Question about Uniden Lands Phones
I have a Uniden 5.8 Exa1580 phone w/ans base. For no reason the base does not have the infoon screen, it is all on handset. Plus will not record, nor can I make call. Help
Posted by julie claridge on
5 Related Answers
Anonymous
SOURCE: Uniden cordless phones
This sounds like the register-deregister problem elsewhere on this page. Try holding down the "end" and "#" buttons for about 6 seconds to deregister the phones and then reregister them. I had this problem too and it worked for me.
Posted on Jan 21, 2007
bunnydawg
Roberta Smith
  • 5158 Answers
SOURCE: Add extra handsets to Uniden 5.8Mhz
first thing to try.... place each handset into the base of the system you want them to be on.... and watch the charging light... it should flicker... the phone may work then... do that with all the phones..... also what is the make and model of the unit you already had.
And if you don't already have it... here is the user guide for that phone system.
http://www.uniden.com.au/resources_main/pdfs/DSS7855_7855+1_OM%20.pdf
Posted on Apr 03, 2009
Anonymous
SOURCE: bt graphite handset states out of range but is on base
the manaul states that by resetting the phone should solve this. In my case removing the batteries from the handset for a couple of seconds seemed to work just fine.
Regards
Posted on Jun 07, 2009
Anonymous
SOURCE: ADDING HANDSET SAYS OUT OF RANGE
A search of Uniden support only said to call 1-800-297-1023 with handset registration issues. The rep picked up quickly and walked me through the reset procedure. Here it is step-by-step:
1. Remove battery
2. Hold down the * and # buttons and reinsert battery. You should hear a long beep. If not retry. (This is a bit awkward but hold the handset upside down and it's workable)
3. Screen will be blank. Immediately press the right soft menu button.
4. Screen will report that EEPROM is clearing and then state EEPROM Clear Ok
5. Remove battery (yes again)
6. Reinsert battery (this time there's no need to hold down any buttons)
7. Handset will reboot with Welcome screen and then state that phone must be registered (this is the status a handset should be in from the factory)
8. Place handset on base and it will register as normal
Posted on Oct 09, 2009
Greg McCarthy
  • 1340 Answers
SOURCE: How do I record a new message please?
There should be a button that reads "greeting".If there is no button that says "record" or "rec",then just hold down the greeting button and it should prompt you to record.It seems odd though,the digital answering machines usually hold their greeting even when losing power and coming back on.If it currently gives a "computer voice" greeting it should not be a problem.If there is no "computer" greeting,there may be a problem.Good luck.
Posted on Jul 22, 2010
Testimonial: "Thank you for your help and speedy reponse. I will try to set it up when I get home tonight"
How do i remove announce only from my answering machine
First, turn on the Answering system, either with the base Answer On/Off button or the handset (Ans. Setup, Ans. On/Off). Next make sure that the memory isn't full. If the message LED reads FL, delete old messages with the handset. You'll need to press the button with the envelope/Mute on it to access the message.
Now, press Menu/Select, scroll through the menu to Ans. Setup. Select this and search for Record Time. Select this and choose the recording time of 1 or 4 minutes. Press Menu/Select again to save the setting.
This is in the manual on page 45. You can get the manual from Uniden at https://www.uniden.com/product-information/owners-manuals . Search for the DECT1580 (the last 5 indicates the number of handsets). The direct link to the manual is https://www.uniden.com/File%20Library/FooterNav/Product%20Information/Owners%20Manuals/DECT1580om.pdf .
I hope this helps.
Jun 01, 2016 | Uniden DECT15805 Cordless Phone
The display screen is showing the word "SEARCHING" on the screen, can't get the phone to work, cannot pick up an incoming call, the display also displays "HANDSET OUT OF RANGE" WHEN ANY BUTTON IS...
From the Uniden support site.
You can first try a Basic Reset.
