Question about Sony Televison & Video
Antenna input not enabled
Trying to attach digital antenna to Sony KDL-55nv720 for local channels....planning on cutting the cord.... Connected antenna but when I INPUT the TV option is grayed out...I cannot choose it....When I go to DISPLAY I can choose TV but get the error message "tv antenna input is not enabled"...appreciate any help...
    Top Expert:
  • Sony Master
  • 64,733 Answers
You need to change input source to air or antenna
Posted on Nov 10, 2019
6ya staff
SOURCE:
Anonymous
  • 46 Answers
SOURCE: RCA TV - Trying to hookup new dvd/vcr player to old tv with only antenna input
The input on your television is probably coaxial (for cable or an antenna) which means it needs an RF modulated signal. You can find one of those at your local department or electronics stores. Just look for an "RF Modulator" or "video-RF convertor." They're most commonly used to hook video games up to older televisions.
Now, if you've got an old VCR handy, that has an external input, it already has the RF modulator built-in.
Posted on Nov 08, 2007
Anonymous
  • 84 Answers
SOURCE: Can't remove AV Input display
Try setting hdmi control to off in tv menu
Posted on Apr 06, 2008
Anthony Gonzales
  • 267 Answers
SOURCE: Sony 46" LCD tv hdmi input replacement kdl-46v2500
replace that board
Posted on Mar 06, 2009
Anonymous
  • 245 Answers
SOURCE: Sony Bravia KDL-46V4000 tuned to digital mode has
YOU LIVE IN A BAD RECEPTION AREA WHERE DIGITAL IS NOT WORKING WELL......
LOOKS LIKE U HAVE TO SWITCH TO ANALOG.....
UNTIL THIS PROBLEM IS SOLVED IN UR AREA.....
Posted on Nov 20, 2009
kimberlyesco
Dish
  • 184 Answers
    Verified Fixya Pro
    SOURCE: can't get the tv/input button to work on dish
    Hi there! This is Kimberly Escobar with Dish Network. Just ran across your post and wanted to help. In order to get the remote to possibly work the Inputs on your T.V the remote needs to be programmed to your Vizio T.V. In order to do this we have certain codes that can be integrated into the remote. Some of the codes for a Vizio T.V are 505, 671, and 627. The procedure is press and hold the clear T.V buttton located at the top of your remote until you see all the other buttons light up in red, once they are lid up enter one of your codes followed by the pound key for example: 505#. The T.V button should light up 3 times you can then try the remote to see if it works your T.V
    Unfortunately we cannot promise it will completely function the T.V so it might bu that input button does not work. If you need any help please contact us directly at 1800-333-DISH.
    Posted on Feb 09, 2011
    Antenna channels
    use digital antenna via radioshack
    Jan 24, 2014 | Sony BRAVIA KDL-40XBR2 40 in. LCD HDTV
    Digital not displaying
    try to reset the unit.by unplugging it for sometime and then plug in.this will help.if the problem is minor.
    Aug 24, 2008 | Sony BRAVIA KDL-40V2500 40 in. LCD HDTV
    Antenna unrecognized.
    Sometimes the TV will lock out other inputs when a cable is connected. Try the antenna by itself and put the TV in Channel scan mode. If this works reconnect the cable TV cable. If that doesn't work you may need an A/B switch
    Feb 19, 2018 | Sony BRAVIA KDL-40S2010 40 in. LCD...
    How to change channel from one to any one channel in sony bravia
    I need more info. Are you using antenna connected to RF input or are you using cable box, sat box or ATT Uverse? If connected to antenna . go in menu or Home on Sony. Press setup and look for channel scan. Set to antenna and do auto scan. If cable or other provider box set tv to ch 3 or what ever provider says. You are then using the tuner in that box. You will use providers remote to change channels. Be sure in setup that tv is set to cable if cable box is used. Hope this helps but the info you posted could be more descriptive.
    Oct 02, 2013 | Sony BRAVIA KDL-V32XBR1 32 in. LCD HDTV
    Using an antenna on KDL-32S5100
    No you do not. Your Sony already has a digital tuner. If you are not getting all the channels you think you should, you just need to keep progromming your TV with the antenna at different locations to maximise your signal.
    Apr 17, 2012 | Sony BRAVIA KDL-32S5100 32 in. LCD HDTV
    My Sony KDL-52xbr4 was working fine until I did a re-scan of the digital channels. After the re-scan the TV finds no digital channels. All other TVs hooked to the same antenna work fine. The sony scans up...
    Hi check to make sure the antenna is connected correctly. try tunning the channels manually and if they come up you can save them one at a time. Also try moving the antenna to a different location. make sure the TV is set to scan on the same input that you are connecting the antenna. If all that fails ou might have a defective tuner board.
    You can get parts for this tv at www.interliquidparts.com
    Nov 06, 2011 | Sony BRAVIA KDL-52XBR4 LCD TV
    Trying to hook up a digital antenna but no channels coming in
    You need to get a connection from a local cable or wireless service with a set top box to be connected to the input. Please check with your local operator and see if the set top box is needed for the digital feed.
    Otherwise you might need a dish with the LNB to be used to the TV. Digital tuner means that the tuner is working to scan and memorising the full band width of the channels with digital processing and thus faster and crisp.
    Check the details of the TV from a forum:
    http://reviews.cnet.com/direct-view-tvs-crt/philips-32pt9100d-32-crt/1707-6481_7-31473699.html
    Oct 22, 2011 | Philips 32PT9100D 32" TV
    Whilst watching digital channel, tv suddenly said channel not tuned. Same problem with all channels. Now comes up channels not stored, and when trying auto start up, says no channeels found.
    Ur tv,u are using and getting a over the AIR free broadcating tv channels signal wright?Ur antenna are using,have problems might not work anymore in ur area.Tries manual channels scanning ur tv should get it back or buy a better antenna deign like a Digital antenna design for a hook it up for a better signal prob and longer signal ranges tries scanning for Free over the AIR channels again should solved this problems.
    Aug 27, 2011 | Sony BRAVIA KDL-46V3000 Television
    Bought a Soney KDL-46EX500 last week. Still tring to get it set up. Got the digital local stations programed into it today. (finally) Now I can not figure out how to switch back and forth from locals...
    Looking at a diagram of the back of your TV I see that you have only one Coax input. You will need to plug either your antenna or the DirecTV in one of the other sources available on the back of the TV.
    According to DirecTV's website, their box also uses composite video cables and depending on the age of that box, may have an HDMI connection also.
    Looking at the back of your TV, the composite video cable input is the top two rows to the right of the Coax input you are currently using.
    Once you have both connected to different inputs, you can use your remote to switch between the sources and watch whichever you like.
    May 03, 2017 | Sony Televison & Video
    Lost digital channels, only getting analogue installed new antenna, no help other sony lcd is working fine
    Got to -
    Menu -> settings -> set-up menu -. auto start up
    Rescan your tv for all channels.
    Any more problems, call sony. 08456000124 local rate number
    Dec 12, 2009 | Sony BRAVIA KDL-32S2000 32 in. LCD HDTV
    Televison & Video Logo
    16 people viewed this question
    Top Sony Televison & Video Experts
    Jerry Greenberg
    Jerry Greenberg
    Ekse
    Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
