Question about Amana ABD2533DES Stainless Steel Bottom Freezer Refrigerator
Location of thermistat for freezer - Amana ABD2533DES Stainless Steel Bottom Freezer Refrigerator
Posted by mikemclann on
Anonymous
  • 236 Answers
Usuall in the freezer compartment. Frige knob controls air flow only
Posted on Sep 19, 2009
Ice buildup in the top freezer
YOU HAVE A DEFROST ISSUE WHICH IS GOING TO BE A DEFROST THERMISTAT OR A DISDONNECTED HEATER
Jul 27, 2012 | Whirlpool 21.0 cu. ft. Top Freezer...
I have a Kenwood side by side with water and ice despender. The freezer doesnt work fine but the other side(refrigerator) cool is good and the motor runs constantly without turning the switch off. It is...
If no ice build up on back wall of freezer then you may have a refrigerant leak causing the less than ideal situation with freezer. Need to locate and repair leak and fill to specs to get proper cooling.
Jul 24, 2017 | Refrigerators
Not giving up on frigidarie
this would appear to be a thermistat control issue.make sure that the doors are closed tight and the seals are in good shape this will also cause long periods of run time.if those thing are good replace the thermistat control.good luck with your fridge let me know hwo things worked out for you.
Jan 21, 2010 | Frigidaire FRT15B3A Top Freezer...
FREEZER KEEPS WORKING NOT REFRIG
Yes, the defrost thermistat turns the element of when temps reach about 50 degrees F. The adaptive defrost tell the fridge to go into defrost. When the ice melts the defrost thermistat turns the element off.Whe can check the defrost thermistat if you like.
Your refrigerator has a adaptive defrost board inside the fresh food compartment hiding behind the control panel. That would be the first thing to consider that may be bad. But you also said you manually defrosted the refrigerator and it began doing this again about a month later. Take the model number and enter it in the search feature for model at it will take you to a page so we can look at the same refrigerator and work together to fins the answer. Below is a link click on that to look over your model. The adaptive defrost part number is 61005988
Let me know when you are ready, Thanks, Sea Breeze
http://servicepartstec.blogspot.com/
It is also possible the defrost thermostat is defective or a problem with a defrost element. Did you cange both element whith new defrost thermistat? Part number 61006199
May 11, 2009 | Maytag MZD2766GES Side by Side...
REFRIGERATOR BOTTOM IS NOT COLD.
OK that number is good, Frigidaire model GLRT13TEB3 Sometimes the freezer section appears to be cold enough but you may need to check it if we don't find the problem soon. If your freezer is not defrosting properly it will restrict air flow to the fresh food section and that make us think that's the only problem. Your refrigerator has a defrost timer located inside the fresh food section behind the thermostat control cover. Unplug the refrigerator and open back of the freezer compartment to expose the evaporator coil. If covered with ice or frost this will be considered to be something wrong with defrost circuit. First we check timer, then element and then the defrost thermistat. Let me know what you find after you expose the evaoprator. Thanks, Sea Breeze
Apr 21, 2009 | Refrigerators
MATAG FRIG PTB2153GR FREEZER DOES NOT GET COLDER THAN 38 DEGREES F
Try turning the defrost timer clockwise until you hear it click. If defrost element and defrost thermostat are working properly, the refrigerator should begin to defrost. The timer is located inside the fresh food compartment behind plastic controls cover and also near the thermistat control.beb686d.jpg .I will be around if you need, just let me know,Sea Breeze
Mar 23, 2009 | Maytag Refrigerators
Compressor not starting
the thermostat is in the fridge and fridge runs at about +4-6degC. if temp in the garage is about that value, appliance will not want to turn on
Dec 01, 2008 | Amana DRB1901C Bottom Freezer Refrigerator
Open Questions:
Amana ABD2533DES Stainless Steel Bottom Freezer Refrigerator Logo
52 people viewed this question
Top Amana Refrigerators Experts
Marvin
Marvin
john h
Are you an Amana Refrigerator Expert? Answer questions, earn points and help others
