Question about Cutter Tools
With the cheapest multimeters costing as little as just a few dollars there is no reason not to have the ability to check things instead of guessing.
With most portable tools and appliances the first thing to check is the power cord because around 60% of the time an internal break is the cause of a tool not starting.
Power tools and appliances often have electronics to provide variable speed or soft start. Checking these is beyond the scope of the home repairer but a multimeter can check continuity to any electronic component and from it to the motor and the ensure there is continuity through the motor.
If everything else is ok the fault is probably with the electronics if there is any. If you are feeling really brave, the final test is to temporarily and safely bypass the suspected component and apply power.
Posted on Aug 10, 2020
SOURCE: Need a user manual for mastercraft thickness planer
I'd suggest calling 1-800-689-9928 and speaking with one of the customer service representatives
Posted on Dec 15, 2008
SOURCE: my 13 inch delta planer will not feed the stock
I have a 12" Portable Planer Delta Model 22-540 - Planer will not feed the stock.
Posted on Mar 10, 2010
SOURCE: My delta bench top thickness
I have seen various problems with delta planers related to motor humm /not starting. Easy to check. Remove the belt from motor pulley to isolate the motor. The motor should turn freely. If motor turns freely turn on planer and motor should start with a powerful force. If motor will not start and turns very slowly or not at all and humms, most likely capacitor or motor damaged. Test capacitor with meter to with-in + or - 5 percent or mfd rating (if you do not have a meter with capacitor test setting, take to motor shop for free test or replace if capacitor looks burned or leaking oil). You can use generic capacitor with same mfd rating and same or higher volt rating(higher voltage rating is better but the capacitor may be larger and not fit in space allowed). If motor is ok, then suspect debris in system or bearing or bearings at the end of the shafts have failed. With power plug removed from outlet and belt off motor pulley, turn shafts by hand or with belt. Should be fairly easy to turn and feel smooth. If stiff, could be debris or bearing (replace all four bearings). Clean system or use generic bearing. Order by using the number on side of bearing.
Posted on Aug 03, 2011
SOURCE: (2007) Frigidaire Affinity Gas Dryer won't shut off
mybe the star button stay stuck and the dryer tinks some one is puching the star button and it will continio to run. try to open the door and it will stop and then clouse the door if the dryer star whitout pushing the star then you now the star switch is stuck. goo lock
Posted on Feb 22, 2012
SOURCE: Rexon planer parts
I found the following on the net Try them if you haven't already done so
Contact Details
Web: www.rexonspares.co.uk
Phone: 01709 876611
Fax: 01709 876811
Email: [email protected]
[email protected]
Posted on Apr 25, 2013
