Process Control Error This SC is issued if the process control adjustment fails 5 times consecutively after AIO replacement. • Defective contact at the terminal between the machine and AIO. • Dirty TM sensor 1. Check the contact of the terminal and re-install the AIO. 2. Clean the TM sensor.
Most AIO remotes have a scan function that will find upto 80% of all TVs and DVDs set this mode up on you AIO and you will be surpised how easy it is to find an alternative code using this method.
if using vista try this: Right-click on the Home Center icon. Select Properties. Select the Compatibility tab. Click Run this program as administrator. Click OK. reply if does not work.........
Have you enabled the wireless radio at the control panel of the AIO (all-in-one)? It isn't enabled by default. It must be turned on at the control device's control panel.
If you haven't done so already, please, do this and let us know the results.
If you have already followed the manufacturer's instructions for enabling your AIO's wireless radio, please, tell us in detail what other steps you've taken so far in attempts to fix this problem.
If you'd like we can locate the instructions for setting up wireless connectivity w/ your AIO. We will need the model number of the device in that case. Just post back w/ that information and we'll be happy to get that for you.
I needed to reload my AiO Home Center software and no one seemed to have the correct procedure. Maybe if you remove & reinstall yours it will resolve your problem. This procedure worked for me on my XP-machine: 1. got to Control Panel/Printers&Faxes and delete the printer 2. go to your Hardware/Device Manager/Universal Serial Bus Controllers, right-click on USB Composite Device and select Uninstall 3. go to Control Panel/Add/Remove Software and remove the EasyShare software 4. disconnect the cables from the Printer 5. download from Kodak.com the program "install_aio.exe"; run the program (I selected only AiO+EasyShare+Software Updater to load) 6. followed the prompts after the sw installed to reconnect the Printer cables 7. rebooted