A reset is done by following the below steps:
1. Disconnect the battery from handset(s)
2. Disconnect Phone Cord from wall jack
3. Disconnect Phone cord from base unit
4. Disconnect AC adapter from wall outlet
5. Allow to sit for 30 min
6. Reconnect Phone Cord to base
7. Reconnect Phone cord to wall jack
8. Reconnect AC Adapter to wall outlet
9. Reconnect battery into handset until you click or feel the plug snap into place
10. Re-Register Handset by placing on main base
reference
Mar 13, 2015 | Uniden DECT 6.0 Cordless Phone ID
Uniden base flashing 88 8
I just got off of the phone with Uniden for the same issue with my D1680-4. The alternating "8" - "88" code is an indication that the base is dead. They will be sending me a new base (and 2 handsets). During the call I learned that if you do not have a receipt, Uniden warrants their phones for up to 15 months. The advertised 12 months, plus 3 months for the product to get from manufacturing, through distribution channel and finally sale to the consumer.
Feb 17, 2012 | Uniden D1680 Cordless Phone
I have the uniden dect 6.0 3 handset. I lost my manuel and do not know how to record my answer message
Which specific Uniden DECT 6.0 phone do you have? There are a number of them. Uniden has the manuals available here: http://www.uniden.com/bin/venda?ex=co_disp-view&bsref=uniden&scat=dectphones_mnl . Phones are listed in alphabetical and numerical order.
If the answering system is off, turn it on before proceeding to the following steps.
If you are at home, there are usually two methods to access the answering system. Some Uniden phones let you set the outgoing message from the base or the handset. Others will only let you set the message from the handset. (Calling in remotely is more complicated.)
To access the answering system menu from a handset, on some models, push the Mute/Messages button. Then let your current message play or press 5 to stop the recorded announcement. Then either use the up/down arrows to select Record New Greeting (or the number that matches the sub-menu item). It's number 8 on the DECT1480. Then wait for the prompt (tone or "Record Greeting") and then speak into the handset clearly. Press 8 to stop recording and press End to save the message. Press 6 to select the outgoing greeting if a default greeting is available.
On other Uniden DECT phones, press Menu and go to Ans Setup. Then choose the line for the greeting (if it's a multi-line phone) and then select Record Greeting. Press Start, wait for the prompt and then press Stop when done. Press Stop again to save the message. If there is an optional pre-recorded greeting, use the Greeting Option submenu to select the greeting to play. (This applies to the DECT4086.)
From the base, you'll do something similar. However, you should stay about 9" from the microphone while recording. Messages can be between 30 seconds and 3 minutes 30 seconds for most systems.
I hope this helps.
(recording a new greeting during a remote call can be done but consult the manual for details.)
Dec 21, 2011 | Uniden DECT 6.0 Cordless Phone ID
E4 - Erros My uniden phone model TRU 9485 - 4WX after outage power, now on LCD screen appear E4 and it didn't respond to any button when i press. I read some help which they say press 3 button...
Hello
Connect the phone line and power UP the base unit. Place the handset on base to get charged. It must reset automatically when you place the handset on base to charge. If not; resetting both handset and base unit is necessary.
Resetting the Handset
You may need to reset your handset in the following instances:
You lose a handset and purchase a new one. When you try and register to your existing base you get registration
failure.
You are unable to register any handsets to the base.
You had a base which needed to be exchanged by the manufacturer. When you register your existing handsets
to the base, the handsets say #3 and #4, but you only have 2 handsets.
When you are instructed to by the one of the manufacturer's call center representatives.
To reset, do the following:
Press and hold [ ] and [#] for more than 5 seconds. Select DEREGISTER HS.
WHICH HANDSET? appears. Select the handset that you want to de-register, and press the OK soft key.
DEREGISTER HS appears. Select YES, and press the OK soft key.
ARE YOU SURE? appears. Select YES, and press the OK soft key. You will hear a confirmation tone. The
handset will clear its registration information from the base, and then delete its own base information.
