Shut off power to dishwasher at electric panel,shut off water supply,open door of dishwasher,remove screws on top side of dishwasher that are screwed into the underside of the countertop,,remove the front service panel on the bottom front face of the appliance by removing two or more screws on the right and left,locate and disconnect the water supply feed,locate and disconnect the electricity supply cable,locate and disconnect the drain hose usually connected to the drain of a nearby sink,pull dishwasher out of cavity in cabinet by grasping both sides of dishwasher with door slightly open,adjustment of front legs of appliance may be necessary.
SOURCE: Soap dispenser cover won't close
It sounds like it may be stuck between cycle steps.(this sometimes happens if the washer is open during a cycle)Try and run it through one full wash cycle as it is.Then check to see if the soap door will close.If not,the lack may be broken
SOURCE: Potscrubber 900 Dishwasher won't drain
HI. check the following areas for faults.
1. Air gap / Drain hoses
If there is an air gap (located in the sink, near the faucet), check to see if it is clogged. Unscrew the top cap and see if there is anything blocking inside. Note: If there is no air gap installed, the dishwasher might not drain properly.
If the drain hose is clogged, the dishwasher would not drain. If there is an air gap installed, it is very common that a hose going from the air gap into the garbage disposer is clogged. Remove and clean the hose. Make sure to reattach the hose before starting the dishwasher.
Note: If you recently had a garbage disposer installed, it is common to overlook removing the drain plug.
2. Broken belt
Some dishwasher models use a belt to drive the pump. Replace the belt if found broken.
Note: Sometimes the belt would just come off the pump. Even though it might not be broken, it is recommended that you replace the belt, because it is probably too stretched out.
3. Pump
Some models have two impellers inside the pump - one, wash impeller, takes care of the wash cycles, the other, drain impeller, drains the water out. If the drain impeller is broken (broken blades, shaft), the dishwasher would not drain. Replace any broken pump components.
4. Drain solenoid
Some models (for example most GE dishwashers) use a drain solenoid to drain water out. Sometimes the solenoid gets stuck, preventing the water from draining out. Try to free up the solenoid. If unsuccessful, you might have to replace the pump assembly.
5. Motor
If the motor is stuck, it is sometimes possible to free it up by manually spinning the motor.
Replace the motor if defective.
6. Timer
Replace if defective (note: uncommon problem).
SOURCE: burning smell coming from dishwasher caustic to
Older GE's had problem with drain coils over heating
Remove the bottem front plate and the coil will be on the left side of the moter and activate when the drain cycles, check that
SOURCE: need to remove ge potscrubber
Hello, sharraberry
I
was trying to help you out here. I am not sure if this well help you?
But here is a link to about everything you want to know about your
dishwasher, from repair to trouble shooting on most common dishwashers.
If you go to this link and click around, I am sure you will find out so
much about your Dishwasher, you will know more that the company that
made it.If you already solved the problem this is good for future
problems. Here Is the link for you to click on.
http://home.howstuffworks.com/dishwasher.htm
Please
if this helps you at all, and if you can find the time to rate my help
and some kind words written would be appreciated for my free help. Here
is also my direct link to my own pages of other areas of my expertise
for other problems you might have in Automotive,Appliance, and
Electronics. Drop In anytime for my help. Thanks So Much, Mike :)
http://beta.fixya.com/users/mc1bean
