Good day!!!
That problem is usually cause of low reception if you are using aerial antenna,if your are using cable or digital signal check your wiring and the worst is you have defective audio IC..
I will teach how to determine the exact trouble just click this link LCD HDTV ASSUMED TO FIX and click "get service"..
Thanks for using fixya...
SOURCE: need upstar TV Codes
I found that common LG codes (056) mostly work with UpStar (that uses LG panels, and generic electronics modules).
Watch out for stripped or missing hardware, including on table stand pod and VESA brackets, with UpStar's sloppy quality control. Also, they've reversed AC line Hot and Neutral and caused other problems in their California service facility, shipping fire and electrocution hazard TV's.
SOURCE: Can anyne find Upstar TV code for DirecTV remote RC65X?
Use code 11758 I called upstar and it worked.
SOURCE: codes for upstar tv
I have an 32"UpStar TV P32ES8 codes that woeked for me CODES:1265, 0702, 0150, 0154, and 0047 (OneFor All Remote)
SOURCE: Forgot lock code on 32 inch led hdtv upstar tv model nnumberP32ES8
If you wish to get some details; check the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/ Unlock procedure and to override the password lock of many popular brand TVs and other devices are given. Search the site by type in this key phrase "How to unlock television"; in the search box at the top left of the display window, to get gathered related posts.