MODELS VARY! PLACE HANDSET ON THE BASE FOR REGISTRATION OR REFER TO OWNER'S MANUAL. To
re-register the handset to the base (see page 25).
If the handset cannot contact the base, it will display OUT OF RANGE. Make sure the handset is in range of the
base and the base is connected to power.
Note: It is also possible to reset the handset back to its original factory settings. All changes including Caller ID information
will be erased. For more information on resetting the handset back to factory settings and when you need to
do this, see www.uniden.com or call our Customer Service Hotline. See back cover page for contact information.
Resetting the Handset without the Base
If your original base is not available for some reason (for example, it is lost or somehow incapacitated), you can still
reset the handset and use it with another base.
Move the cursor to select BASE UNAVAILABLE and then press the OK soft key.
BASE UNAVAILABLE appears.
Move the cursor to select YES, and then press the OK soft key. ARE YOU SURE?
appears.
Move the cursor to select YES, and then press the OK soft key. You will hear a confirmation tone. The handset
will delete its own base information without trying to contact the base. When the base information is deleted,
the handset displays MODELS VARY! PLACE HANDSET ON THE BASE FOR REGISTRATION OR REFER
TO OWNER'S MANUAL. Register the handset to the new base (see page 25). of its user manaul.
OK.
Sep 12, 2011 | Uniden TRU9485 Cordless Phone
Regarding connecting old and new phone of same brand
1. Remove battery
Oct 12, 2009 | Uniden Cordless Phone
1. Remove battery
Aug 02, 2009 | Uniden DECT 6.0 Cordless Telephone...
Cant register/install a new dect 6.0 uniden 2060 phone
I had a similar problem which I finally fixed. You did not say if any of your phones registered.
First try the following recommended by Uniden Support:
Your phone(s) should be fully charged before putting them on the main base.
Unplug the battery from the phone by removing the battery cover and removing the connector. Then, push the # and * key together and hold while you plug the battery back in (requires some dexterity). Continue to hold the two keys until you hear a confirmation tone. This will force the phone to reregister. Put the phone on the main base (if you are sure it has a fully charged battery) and see if it will reregister it to solve the problem.
That did not work for me. So, I followed the instructions to de-register the handset (even though it hadn't really registered). But, I also pretended like the Base was not available (because using the base in this step also failed).
1) Press and hold the hang up and # keys for at least 5 seconds.
2) Move the cursor to select Base Unavailable and then press Select.
3) Select the base you want to deregister from, press Select and then move the cursor to Yes and select.
This causes the phone to delete any of its base information.
At this point, again insure that your phone shows the battery is fully charged and if it is not, put it on the stand alone charger base (not the main base). With the battery fully charged, place it on the base and try registering again by placing it in the main base.
If neither of these approaches help, contact support at Uniden.com.
However, my problems were cleared when I cleared the handset with the second set of instructions.
Apr 25, 2009 | Uniden DECT 6.0 Cordless Phone ID
Can't talk on both phone at same time. second on is always dead.
The DXI4286-2 is an Analog phone, it does not allow for both handset to be used at the same time. You can transfer a call from one handset to another, but cannot talk on both at the same time.
The following is from the user's manual for your phone:
Unavailable message is displayed
on the LCD screen of the
handset.
• Make sure the other handset is not already in use. Both handsets cannot be in talk mode at the
same time.
• Place the handset in the main base for at least 5 seconds to re-register to the main base.
• Make sure the handset is not too far from the main base when trying to use.
You might want to try one of the DECT or a Digital 2.4 or 5.8 GHz phones, they allow you to use multiple handsets at the same time.
Apr 04, 2009 | Uniden Cordless Phone
B-DX15686-3TA uniden corless phone
Press the DELETE/TRANSFER button at the bottom of the handset
Jul 28, 2008 | Uniden Cordless Phone
Lands Phones Logo
119 people viewed this question
Top Uniden Lands Phones Experts
k24674
Marvin
Marvin
Are you an Uniden Lands Phone Expert? Answer questions, earn points and help others
