Question about Samsung Office Equipment & Supplies
Changing the Display Language and Country
Setting Language
To change the language that displays on the control panel,
follow these steps:
1 Press Menu until "Machine Setup" appears on the top line
of the display.
2 Press the scroll button ( or ) until "Language" appears
on the bottom line of the display.
3 Press Enter. The current setting appears on the bottom
4 Press the scroll button ( or ) until the language you
want appears on the display.
5 Press Enter to save the selection.
6 To return to Standby mode, press Stop/Clear.
Setting Country
of the display.
2 Press the scroll button ( or ) until "Select Country"
appears on the bottom line of the display.
4 Press the scroll button ( or ) until your country appears
on the display.
NOTE: Changing the country clears the memory.
Link to manual
http://h10032.www1.hp.com/ctg/Manual/c05786751
Posted on Nov 13, 2019
SOURCE: Problems with Samsung SCX-4216F All-In-One Laser Printer?
SCX-4216F could receive fax, but didn't print out faxes. Can anybody help me with this?
Posted on Mar 11, 2009
SOURCE: A student has reset the menu to Russian.
My company uses nothing but HP printers some are connected to the
network while others are locally connected to a computer. I have worked
with this exact model.
First, the easiest thing to try is to power cycle the printer. Hold
down the button to turn off then turn back on. You can also unplug it
from its power source then plug back in.
Power cycling this printer should reset the language to default
(English) or it will let you select the language when it comes back
on. If that doesn't work then you can try to change it using the
installed software.
Considering the fact that someone accidentally changed the language, I
am assuming this printer is connected directly to a computer that you
all have access to and this is not a network printer.
If this is a local printer (connected directly to the computer via USB
or parrallel port) then you should have an HP Toolbox app or some other
program that allows you to configure software related settings for the
device. Open this tool and you should find an option for the language.
This may not be available, depending on how the installation was
handled (if it was installed using the CD provided by the manufacturer
or installed using downloaded drivers).
Try this out and let me know if it helps.
Posted on Mar 26, 2009
SOURCE: Samsung SCX-5421F Laster Printer crashes my pc
Have you tried uninstalling and re-installing the software. Perhaps there is an updated driver for your system since you first installed it, or maybe yours is simply corrupted. I would suggest removing and reinstalling will solve the problem - if, in fact, that is your problem -I've not heard of this happening before.
Drivers are here if you need them:
http://www.samsung.com/ca/support/download/supportDown.do?group=printermultifunction&type=printermultifunction&subtype=monochromemultifunction&model_nm=SCX-4521F&disp_nm=SCX-4521F&language=&cate_type=all&dType=D&mType=DR&vType=&prd_ia_cd=06010300&model_cd=&menu=download
Posted on Apr 14, 2009
SOURCE: Printer Samsung sCX-4521f CRU Fuse Error
Posted on May 29, 2010
May 08, 2014 | Iris USA I.R.I.S Readiris Pro 14 PC ESD -...
Feb 13, 2014 | Samsung SyncMaster 731B 17" LCD Monitor
May 25, 2012 | Samsung SCX-4216F All-In-One Laser Printer
Jan 13, 2011 | Samsung SCX-4828FN All-In-One Laser...
Sep 04, 2009 | Samsung SGH-i900 Omnia Unlocked Cellular...
Aug 14, 2009 | Samsung Office Equipment & Supplies
Mar 21, 2009 | Samsung SCX-4300 Monochrome Laser...
Nov 25, 2008 | Samsung SCX-4216F All-In-One Laser Printer
Nov 13, 2008 | Samsung SCX-4216F All-In-One Laser Printer
Jan 21, 2008 | Samsung SCX 4521F All-In-One Laser Printer
Setting Language
follow these steps:
1 Press Menu until “Machine Setup” appears on the top line
of the display.
2 Press the scroll button ( or ) until “Language” appears
Setting Country
of the display.
2 Press the scroll button ( or ) until “Select Country”
on the display.
Link to manualhttp://h10032.www1.hp.com/ctg/Manual/c05...
