Washing Machines Logo
E01 error in onix washing machine. What we need to do
Posted by balu_rajaram on
Anonymous
    New Friend:
I use a spatula to stick between the door and machine to push the lever open.....
Posted on Mar 03, 2010
Anonymous
    New Friend:
I have an Onix 3011 and the door will not open after the end of the cycle. Can anyone give me any idea how to open the door.
Posted on Feb 04, 2010
  • Anonymous Aug 20, 2012
    My manual says wait 1 minute after the cycle, try turning it off and then try to open the door, if this doesn't work the spring lever has become loose like mine you will need to unscrew the door to reach the lever but be careful I've done it and found my spring and lever where out of place and now I don't know how to put it back in properly to make the spring work properly.
Braun. e01 code what doesn't mean
If your unit is displaying E01, E02, or E03 error codes , unit needs to be repaired, please contact our Braun call center at 1 (888) 977-3578.  Our representatives are available: 9:00 am – 8:00 pm (ET) Monday through Friday and Saturday 9:00 am – 5:00 pm (ET)
What is causing error codes F06 E01?
This error message means an electronic communications problem. Press pause/cancel twice to cancel the error and then disconnect the power cord from the outlet, wait few minutes, plug the power cord back in and select a new wash cycle.
If you see the same error again then you need to check the connections located between the drive motor and motor control unit.
How to start a diagnosis test on Bosch dishwasher model SHE3ARF6UC/21 will not start because of E01 code
Error code E01 means that your Bosch dishwasher is experiencing trouble with the motor.
2answers
Fix error code E01 on smeg wd1 16ba washing machine
Possible leak is what that code means. Check for leaks.
What do error codes e06 and e01 mean?
E01 and e06 codes - Fixya
www.fixya.com/support/t14040885-e01_e06_codes
Aug 19, 2012 - e01 and e06 codes washer will not do anything other than lock the door. - Whirlpool Duet: WFW94HEXW Laundry : question. ... Error message E06 onWhirlpool. Unplug the machine and wait 10 minutes before restarting it.
Bosch vision error code E01 on washer
error code e01 means the computer thinks the door is open even when it's closed you can repair this using this guide:
Bosch Front Load Washer Error E01
Top Washing Machines Experts
Marvin
Marvin
W.L.
