How do you use Air Dry function - Heating & Cooling
Posted by Drummond on
Paul G
    Scholar:
  • 161 Answers
Air dry is a function designed for high humidity countries.
It works much the same as cooling mode only it will run the cooling a lot longer.
I recommend not using it and just use the cooling cycle at a reasonable temperature setting.
Posted on Nov 15, 2019
Dry mode
its function to reduce the humidity
Jun 24, 2010 | Goldstar WG8000 Air Conditioner
What is the dry function for on the remote control?
This is used in very humid conditions to dry out the air in a room. Specifically if you are near the coast.
Nov 14, 2009 | Fujitsu 24C1 Air Conditioner
Will not dry
Does it get hot?
Dryers have 3 functions to perform:
Tumbling
Air flow
Controlled heat
Test for each, and fix the one that is not functioning. Remove vent tube to test for air flow.
Nov 05, 2009 | Maytag Atlantis MDG7400AW Gas Dryer
Dryer works but doesn't get clothes dry. They're
Sounds like inadequate air flow through the machine. In order for the any dryer to function air is forced through the machine and outside. If the discharge is blocked or obstructed in any way the moist air will not be removed, and the clothes will not dry.
Disconnect dryer from wall and clean the wall outlet and and dryer discharge pipe.
Also, if you are trying to force air higher than 6 feet up the wall from a basement you will need a booster fan on the piping.
Sep 15, 2009 | Whirlpool LGR5636L Gas Dryer
What does the "dry" mode function do on the Goldstar GWHD6507R window air conditioner unit? There are also "cool" and "fan" modes, but the "dry" mode is mysterious. Is it some kind of dehumidifier...
Your AC removes humidity and cools the air, in Dry Mode it cools the air but does not remove the humidity as much, which is OK in a desert (Las Vegas, Arizona, etc.) but not good for caribbean with the high humidity
Sep 01, 2009 | Goldstar Heating & Cooling
What is the function of dry mode in ac, when to use dry mode, and when to use cool mode and what about heat mode.
Dry Mode in AC is to dehumidify the room the fan cycles on and off and the indoor unit temperature drops below freezing which causes condensate to collect on the coil and as a result the humidity level of the indoor air is reduced
Jul 13, 2009 | LG L1204R Air Conditioner
What is the Dry setting on air conditioner?
Hi, I know this question's been up a while and I'm not sure if you care anymore but here goes anyway.
Most air conditioners are reverse cycle, so they can heat the air in your house or cool it down. What we are concerned with is the cooling side of things. So in this mode a working liquid is sprayed into the evaporator and cools its immediate surroundings. air is blown over the evaporator which cools the air. The local temperature around the evaporator is very cold, (how cold exactly I'm not sure) so the air in this region has a very poor ability to hold water and so (especially on a humid day) water condenses out of this air on the surface of the evaporator, is collected and drained away. The cooling function and dry function both use the "cooling" mechanism of the air conditioner. Both extract water from the air in this way but the primary purpose of the cooling function is to cool the air whereas the primary function of the dry setting is to dry the air... obvious I know.
Now in the dry setting the compressor will run with fan going at I imagine a relatively slow speed to chill and extract as much water from the air as possible and to minimise circulation. After a short time the compressor and fan will cut-out and then after a short interval start up again (I'm not really sure but I assume this is either controlled by a humidity sensor OR the temperature sensor monitors for a small change in temperature and shuts off the compressor and fan when it detects this). Now in cooling mode (depending on what temperature is set) the compressor will run for longer and more frequently and therefore remove more water. So why have a dry mode if cooling mode removes more water?... Well that really has the same answer as the question "when do I use dry mode?"
Well on a particular day where the temperature would normally be considered comfortable but on this day it is unusually humid, your body will find it difficult to radiate heat via sweat because of the already high RH (relative humidity) making you uncomfortable and feel "hot". Using dry mode will reduce this RH without adjusting the temperature by much, but you will perceive an ambient temperature drop due to your body being able to discard heat more easily... hence making you more "comfortable" in same way you would normally feel at that temperature.
On the contrary if you were to use cooling mode (which is regulated by temperature) you would have to set a temperature lower than ambient so that the compressor will "kick-in" rather than the air conditioner just running its fan...agree? So that means the air conditioner will reduce RH (which we want) giving you a perceived temp drop but it is also chasing the temperature which you set which will give a REAL temperature drop. So anyway the point is; if it was an unusually humid day on what would otherwise be a comfortable temperature, using cooling (remember the temp has to be set lower than ambient) instead of dry would result in you feeling cold very quickly due to the perceived AND real temperature drop.
So really the dry setting is for days which aren't too hot, but are humid.
I think my logic makes sense.
cheers Matt
May 30, 2008 | LG L1204R Air Conditioner
Heating & Cooling Logo
106 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Marvin
Marvin
