I believe there is a component overheating? I had TV in my garage for a few hours, at about 40 degrees. TV ran fine for 20-30 minutes before picture dropped and horizontal lines appeared. I have pictures if it helps.
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Line, faults & possible causes to LCD screen are given with illustrations. You can get an idea about the fault to an extent.
SOURCE: Horizontal White Line
In your statement i found during switch on you get picture. Check whether in a few minute picture suddenly goes to the horizontal line or height reduces and then goes to line. If suddenly goes means change any zener diode in pumpup circuit. If it is not means LA 7840 ic getting imbalanced supply voltage i.e.,negative and positive voltage are not equal. Suppose only one vcc means supply resister getting high ohms and change the the supply resister.
SOURCE: Color line across the center of a black screen
Hi. this is caused by dry solder joints on the frame o/p IC. Resolder all legs of frame chip. Should sort that out.
SOURCE: Flicker-Blinking on picture
Too late now but I hope you had it serviced while it was still on parts warranty. With a couple of exceptions, service on those is by major pcb replacement.
SOURCE: Intense white & coloured horizontal line on black background on startup
I wouldn't attempt as the capacitors on a tv store around 25000 volts this is more than enough to kill you and they keep there charge even when the tv is off. Either take it to a repair shop or put that money towards buying a new tv - Do not even attempt to open the tv. (It sounds like maybe a tube has gone or the electromagnet that makes the beam move vertically is gone.
SOURCE: 40 samsung lcd picture problem
first check the power supply board for puffy capacitors. then change the t-con board on lcd panel
