Question about Lands Phones
My phone wont let me make calls just constant dial tone
Posted by Susan Collaire on
5 Related Answers
Anonymous
  • 12 Answers
SOURCE: Uniden cordless phone. No dial tone.
Hi peddler65, did you plug your phone into another area to see if there is a dial tone. Then if not call the phone company or find the D-mark (where your dial tone ) comes into your home and put a jack on that and plug a phone in with all phones in the house unplugged.
Thanks.
Posted on Nov 15, 2008
Anonymous
SOURCE: Dial Tone but won't call out.
I just had the same problem. Try unplugging the plug from the electrical outlet for the home(base) unit and plugging back in. Fixed my problem right away.
Posted on Jan 06, 2009
Anonymous
The problem was the main phone line not the phone itself
Posted on Jan 08, 2009
Anonymous
  • 40 Answers
SOURCE: Modem connects to internet but I have no dial tone to make calls
I have personally seen this issue before and with an Arris cable modem the issue you are having means that there is a over current issue with your phone line. What this means is that your phones are either getting to much or to little voltage. Usually this is caused by a crossed phone wire/staple through a phone line or possibly corrosion on your line. The first step into troubleshooting this would be to check where your phone lines tie together at and make sure nothing has come loose or broken. Also if you any of your lines run outside to a phone box go in the customer side of that and check to make sure there is no corrosion. This can also be caused by a phone going bad. Go around and unplug your phone lines 1 at a time from the phone line and see if it starts responding correctly. You made need to power cycle/reset your modem when you do this to clear the error. The final way that you can tell if it is in your phone line or not is to unplug the modem from your house line and plug a phone straight into the modem. This should make at least that one phone start working correctly.
Posted on Apr 09, 2009
Anonymous
SOURCE: I pick the phone up, no dial tone. Display says
We called the phone company.....There was a problem up on the telephone pole. They fixed it, no charge.
Posted on Jan 25, 2010
Dial tone wont call out
call your service provider i had same problem they fixed it
Jun 03, 2013 | Saws
My phone doesn't have dial tone. Each time I dial a number and try to call,it wont work. I call my phone but it wont ring. I need help on this. What happen to the phone? Or what should I do?
If you have another phone connect it to the wall outlet to see if you get a dial tone. This will indicate if your base unit is faulty.
Check the power adapter to the base unit, make sure it is getting mains power.
If the base unit has dual phone lines and if line 1 is only connected and the line 2 has beed selected then you cannot get a dial tone. In the chase press the line 1 to get a dial tone.
If your base unit has only one line then check the phone line at the wall socket make sure it is plugged in tight, also check the the connection at the base unit.
If this does not work then ring the phone company and get the to test your phone line, you may have a faulty line to your home.
Feb 03, 2012 | AT&T E2116 2.4 GHz Cordless Phone
Call forward will not turn off, have tried *74 & *73 , have rebooted and turned off then on, call divert symbol still on and phone calls still diverted.
To set Unconditional Call Forward ON Dial "*72" for a dial tone. Dial the forwarding number followed by "#". Wait for dial tone. LCD will display "Call FWD Activated"
To Cancel Unconditional Call Forward: dial "*73" and get the dial tone, then hang up. LCD will display "Call FWD Activated
but, since you have tried those two, it could be that there might still be a different type of call forward option that is still ON, on your phone like Busy Call Forward and Delayed Call Forward 1. To Cancel Busy Call Forward: dial "*91". Wait for dial tone. Hang up.
2.To Cancel Delayed Call Forward: Dial "*93" for a dial tone, then hang up.
Let me provide you a link to the website which I used as a reference for your future reference.
http://www.grandstream.com/user_manuals/GXP_User_Manual.pdf
Apr 27, 2011 | Grandstream GXP-2000 IP Phone
I cannot get a dial tone. I press the talk button to dial out. After 3 quick short beats a message appears in the display window " can't connect ". The phone rings when in coming calls come, but...
Which make and model of phone is it?
Are you pressing the green call button beforew you try to enter the number you are calling?
You should enter the number first, then press 'green'
You wont hear a dial-tone like a landline phone
Feb 23, 2011 | Cell Phones
No dial tone
plug out the fax... plug in a phone... if still no dialtone... replace phone cable... still no dial tone... call the phone company...
plug out the fax... plug in phone... dial tone heard... bad fax... try to reset fax machine... per instructions... still no dial tone... call repair guy...
I’m happy to assist further over the phone at https://www.6ya.com/expert/norman_d2fa496dce30c65d
Dec 18, 2009 | Office Equipment & Supplies
None of our faxes are going out and we receive error number 87
set the fax so you can hear dial tone... if no dial tone then check the fax line.... if fax line plugged in... plug it out of the fax and plug into a phone... if still no dial tone then change fax cable... if dial tone... then call your cell... if static... fax wont work call phone company... if you get a funny signal call phone company...
Dec 10, 2009 | Office Equipment & Supplies
Cannot receive calls and dial tone flashing
You have a feature active on your phone it's more than likely a call forward feature which would redirect you calls. The broken dial tone or stutter dial tone is an indicator a feature is active. Contact you system admin for the clear all feature code and the clear all call forwarding codes.
Feb 26, 2009 | Mitel 5220 IP Phone
Can't dial out or receive calls
constant dial tone and cant dial out or receive calls
Feb 24, 2009 | Uniden Cordless Phone
Home phone
my phone has a dial tone but wont dial out or recieve calls.
Sep 23, 2008 | Motorola Mobility AT&T Prepaid Free2Go...
Lands Phones Logo
117 people viewed this question
Top Lands Phones Experts
Marvin
Marvin
k24674
Are you a Lands Phone Expert? Answer questions, earn points and help others
