Question about Kenmore Washing Machines
Kenmore Washer 796 will shut down after wash. Need to unplug and plug back in before starting a new load?
    Top Expert:
  • Kenmore Master
  • 30,511 Answers
Mainboard issue. Watch this
https://www.youtube.com/watch?v=EmSJxtSuu3A
Posted on Nov 14, 2019
6ya staff
SOURCE:
Anonymous
  • 9 Answers
SOURCE: LG WFT1081TP Top load washer
The fuse is located in a black cover.  You need to gently pull the front panel out of the way and look to the right of the unit, in the area under where the panel was.  There, you will see a black wire running into a black cylindrical case that has a black wire running out of the other end.  Heed the warning on the label, please, and make sure that the power is unplugged form the wall.  Gently pry open the casing and you will see the fuse within.  The ends of the wires just pull off (gently) and then you have the fuse.
Tomorrow I go on a fuse hunt and try this out.
Posted on Mar 11, 2008
Anonymous
SOURCE: Kenmore Elite Front Loader HE 4t washer
I am getting an f 02 error
Posted on Oct 17, 2008
Anonymous
  • 12 Answers
SOURCE: Kenmore model 110 washer will not drain at end of wash cycle
It could be the lid switch or the timer.
Posted on Jan 31, 2009
Anonymous
SOURCE: kenmore top load washer model 110.44722401 won't start
The Machine does not know the lid is shut.... there is an arm connected to the lid... that arm runs just inside the the top cover and presses a button to signal the lid is down.. some where along the line the arm isnt pushing the button..take off the top cover and it should be an easy fix
Posted on Jul 07, 2009
bjcornell
SOURCE: Kenmore Elite HE3t 11042922200 Front Loading. F02 drain Problem
We experienced the same thing. I was able to restart and locate the noise to the water pump. After disassembling the water pump found the impeller shaft sliding out. For some reason this shaft will not stay in place. Had to order a complete pump assembly as the electric motor is not available.
Posted on Jul 13, 2010
Kenmore washer model #796 front load washer - washer will not spin out - went to drain water from drain hose - no water will come out - so I unscrewed pump filter - water is pouring out of there - help
OK....I am here to RESCUE you...1st, DON"T do that anymore! You will get wet! LOL. Simple solution. You need a New Drain Pump replaced and installed. Once that is done. I do NOT want to hear about you going down there anymore and doing....That! LOL...
Your machine will be happy and spin.and drain all day Long!
If you need further help, reach me via phone at https://www.6ya.com/expert/steven_b77d19396bfe2249
Mar 05, 2014 | Washing Machines
My front load kenmore washer is stuck on control lock when unplugged it start at 14min when plugged back in on the spin cycle and when it reaches 2min the machine shut off and the control lock flashes door...
Hello & Welcome to FixYa
This is a common issue with washer however; your whirlpool duet washer needs a reset to resolve the control lock problem. Press and hold the DRAIN/SPIN button for 15 seconds to reset the control. Please get back to me if you have any other questions.
Kevin
Oct 04, 2011 | Kenmore HE3T Washer
Washing machine will not turn on it shut off
Have you tried unplugging the unit and waiting for a minute and then plug it back in. The load might have been off balance and caused that condition. Once it has been reset you might be able top end the cycle.
Dec 07, 2017 | Kenmore HE2 Plus Front Load Washer
Kenmore Elite HE3 washer lights light but wash won't start
Sometimes I just have to unplug the machine, wait a few seconds and plug it back in and it works. I guess it resets itself or something.
Feb 26, 2009 | Kenmore Elite 45986 Front Load Washer
"le" on the LG WM0532hw front load washer errror
try unpluging for 45 seconds than hold in the selector knob for 10 sec. & plug back in
Feb 02, 2009 | LG WM-0532HW Front Load Washer
Started a new load of wash and water never shut off flooding room
you can check for a broken/cracked/ dettached plastic hose leading from the back left side of tub to the pressure switch under the main console. usuall problem is it dry rots and cracks, or comes loose after shaking/vibrating,
Nov 15, 2008 | Kenmore 22422 Top Load Washer
Kenmore elite oasis (canyon capacity) top load washer
The button interface on the console has failed and will need replacing. Read owners manual for possible limited warranties on electronic components.
Jun 03, 2008 | Kenmore 24032\24036 Top Load Washer
Please help , tell me why door is locked, on h 2 kenmore washer,
THANK YOU,
still nothing,
red doorlock light on, wont do anything,
I have to unplug so it will shut off,
when I plug in and hit start, red light stays on again,
Mar 28, 2008 | Kenmore 4292x Front Load Washer
Washing Machines Logo
47 people viewed this question
fordexpert
Harvey Mahal
Kristen Denison
Kristen Denison
Level 1 Expert
