Question about Johnson Boating
Remove tilt trim 98 50 hp Johnson - Johnson Boating
Posted by Steve Bousfield on
5 Related Answers
Anonymous
  • 5 Answers
SOURCE: tilt-trim not tilting down after being tilted all the way up
check the solinoid you should have two,one for up and one for down,you can test by putting a screwdriver on both neg and pos contacts at same time,if thats not it check to make sure nothing came unpluged
Posted on Jul 26, 2009
Anonymous
  • 86 Answers
SOURCE: I have a 1994 150 hp Yamaha outboard motor with
Stop! Dont replace the pump...I would bet that it is the "down" Solenoid that went haywire. I would begin by replacing the Down solenoid...it is a far easier and cheaper fix and if your pump works to raise the engine then that tells me that it is not faulty. The Down solenoid looks just like a starter solenoid and the one that you are looking to replace has a GREEN wire to it. Yellow with a red stripe is for the starter. Blue wire is the up solenoid. So replace the one with the green wire going to it and I bet it will fix your problem.
Posted on Aug 03, 2009
canbruce75
Bruce Canfield
  • 1776 Answers
SOURCE: how to service a tilt/trim on a 50 hp yamaha
To check the fluid level, tilt the motor up and engage the tilt lock lever. Open the bolt on top of the tilt/trim reservoir. The fluid should be even with the bottom of the bolt hole. If not add some fluid. When you put the bolt back in, run the trim up and down a few times. That should purge any air out of the system. Always be on the lookout for any leaking hoses or fittings. Hope this helped and best wishes.
Posted on Aug 31, 2009
ray gallant
  • 68537 Answers
SOURCE: I have a 1987 110 hp johnson vro, the trim motor
sounds like your little relays are bad .
Posted on Apr 25, 2010
ray gallant
  • 68537 Answers
SOURCE: trim tilt guage not working,2000
kinda sounds like a wire got pulled loose or the gauge went bad .
Posted on Nov 02, 2010
My johnson 50 when in the up position it slowy goes down and there no oil leaks ps how much tilt fluid should be in it tilt cheers michael
Have a bad check valve somewhere in the system allowing pressure to bleed backwards through the system, should be able to hear it when the bucket is up in the air turn off the tractor and listen closely to the lines for a slight whining sound from the fluid leaking when it should be sealed
Oct 11, 2016 | Sierra Johnson/Evinrude Tilt and Trim Pump...
Can you please advise me how to fix my tilt motor on my johnson Model No. J50PL4ST 50 HP 2002 motor
have never heard of a tilt motor.trim and tilt but you aren't telling me what it does or doesn't do.miight just need oil or even a fuse replaced
Aug 28, 2014 | Boating
Can't get any power to my evinrude tilt and trim what am I doing wrong ?
Check fuse.try connecting trim wires from t/tilt motor direct to battery supply to see if motor is ok.t/tit solenoid could be faulty,switches could be faulty.broken wire in loom or control box
Aug 16, 2014 | Sierra International 18-6756 Marine Power...
Tilt/Trim Motor
check trim switch with multi metre ! check solinoids not stuck !
Jan 16, 2014 | Boating
Johnson trim tilt problems
WWW.OVERTONS.COM ORDER A SELOC SHOP MANUAL
Jul 23, 2013 | Boating
How to raise manual tilt johnson (no tilt trim)
on the right side of the motor there is a lever that says tilt on it pull it up unlocks motor grab the top of motor and pull with all your mite
Mar 25, 2013 | Boating
Tilt trim go up wont go down 2003 johnson 140 hp 4 stroke
You may want to check service bulletin #2002-052. Some of these motors supply too much voltage to the trim switch at the throttle lever and that trim switch stops working. There is an add-on harness #586806 that fixes this. If you can still tilt and trim the motor at the trim switch that is built into the motor housing this is likely the problem.
Jan 30, 2012 | Boating
The trim/tilt on my 97 Johnson 150 outboard is not moving. Tilt motor runs. Some time ago my mechanic told me not to run the tilt all the way to the top, which is, I think, what happened. Any ideas on...
Make sure there is not a spring loaded locking lift latch engauged. If there is you will see a little movement and then the motor will sound slower. If there is no movement and the motor runs the same speed with no change you are low on hydraulic tilt and trim fluid.
Please take a moment and rate my answer............ Thanks
Nov 28, 2010 | Sierra International 18-6756 Marine Power...
Trim tilt guage not working,2000 model 70 hp Johnson outboard.thanks Peter.
Oct 03, 2010 | Bass Pro Boating
Boating Logo
137 people viewed this question
Top Johnson Boating Experts
Marvin
Marvin
Lawrence Oravetz
Are you a Johnson Boating Expert? Answer questions, earn points and help others
