Televison & Video Logo
Tonya Lynn Edwards Posted on Nov 13, 2019
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I need the code book for a captive Works universal remote to program a TV HDMI and it is a i l o tv
Level 3:
Top Expert:
  • Universal Master 76,851 Answers
  • Posted on Nov 14, 2019
Universal Master
Level 3:
Top Expert:
Answers
76851
Questions
30
Helped
15006901
Points
237762
Set-up (Programming) procedure is too much to type in here, and is not practical and it will differ brand-to-brand remote controls. If you wish to get more; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls. One among it has general set-up codes to check with TVs and other devices are given, in the order of the 'device's brand name list' in alphabetical order. Pull up older posts. Search the sites by type in the brand name to your device in its search box at the top right part of the display window. It will help you to find the document easily.
https://homenol.blogspot.com/
https://remotesearch.blogspot.com/
https://electronicshelponline.blogspot.com/
https://electrohelponline.blogspot.com/
5 Related Answers
Anonymous
  • Posted on Dec 27, 2007
SOURCE: SYSTEMLINK 3 RCA UNIVERSAL REMOTE CODE 4 A MAGNOVOX TV
Code Lists:
http://www.thompsontv.com/rcarc.html
Anonymous
  • 2071 Answers
  • Posted on Sep 02, 2008
SOURCE: VIZIO REMOTE CODES
JUST TRY THIS PROCEDURE;
http://www.hifi-remote.com/ofa/codes-tv.shtml#tv
If none of the codes work then we have two other solutions:
1. Searching For Your Code
If you have tried all of the set-up codes for your brand of equipment ,or yourbrand is not listed, and you are still not able to get the unit to respond, trythe following procedure to search for your code.
If you don't find a code that works, the remote will flash four times when youreach the end of all the codes for this device type.
  1. PRESS the button for the device you want to program, (TV, VCR, CABLE, etc.), then RELEASE.
  2. PRESS and HOLD the SETUP button until the red LED flashes twice, then RELEASE.
  3. ENTER 9-9-1 (two blinks on the remote)
  4. ALTERNATE slowly between the POWER key and the DEVICE (TV, VCR, CABLE, etc.) button until your device turns off. (On VCR, LD, and CD players use PLAY instead of POWER)
    Make sure that the remote is pointed at your device during the search, You may have to press this sequences of buttons up to 100 times to search the entire library of codes.
  5. When your device turns OFF, PRESS the SETUP button and RELEASE it to lock in the code for your device.
2. Learn the buttons from the original
Line up your original remote and the head-to-head before completing thefollowing steps.
  1. PRESS and HOLD the SETUP button until the red LED flashes twice.
  2. PRESS 9 - 7 - 5, the red LED will flash twice.
  3. PRESS the DEVICE key where you wish to learn the function. The next 3 steps must be completed within 10 seconds.
  4. PRESS the button that will receive the learned function, the LED will flash rapidly.
  5. PRESS the button on the original remote to be learned.
Now you can repeat steps 3 through 5 to learn other functions onto other keysor press and hold SETUP until the Cinema's red light flashes twice to lock inyour new feature. (If the red light does not blink twice, stop and repeat stepsthrough 6).
To test the new feature, press and release the device key in which the newfeature was learned followed by the key on which the feature was learned
More help for programming your remote can be found here:
http://www.hifi-remote.com/manuals/ofa-l.shtml?URC-7800#device
Hope that helps! Should you have any further questions,please feel free to post them here.
Television Video - DVD Audio Satellite Set Top Box Video - VCR Brand: Model (optional): clip_image001.gifclip_image001.gifWe could not find an exact match, we think this code will work. 10054 clip_image001.gifclip_image001.gifSetup Instructions
· Set the "Mode Switch" to TV.
· Press and hold the "Mute" button and the "Select" button until the visible LED blinks twice.
· Enter the 5 digit Code above.
· Try your new code and tell us how it worked!
You'll have to settle for that, use the middle power key in the tv device to power on & off the tv.
hope this may help;
Regards,
VOTIT
DON'T FORGET TO RATE;
Anonymous
  • Posted on Dec 23, 2008
SOURCE: RCA universal remote modle #RCR311w need instructions and codes for LXI tv
http://remotefinder.rca.com/default.aspx?site=rca is the only place you have to go to. It works!
Anonymous
  • Posted on Nov 05, 2009
necesito codigos de control rca systemlink 3 para programar tv emerson y sylvanya,por favor ayudenme, gracias.
Anonymous
  • Posted on Jun 02, 2010
SOURCE: Need code to program universal remote for my Apex LCD TV
i have apex tv 2003 and i need a code for my remote
How to program a AVOL tv to a universal remote not in book
AVOL 4 digit codes:
2735 1820 3382 2051 2397 3118
AVOL 5 digit codes:
13118 13382 13479 12735 12051 12397 12278 11531
7helpful
Need code 4 ge universal remote? 24911 4 ge tv
i need my code for my tv. The brand of my tv is Magnavox. I also need the steps to program the remote because I lost my book
2helpful
2answers
Program the RCA#rcr312 universal remote control
hold the code search buttton until light comes on then select the device you are programing and enter code
I need a code to make my remote work my tv
i have a rca tv and a magnavox universal remote and i need codes to program
2helpful
2answers
I need codes for philips universal remote control
lost manual tring to hook up dvd/vcr emerson up need code
37helpful
14answers
4helpful
2answers
Sylvania 6313CB 13" TV/VCR replacemnt remote
We have a Sylvania 6313CB TV/VCR combo.  I bought a universal remote and the code would not work when I tried to program it to the "TV" button using all those possible codes listed in the books.  So, on the universal remote, there was a button named "VCR" and when I programmed in the code "0000" all worked.  This was a $6.00 universal remote named "One For All"  we bought at the Big Lots store.
Specifically, here is what I did:
Turned TV on Pushed the "VCR" button and light blinked once Pushed and held the "set" button until it blinked twice Released the "set" button and entered the numbers "0000" Pushed the on/off button and it worked including volume, channel up/down and channel change by entering the channel number.
Hope this works for you too.
3answers
In need of tv codes for ge romote control
You don't need a code. Just follow the instruction as follows:
1. Tun on TV
2. Press and hold "code search" until light stays on, then release.
3. Press TV botton
4. Press on-off repeatedly until TV turns off
5. Press enter.
That is it. It works for me.
Top Universal Televison & Video Experts
vince
Jennifer Rock
Jennifer Rock
Are you an Universal Televison and Video Expert? Answer questions, earn points and help others
