didn't go green and shut off. Whats this mean?
  • blaine1916 Sep 22, 2009
    When you say boards, are you talking about the crt boards or the chassis convergence board?
    I have the volt meter. What am I looking for between the boards? Should I check the boards hooked up to the tubes or disconnected?
  • 647 Answers
If you unplug the Green CRT board (neckboard) do you get the other 2 tubes comming on?
Posted on Sep 19, 2009
  • 2 more comments
  • Anonymous Sep 19, 2009
    Has the focus/screen block been replaced? Or have you tried swapping the red (or Blue) inputs and o/p's from the focus block?
  • Anonymous Sep 21, 2009
    That means the green tube is ok and the problem has to do with the supply to the green tube (this could be confirmed by putting the green board to the red tube it should go all red and shut off) Check the main voltage supplies on the green board you'll need a meter and possibly a scope to check. Let me know if you need more info (you can compare voltages from red or blue boards to the green board)
  • Anonymous Sep 22, 2009
    The CRT boards
    You'll need to get a service manual (Schematic) to trace out where the green signal enters the CRT pcb and the DC voltages that drive the signal.
  • RCA Master
  • 5,138 Answers
I would go back to green tube disconnect ,unplug CRT board to green tube if set stays up playing its the tube.
  • ladywinn
    ladywinn Sep 19, 2009
    From what you said your GREEN TUBE is BAD.anytime you disconnect CRT and set comes on that tube is shorted.
6ya staff
SOURCE:
Tip
Format nokia
Follow this instructions to format your s60 phone
method 1:
2) Switch off your phone
3) Press the power on/off to switch on the S60 phone.and Press and hold these three keys together:
* Green dial key,
* Sharp key (#)
* One key (1)
note: Do not let go the three keys until you see the "formatting" screen displayed
4) Wait a few minutes until the format is complete. Your phone will now be at its original factory settings
method 2:
1)press *#7370#
2)enter security code(default code is 12345)
3) Wait a few minutes until the format is complete. Your phone will now be at its original factory setting
Now restore all your ring tones, messages and contacts and you once again have a fresh OS.
on Dec 17, 2010 | Cell Phones
Tip
To unlock Nokia N73(all S60 phones)
Make sure your phone is fully charged. Ads by Google
'; for(i = 0; i '+ '' + google_ads[i].line1 + ' ' + google_ads[i].line2 + ' ' + google_ads[i].line3 + '
' + '' + google_ads[i].visible_url + ''; } s += ""; document.write(s); return; } google_ad_channel = '+7733764704+1640266093+9911500640+5009222491+6529619144+3607312525+8962074949+8941458308+6876289738+7122150828' + xchannels + gchans; google_ad_client = "pub-9543332082073187"; google_ad_output = 'js'; google_ad_type = 'text'; google_feedback = 'on'; google_ad_region = "test"; google_ad_format = '250x250_as'; //--> google_protectAndRun("render_ads.js::google_render_ad", google_handleError, google_render_ad);
Backup your contacts list and personal files to MMC memory card (if possible).
Switch off your N73 phone.
  • The green dial key,
  • The star key (*)
  • The three key (3)
Press the power on/off for 1 minute to switch on the N73 phone. Do not let go of the three keys until you see the “formatting” screen displayed
Wait a few minutes until the format is complete. Your N73 will now be formatted and restored to its original factory settings.
This wont ask you for Lock code when you switch it on next time.
on Feb 14, 2010 | Nokia N73 Cellular Phone
6233 mobile how to formet
Hi, follow these steps to format your nokia:
1. Switch off your phone.
2. Press and hold three keys: the green dial key, star key (*), and number 3 key on the keypad and then press the power on/off to switch on the phone.
(remember not to let go the three keys until a formatting word show on the screen)
3. Then your phone will be back to it's original settings when the full phone formatting is completed. Just wait for a few minutes.
Hope this can help you,GoodLuck =)
Aug 31, 2011 | Nokia 6233 Cellular Phone
Manual formatting of Nokia N70+how to
method 1:
1) Backup your contacts list and personal files to MMC memory card (if possible)
* Green dial key,
* star(*)
* three(3)
method 2:
1)press *#7370#
Dec 18, 2010 | Nokia N70 Cellular Phone
Screen goes green then black
That model is famous for bad picture tubes, and thats the classic symptom of a bad tube shutting the set down
Jun 25, 2009 | Sony KP-51WS500 51" Rear Projection...
On my playstation 3 the green light stays on for about 4 seconds then beeps three times and shuts off any answers
I am not sure why but hopefully this will work... Shut down the PS3 make sure it's shut down... Unplug the main power cord and after a few minutes replugged it and turn it on! I hope it works! I usally have crazy problems like that but as soon I reset it and I forget the problem!
Feb 07, 2009 | Sony Playstation 3 (PS3) Console
Hi..how to format ngage if its stuck up in nokia logo???
If you have any files that are important to you, make backups.
1. Make sure you phone is fully charged.
2. Backup your contacts list and personal files to MMC memory card (if possible).
3. Switch-off your phone.
4. Press and hold these three keys together
-Green dial key,
-Star key (*)
-Three key (3)
then press the power on/off to swtich on the 6600 phone.
DO NOT let go the three keys until you see the “formatting” screen displayed
5. After a few minutes, the format will be complete. Your 6600 will now be at its original factory settings.
Disclaimer : I will not be held responsible for anything that happens to your phone as a result of following my guide. Use this guide at your own discretion and risk.
Good Luck.
Live, Love, Laugh.
Feb 18, 2008 | Nokia N-Gage Console
Sony proj tv,sound,green pict few seconds then shuts down
could be three different things.
1. could be the crt itself as a tube with dfective phosphure wil do this
2. could be the vertical ic on the crt board
3. could be the focus pac.  located in front of tv with 6 adjustment knobs on it.
Oct 06, 2007 | Sony KP-41T65 41" Rear Projection...
Samsung 62" rear projection t.v. model # PCL6215R
The most likely problem is a bad solder connection on one of the circuit boards. If you have the skills, remove the boards and look at all connections for cracked solder joints or cold solder joints. Resolder anything suspicious.Good luck.
Jun 11, 2007 | Samsung PCL6215R 62" Rear Projection...
RCA D52W20 52" Rear Projection HDTV-Ready Television Logo
187 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
