Question about Uniden Lands Phones
A completely dead cordless Uniden phone
No dial tone, will not receive incoming calls
Posted by Barbara Atkins on
5 Related Answers
Anonymous
SOURCE: UNIDEN 5.8 GHZ CORDLESS PHONES
Registering Handsets to the Base
Whichever handset you choose to charge in the base is automatically
registered to the base. Any additional handsets must also be registered to
the base before you can use them.
Be sure both handsets are fully charged.
One at a time, place each handset in the base. The charge/in use LED on
the base begins to flash, indicating the base is registering the handset.
Wait for at least five seconds, then pick up the handset and press
[talk/flash]. If the display shows TALK, the handset is registered. If not,
place the handset in the base to try again.
Press [end] and continue with the next handset.
Note:
Once both handsets are registered, it doesn’t matter which
handset is placed in the base or the charger.
When you charge the handsets, Caller
ID summary screen and the name of
the handset appears.
This can be find from uniden website.
http://www.uniden.com/pdf/DXAI4588-2om.pdf
Posted on Jul 08, 2008
Anonymous
  • 12 Answers
SOURCE: Uniden cordless phone. No dial tone.
Hi peddler65, did you plug your phone into another area to see if there is a dial tone. Then if not call the phone company or find the D-mark (where your dial tone ) comes into your home and put a jack on that and plug a phone in with all phones in the house unplugged.
Thanks.
Posted on Nov 15, 2008
funkyjacob
Jacob McNamara
  • 76 Answers
SOURCE: No dial tone on handset
It may not be registed with the main unit. You may need to register the handset. With my uniden all i have to do is put it in the main base until it says what handset it is (it should be a number).
If you have any questions please dont hesitate to ask
Posted on Dec 02, 2008
Anonymous
SOURCE: Dial Tone but won't call out.
The problem was the main phone line not the phone itself
Posted on Jan 08, 2009
Anonymous
  • 39 Answers
SOURCE: uniden 5.8Ghz phone.
You need to reset the main base unit. Unplug the power from the back of the base. While the power is disconnected, press and hold the delete key while reconnecting the power. Wait for a long beep tone. When the display shows 88 or P, press play button one time. If you have a phone without an answering machine, disconnect the power from the back of the base, press and hold find hs button while reconnecting power.
Posted on Mar 17, 2009
My Uniden handset is not working. No dial tone. Just a long continuous beep. Unable to ring out or receive incoming calls. How can I troubleshoot this problem.
open line if have more than one phone plugged into a jack unplug one at a time and check dial tone if no change have phone company check incoming line
Jun 01, 2018 | Uniden Lands Phones
GE 900 Mgz cordless phone, model 26936GE2-C
How many handsets do you have on this system? Just the one for the base unit?
May 21, 2008 | Uniden Cordless Phone
No dial tone phone jack tested ok phone rings incoming call when you pic up nobody. changed battery still no dial tone or conection on incoming call
This is caused by a failed wireless signal transmitter in the base station or a failed wireless receiver in the handset, these phones are not repaired unless they are under warranty, so all you can do is replace it, this is the #1 PROBLEM WITH ALL CORDLESS PHONES.
Mar 22, 2011 | Clarity C410 Cordless Phone
Cannot get dial tone to make a call ane cannot receive an incomming call.o
Double check your wire from the wall to your base set.
Is it possible you have something 'off hook' and the phone company has turned the dial tone off? Look in the front of your telephone book for the procedure to check the service to the "De-Mark"
I hope this helps you
a
Sep 27, 2009 | Panasonic KX-TG1033S Cordless Phone
Mitel 5212 no dial tone and goes straight to voicemail
Not too sure about the no dial tone issue, but you can check to see if the DND is turned on...
Press the Blue Superkey and scroll thru till you see DND (Do Not Disturb) is on and shut it off.
Jul 20, 2009 | Mitel 5212 IP Phone
Can't dial out or receive calls
constant dial tone and cant dial out or receive calls
Feb 24, 2009 | Uniden Cordless Phone
Cordless receivers not working
If you have tried the phone base unit in the same jack that works correctly with your answering machine and you still cannot break dial tone, then you have a defective base unit. Jer
May 09, 2007 | GE 25831GE3 Cordless Phone
Incoming telephone calls
Refer to your manual. It may be under RX(recieve settings). Go disable FAX/Tel SW and make sure it is fax mode only
Jan 11, 2007 | Canon FAX-B820 Plain Paper Bubblejet
Lands Phones Logo
110 people viewed this question
Top Uniden Lands Phones Experts
k24674
Marvin
Marvin
Are you an Uniden Lands Phone Expert? Answer questions, earn points and help others
