Question about Apple iPhone Smartphone
Can you block a phone number on your phone - Apple iPhone Smartphone
Posted by kwelsh58 on
Michael Lei
    Master:
  • Apple Master
  • 498 Answers
This works really well for blocking phone number on iPhone, like phone numbers from some unknown spammers, advertising companies and internet marketers bothering you with promotions and offers for products that are not at all related to your interest. These steps will block only those unknown callers that you choose to block. The detailed steps are as follows:
1. Go to the Messages app.
2. Tap on the target message from the spammer.
3. Choose "Details" on the top right hand corner and tap on it.
4. There will be phone icon and a letter "i" icon across from the number. Tap on the "i" icon.
5. Scroll down to the bottom of the page and then tap on "Block Contact".
Note: Once you press on Block Contact, the phone number that you just blocked won't be able to make phone calls, send text messages, or Facetime you.
For more methods, check: How to Block A Number on iPhone
Posted on Jul 10, 2019
How do I block the number of a nuisance caller?
Android:
  • From the call log, you can disable incoming calls from specific numbers.
  • Select the number you want to block, then hit More or the 3-dot menu icon in the upper right corner and choose to Add to reject list.
  • This will disable incoming calls from specific numbers.
iPhone:
  1. To block someone already added to your iPhone's Contacts, go to Settings > Phone > Call Blocking and Identification > Block Contact.
  2. To block a number that isn't saved as a contact in your phone, go to the Phone app > Recents.
  3. Click the exclamation mark next to the number.
  4. Scroll to the bottom and select Block this Caller.
The video for Android:
The video for iPhone (couldn't find a more updated vid):
And, finally, here's the source article for Android: Block Numbers And Texts ' Block Someone On Android
For iOS: https://www.popsugar.com/tech/How-Block-Number-iPhone-31863584
Mar 03, 2018 | Cell Phones
Can you block a phone number on a Doro 6520 cellphone
Yes you can
How to block a phone number on Doro 6520 - Phone-Info
https://phones.brain-start.tech/block-phone-number/how-to-block-a-phone-number-o...
Aug 12, 2017 - Because you have an Doro 6520, you can also block text messages from a phone number. First, open the application "Messages" and then press the menu button located at the top left of your Doro 6520. Then you will see a list and you will need to press "Settings". Then click "More". You will have access to ... People also ask How do you block a number from your phone?
How do you block a number on a consumer cellular phone?
How do you block a phone number on an LG flip phone?
How do you block a number on a ZTE phone?
Feedback
How to put or remove a blacklist contact on yo ur Doro 6520 - Phone-Info
https://phones.brain-start.tech/.../how-to-put-or-remove-a-blacklist-contact-on-yo-ur-d... Jul 17, 2017 - To actually add the number to the blacklist on your Doro 6520, simply go to the contact containing the number in question, click on the 'menu' key of your Doro 6520, and select the 'block this contact' option or 'add it to the blacklist'. That's it, your contact is now added to the blacklist of your Doro 6520.
Doro 6520 - Turn call barring on or off
https://userguide.vodafone.co.nz/doro/6520...os/calls.../turn-call-barring-on-or-off/ Turn call barring on or off. You can block certain types of calls such as incoming calls when you're abroad. Key in your barring password and press the Navigation key. The default barring password is 0000.
Feb 20, 2018 | Cell Phones
How to block numbers
To block calls, open the Phone app, select Call History, tap the number, then select Block Contact or BlockCaller. To block calls, open the Phone app, select Menu > Settings > Call Reject > Reject Calls From and add numbers. To block calls for numbers that have called you, go to the Phone app and open the Log.26 Sep 2016
How to Block a Number on Any Phone ' PCMag.com..
or go to this link for other phones. How to block numbers Google Search
Oct 28, 2017 | Cell Phones
How do you block a cell number of iphone 4
You can block any number on your iPhone by just installing an app called "iBlacklist"
There you have many options, and with them there's an option of blocking a cellphone number.
You go to Blacklists - General BL. There you have '+' in upper right corner. From there you can add the number you want from contacts, recent calls and messages or write it yourself.
Jan 28, 2013 | Apple iPhone 4S
How to block a cell no
In the app you have many options, and with them there's an option of blocking a cellphone number.
Jan 28, 2013 | Apple iPhone 3G
Blocking nuisance mobile phone number
Can no be done. Iphone doesn't have a 'black list' for phone numbers
Nov 06, 2011 | Apple iPhone 3G
No manual and am receiving unwanted calls at night just became threatening how do i block them
Using Call Block
If you subscribe to Caller ID, you can save phone numbers to the call block list. When a call comes in, the phone compares the received phone number to the numbers on the call block list. If the phone number is on the list, the phone replaces the caller's name with Call Blocked and disconnects the call. (The caller hears a reject tone.)
The call block list holds 20 entries, and all stations share the same list. You can add entries through the Call Blocking menu, by selecting Add Call Block in the CID menu, or by blocking incoming calls. (Only one station can edit the call block list at a time.)
Blocking incoming calls
  1. When the phone rings, wait until the display shows the Caller ID information (usually after the second ring).
  2. If you want to block the call and add this number to the call block list, press Block.
  3. When the phone asks you to confirm, press Menu/select or Block. Blocking an incoming call from an "Unknown" or "Private" number is the same as selecting Unknown Number or Private Number from the Call Blocking menu.
Call Blocking menu options
  1. With the phone in standby, open the menu and select Call Blocking.
  2. Choose one of these options:
  • Create New(Handset only) - Add an entry to your call block list. The phone will prompt you to enter a name & phone number.
  • Private Number(Handset only) - Block all calls from numbers reported by CID as "Private." (This does not count as one of the 20 entries.)
  • Unknown Number(Handset only) - Block all calls from numbers reported by CID as "Unknown". (This does not count as one of the 20 entries.)
Call block entry options
  1. With the phone in standby, open the call block list and find the entry you want.
  2. Press Menu/select to open the individual entry menu. Choose one of these options:
  • Edit(Handset only) - Edit this entry. The phone will prompt you to edit the name & phone number.
  • Delete - Erase this entry from the list & allow calls from this number.
I’m happy to help further over the phone at https://www.6ya.com/expert/jeremy_69f3cc28d95bf514
Mar 20, 2011 | Uniden DECT21883 Trio Cordless Phone
Blocking a phone number
if you want to block your own number dial *67 before you dial... to block someone else try dialing
To activate Call Block or add a telephone number to the rejection list, dial *60. If you dont know the number to be blocked, dial *60 immediately after hanging up from the call. To turn off Call Block, dial *80. Call Block cannot block calls from some cellular phones, pay phones or business lines. It also cannot block most long distance numbers.
hope this helps...please rate...thanks
Jan 13, 2009 | Uniden Cordless Phone
Blocking numbers on cell phone
Unfortunately, Sprint does not have the ability to block single numbers from calling you. We can either block all incoming calls, all outgoing calls, or both, but not particular numbers.
Jun 30, 2008 | Sprint PCS Phone SCP-2400 by Sanyo(r)...
Apple iPhone Smartphone Logo
165 people viewed this question
Top Apple Cell Phones Experts
Ekse
Marvin
Marvin
sandyp4ever
sandyp4ever
Level 1 Expert
Are you an Apple Cell Phone Expert? Answer questions, earn points and help others
