Question about Health & Beauty
SOURCE: replace front wheel bearings
The bearings in your car are pressed into a hub. If the part is available as an assembly, it can be replaced that way. Generally on a front drive car:
Remove wheels and brake calipers
If it is pressed in: remove the rotors, disconnect the drive shafts and remove the steering knuckle. Then the old bearing is pressed out and the new one pressed in with a machine shop press. If the bearing is part of the hub, that will be unbolted and the new one swapped.
On a scale of 1-10 difficulty, Id rate it a strong 7
Posted on Jun 20, 2008
SOURCE: 1995 ford contour / passengerside wheel bearing
http://www.autozone.com/shopping/repairGuide.htm?pageId=0900c152800a8e08
Posted on Dec 07, 2008
SOURCE: what torque for rear wheel bearing Ford Focus 2000
Can only find out that the hub needs to be tightened to
235 nm Dunno if this helps
Posted on Jan 27, 2009
SOURCE: 1998 mustang squeaking wheel bearing
The wheel bearing need to change.
Grease will only cover the problem for a little while.
If you jack the wheel up a little off the pavement.Then try to shake the wheel back and froward. If it shake then the wheeling bearing is getting bad. There suppose to be no shake on the wheel.
Posted on Mar 19, 2009
SOURCE: Wheel Bearings
Hello tclinch.
Your Grand Caravan has hub assemblies front and rear. Also if yours is all wheel drive it has a rear hub as well. Just different removal processes.
Hope your repair goes well for you.
Posted on Nov 27, 2009
May 22, 2018 | Cars & Trucks
Dec 09, 2015 | Kia Cars & Trucks
Sep 02, 2014 | 2007-2011 HA590245 Dodge Nitro Front Wheel...
Oct 23, 2013 | 2001 Mercury Grand Marquis
Feb 14, 2013 | 2006 Nissan Altima
Jul 07, 2012 | 1993 Plymouth Voyager
Jun 18, 2012 | Tata Indica Cars & Trucks
Dec 31, 2009 | 2002 Ford Explorer
Sep 15, 2009 | 2003 Hummer H2
Feb 20, 2021 | The Health & Beauty
121 people viewed this question
