Question about Bosch Nexxt 300 Series WFMC2201UC
Bosch 4.0 Cu. Ft. Nexxt 300 Series Front Load Model WFMC2201UC now the fabric softener will not dispense. Apparently something clogged further down inside.
Purchased from Lowes 2008, detergent and bleach dispenses fine. Have removed tray and soaked in hot water overnight.
6ya staff
SOURCE:
Anonymous
SOURCE: Water in detergent dispenser
Remove dispencer again, remove conditioner syphon assembly and clean up the little tube. Should then go okay
Posted on Jul 11, 2007
zeusfaber
Alastair Macleod
  • 247 Answers
SOURCE: Bleach and fabric softener dispensers full of water
This is a problem common to virtually all front-loaders. Pull the dispenser drawer right out (it is designed to come right out - you might just need to give it a bit of a jiggle to get it past the stop) Remove the cover/caps from the drawer (sometimes this is a snap-on cover over the back of the drawer, sometimes a top-hat shaped cover over the siphon spigots). Give everything a thorough clean off with hot water (scrubbing with an old toothbrush helps), then reassemble. A.
Posted on Jul 16, 2007
Anonymous
SOURCE: Bosch 3.81 cu ft Nexxt 500 Plus bleach not dispensing
We had the same problem with the bleach dispenser. It was under warranty so Lowe's sent a repairman that replaced some part in the control panel that he said was faulty on this model. He also said to only use 1-2 Tablespoons of HE detergent and leave the door open. Also dilute any softeners before adding them.
Posted on Oct 12, 2008
Anonymous
SOURCE: Fabric softener and bleach dispensers
Call the tech. one came out this week and said the system solenoid is always engaged causing the bleach and detergent to dispense when drawer is pushed in
Posted on Feb 22, 2009
Anonymous
  • 101 Answers
SOURCE: Water in the detergent, fabric softener, bleach dispensers
If it's not leaking outside I wouldn't worry
Posted on Oct 02, 2009
Front load washer dispenses fabric softener drawer fills water
either the auto dispenser is sticking , take out and clean with hot water. Or flow control valve needs replacing.
Feb 24, 2014 | Bosch Washing Machines
Fabric softener does not get dispensed into wash on my Bosch Nexxt 500.
Hi emily446,
Take out your Tray from the drawer (Usually un-clips on the sides or top)
Then clean the holes inside the drawer at the roof. There will be small holes, clean these with either ear-buds or toothpicks. These holes get clogged quite often, and cleaning them will allow water through to the machine again.
Also clean the tray, especially near the hole at the back where the fabric softener gets siphoned through.
Kind Regards
JEDEMEYER1
* If this solution helped you, please rate it
Aug 15, 2011 | Bosch 3.81 cu ft WFMC530 1UC Nexxt 500...
Fabric dispenser still full after washing completed
Here is a tip that I wrote about what I found out about the fabric softener not dispensing into the washer...
Fridgidaire Washing Machine Fabric Softner not going into washer
heatman101
Sep 04, 2010 | Bosch 3.81 cu ft WFMC530 1UC Nexxt 500...
Getting E:13 error on Nexxt 300 series washer
Try putting the washer on COLD and run "TWO" cycles. It must be on COLD. There is a chance there is too much soap or fabric softener in the washer. It may also help to clean the fabric softener tray where you add the softener.
Nov 22, 2009 | Bosch Nexxt 300 Series WFMC2201UC
Shows E13 what is it?
Nov 08, 2009 | Bosch Nexxt 300 Series WFMC2201UC
Water left in fabric dispenser after load
The dispensers work by the siphon principle. You load the softener and at the proper time, the machine diverts water to the softener cup raising the level. In the softener cup, there is a tube loosely covered with a cap. When the level in the softener cup is raised high enough, a siphon effect is started and the softener is pulled from the cup into the washer. This will continue until the water quits flowing and air gets under tha cap, breaking the siphon. The amount of water remaining in the cup is dependent on the level of the cap, and the amount of residual water remaining in the dispenser fill tube once the siphon effect is broken. You can see this effect for yourself: take a measuring cup and slowly pour water into the softener cup, raising the level above the max line. When the level gets high enough, the contents of the cup will dispense. You can remove the cover cap that is a part of the dispenser and clean it; it will help. Removing the entire tray and cleaning all of the tubes and the cap assembly will also help. The only other thing that can be done is to change the dispensing supply valve, as it sounds like there may be some leak by after the fabric softener is dispensed. Having residual water isn't really hurting anything. It's only water, and the machine has dispensed the softener! Try the cleaning part first as this usually corrects the issue, and then the repair technician if it still bothers you. For as much as the extnded warranty costs, you should be completely satisfied with your machine.
Best regards, --W/D--
Sep 13, 2009 | Bosch Nexxt 300 Series WFMC2201UC
Some water backs up in the softener dispenser??
Service was here today and tilted the machine backward about 2-4 degrees. This solved the problem. Now fabric dispenser fully empties. Since the machine is 2.5 year old it is possible that over time it settled. I think though it is more likely the cold water dual inlet solenoid that is a bit constricted. If this fix does not last I will change it.
Feb 03, 2009 | Bosch 3.81 cu ft WFMC530 1UC Nexxt 500...
Bosch Nexxt series washer - water in softener dispenser
Hi. Remove dispenser, and thouroughly clean.
This should solve problem. If problem persists, don't worry about it tomuch, as long as it takes the conditioner down that is the main thing.
Nov 23, 2008 | Bosch Nexxt 100 Series WFMC1001UC Front...
Sep 13, 2008 | Bosch 3.81 cu ft WFMC530 1UC Nexxt 500...
My front loader Bosch washing machine is not draining in the fabric softener section.
Make sure it is the fabric softener that is not being added. Try running w/o fabric softener and see if the tray is still full. The reason I am asking is that after I run my washer the fabric softener tray is full, with water, not softener. The factory tells me it is because the water fill nozzles have realigned and overspray into the softener tray. Not a big problem, since my system is under warranty I am having them fix the nozzles and then I will know how to redirect.
If it is the softener that is not being added then check to make sure the line is not clogged. You can lift out the bleach / softener try and check for cloggs.
Aug 18, 2008 | Bosch 3.81 cu ft WFMC530 1UC Nexxt 500...
Bosch Nexxt 300 Series WFMC2201UC Logo
27 people viewed this question
Top Bosch Washing Machines Experts
Marvin
Marvin
jimorris77
Dw Wooten
Dw Wooten
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
