Dehumidifiers Logo
j
john pan Posted on Nov 10, 2019
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
ForestAir dehumidifier:No water in bucket, and power on, why no status display and fan and compressor not working
jws1013
Level 3:
  • Master 1,713 Answers
  • Posted on Nov 10, 2019
jws1013
Master
Level 3:
Answers
1713
Questions
Helped
458554
Points
6786
Could be the humidity is low enough it isn't turning on. Try to lower the humidity setting to see if it will turn on. Once the humidity gets down to about 50-55%, dehumidifiers don't work very well at pulling out the humidity..
5 Related Answers
Anonymous
  • 1073 Answers
  • Posted on May 05, 2008
SOURCE: Problme in the dehumidifier not filling the bucket.
the unit has a sealed system issue in one of the coils, need to get it to a service company that services the brand that you have
Anonymous
  • Posted on Nov 13, 2008
SOURCE: Dehumidifier Error?
This error code indicates that the problem is most likely a shorted defrost thermistor or possibly a pinched wire going to the thermistor. You will need to replace the sensor assembly - part # 6877A30013L. The Sears website has it listed for 9.99 + shipping. The humidity sensor & defrost thermistor come together in a wiring harness that plugs onto the main circuit board. It is fairly simple to repair. Just remove the front & rear grill & the metal cabinet. Remove the thermistor from the copper tube on the cooling lines; remove the humidity sensor from the front of the evaporator; pull the wire plug off the bucket switch; & remove the small 7 pin plug from the main circuit board inside the metal control box. Reverse procedure to install new sensor assembly.
Anonymous
  • Posted on May 02, 2009
Same problem with Goldstar model DH404EY7 -- stop code 01 on startup, bucket full light blinks (drains to floor).
Replaced the main controller board to fix it.
For my model dehumidifer the part # is 6871A20888A, and cost $77.44 (not counting shipping) from Appliance Factory Parts. The Appliance Factory Parts web site also provides parts breakdown (exploded parts diagram) diagrams and service manuals in PDF form.
tomsat69
tom wright
  • 219 Answers
  • Posted on May 16, 2009
SOURCE: Compressor doesn't turn on
sound as though you need a temp control.Is there frost buld up on coil?If so it may not be humid enough .Hope i helped
Anonymous
  • 51 Answers
  • Posted on Aug 09, 2009
SOURCE: Kenmore 54501 Dehumidifier no water in bucket
may have lost ref charge check name plate for type of ref with 12 and 22 cost of gas cost proh. check tubing in rear should be ice cold to gather condensate if not probably lost gas
Compressor runs, fan runs, no water in the bucket.
There are many reasons why a dehumidifier willnot work or collect water.
Here is a tip that I wrote to help people to figure out what is going wrongwith their dehumidifier
Dehumidifier is running but no water is in bucket
heatman101
I have Haier HD656e which powers up, all controls work and the fan runs, but no water runs into the bucket. The compressor doesn't appera to come on. Anything simple I can check?
heatman101
Re: Kenmore 54501 dehumidifier. Both fan and compressor sound as though they are turning on, but no water is evaporated into the water bucket. The unit had always operated properly during past seasons,...
heatman101
AHH40LHG1: compressor operates, but no fan operation; no power to fan or signal to start
heatman101
Fan working but not compressor. Had been making noise when compressor on but now just fan working
heatman101
Compressor and fan are working but no water extracted in the bucket.
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
There can be many reasons why a dehumidifier will not work or collect water.
Here is a tip that I wrote to help people to figure out what is going wrong with their dehumidifier
http://www.fixya.com/support/r4662409-dehumidifier_running_but_no_water_in
heatman101
Maytag dehumidifier fan works bucket full light is not on but don't hear the compressor. Coils are clean.
There are many reasons why a dehumidifier will not work or collect water.
heatman101
No water in bucket even though fan is running. Think compressor is shot or needs freon?
There are many reasons for a dehumidifier2_bing.gif to not work or collect water.
Here is a tip that I wrote to help people to figure out what is going wrong with their dehumidifier2_bing.gif.
heatman101
Fan runs, but compressor does not start
heatman101
2answers
My dehumidifier will not turn on
heatman101
Top Dehumidifiers Experts
ZJ Limited
ZJ Limited
ADMIN Andrew
ADMIN Andrew
Are you a Dehumidifier Expert? Answer questions, earn points and help others
