Question about Home
SOURCE: Portable DVD player battery won't hold a charge
chuck it in da fkn bin
Posted on Jul 24, 2008
SOURCE: battery compartment
Hi
On the 205W the serial no. is on the bottom of the unit, inside an outlined box. Make sure to remove the mounting bracket to be able to view it.
You do not go into the battery compartment.
If this answer has helped please do leave a helpful vote for it.
Thanks.
Posted on Feb 01, 2010
SOURCE: changed battery and now pendulum wont swing
Give the pendulum a shove and do it every time you pass the clock. I got mine going from swinging for just 20 seconds to working permanently, at least until the next battery change.
Posted on Apr 15, 2010
SOURCE: we have a seth thomas
The clock must be levelled the same as when it was previously set up. In other words, if you didn't check the level of the clock before disassembly and reassembled it and re-levelled it, it may not operate because it might not be the same.
Some clocks have different weights for the clock, chime, and hour strike. Did you mark them and install them in the same location?
My Seth Thomas has a screw to adjust the swing of the pendulum to allow proper escapement on the gear, but you have to be able to determine which way the pendulum needs to swing more to make that adjustment. I may be able to help you with this!
You may need a clock repair service.
Let me know,
Gary
Posted on May 29, 2011
May 03, 2016 | Home
Feb 08, 2016 | Audubon Society Audubon Singing Bird Clock
Apr 27, 2014 | Home
Jan 01, 2011 | Watches
Apr 21, 2010 | Watches
Jul 13, 2009 | Watches
Jul 07, 2009 | Howard Miller 645-627 Clock Radio
Mar 18, 2017 | Home
107 people viewed this question
