After each wash there is nothing in the lint filter is there a blockage somewhere in the system?
    Top Expert:
  • Washing Mach... Master
  • 64,764 Answers
Why would that be a problem?
Posted on Nov 11, 2019
6ya staff
SOURCE:
Anonymous
  • 261 Answers
SOURCE: excessive lint on clothes and smell
There is many solutions that work some. The best analogy I have seen is to reduce the wash time as the newer soaps are more efficient at removing dirt which also softens the fabric. Any excess in soap regardless of type in combination with water type will cause an odor, why is the contaminents in the water plus the junk on are clothes to be polite. It builds up under the basket and along the top water line in the tub plus creates a film from the tub through the hoses, pump and house drain. Lint is a product of excess washing and too much soap. Whirlpool stated for there front loaders no more than two TBL of liquid soap which is like 3/8 cup max for the old top loader. SearsTechToo
Posted on Oct 06, 2008
Anonymous
  • 7 Answers
SOURCE: Bosch WTL5400 Condensation Dryer
We continuously had a similar problem with signals forever coming on after just a few dryer loads. The problem was corrected when we took the back off of the dryer and cleaned the recirculating fan and removed a rubber glove that somehow came through the system and blocked the air flow at the heating element. Low air flow is the same as plugged filter and apparently the computer in our German-made Bosch dryer simply says that. We cleaned the area well, removed all traces of the glove and restored the dryer to operation. We have not had the filter problem since. We routinely clean the heater area at the back of the dryer to maintain our sanity. And we now dry our clothes. Bosch never responded to my query.
Posted on Oct 25, 2008
Anonymous
SOURCE: hoover 600md washing machine lint filer
l spoke to a repairman and he told me that it is probably a soap build up from only using cold water.....he suggested using sugar soap and hot water and let it soak for a few hours and then let it finish a cycle...and surprise surprise it worked, the lint trap is now working and the smell has gone
Posted on Nov 11, 2008
ginko
Ginko
  • 19396 Answers
SOURCE: Hi I cannot find the lint
Hi.
This machines use lint stainless steel filters, located on the side of drum, inside the machine. The filters usually do not get replaced, but they need regular cleaning (clip out & rinse in tap water).
If this solution was helpful, then please do not forget to accept. Writing and posting pictures takes time and your rating is very important for us.
Regards.
Ginko.
Posted on Sep 28, 2010
techbuster
INDIRA KUMAR
  • 5081 Answers
SOURCE: lint appears on clothes after
You could be washing your shirts with towels, these are the greatest lint depositors when washing clothes, towels should be washed separately from your washing, to remedy this pour in one cup of White Vinegar into washer and fill with warm or cool water full cycle cold rinse do not add any detergent or fabric softeners as this could counteract the vinegar when washing your clothes next time you can add half cup of White Vinegar to the rinse water or add to your fabric softeners dispenser, vinegar will help soften and ****** static cling, and deodorize it even removes stains
General explanation to clean lint filters
Wet a cloth and squeeze to remove excess water. Open the washing machine. If there is lint along the plastic agitator, wipe it clean. The agitator is the large, plastic piece in the center of a washing machine.
Remove the agitator tube from the washer. Look at the bottom of the washing machine, where the agitator was. There should be a small lint filter. Peel away any lint built up on this, just as you would peel away lint from a dryer lint filter. Look inside the agitator tube for lint, mold or mildew. Remove any lint with a wet paper towel or rag.
Look along the drain hose for any lint. Wipe the lint down with a clean, damp cloth.
Examine the the top and rim of the washing machine. Remove any lint that has built up by wiping it away with a clean, damp cloth.
FOR WHIRLPOOL DUET MODELS
Drain the washer, if you've not done so already. When finished, unplug it.
Locate the lint trap panel under the washer door. Use the screwdriver to unscrew the panel, if necessary. Pull off the bottom panel. Unscrew the white knob to access the trap.
Use your fingers, a damp rag or sponge to remove lint, hair or other foreign objects that might have become lodged in the trap. When finished, tighten the white knob and replace the door. Plug in the machine.
To keep the lint filter clean, before you launder clothes, check pockets and remove any object that could clog the Whirlpool Duet's lint trap. Consider alternate methods of cleaning clothes or items that could shed and, therefore, clog the lint trap.
If you have cleaned the lint filter, but your freshly laundered clothes still smell like mold or mildew, clean the tub. To do this, open the washer door, then use a damp sponge or rag to wipe the tub, particularly any areas where there might be a gap between it and the washing machine's metal casing. Start the empty washer and add 1 cup of white vinegar, instead of detergent. Vinegar loosens lint, mold, mildew or other debris that might be present. The debris washes away during the drain cycle.
If you have cleaned the lint filter, but the washer still does not seem to be operating properly, drain the washing machine, then pull the washer from the wall and unhook the drainage hose. Rinse the inside with a low-pressure stream of water to dislodge any foreign objects or lint. Reattach the hose. If problems still persist, contact a certified repairman.
Posted on Oct 26, 2010
Is there a filter to catch fluff during wash?
How to Reduce Lint in Laundry - Home Ec 101
www.home-ec101.com/how-to-reduce-lint/
Sep 23, 2010 - I clean out the dryer lint trap every time and that doesn't seem to matter. ... If your washing machine is older, there is a chance that it has a built-in lint trap. If this is the case and ... Follow the directions for cleaning the lint filter.
Washing Machine Pump Filter - White Goods Help
www.whitegoodshelp.co.uk > ... > DIY Washing Machine Repair Help
Jul 8, 2013 - Common problems and faults with a washing machine pump filter. ... a pump filter to protect the pump from a build up of lint, and obstructions such as coins. ... towel to catch water and don't take it out at all if the washing machine still ... If you can't see any blockage, or there is just the odd button in there that ...
Is there a filter to catch fluff during wash? - Fixya
www.fixya.com/support/t26006809-filter_catch_fluff_during_wash
3 hours ago - Locating fluff filter on aeg washer/dryer . After using the dryer facility the following wash resulted in garment containing patched of fluff ...
How To Clean Your Washing Machine Filter - YouTube
Dec 13, 2015 | Washing Machines
Where is the lint filter? Why does it put lint all over clothes?
lint is usually removed in the dryer. If you have lint on clothes after going through the wash, you probably left something in a pocket somewhere.
Sep 20, 2014 | Maytag Washing Machines
I would just like to know where the filter is on a top loading speedqueen washing machine. there must be somewhere that the bits and fluff collect.
there is no filter' it's what they call a self cleaning lint filter, collects lint while washing and then on spin lint goes out with the drain water
Feb 18, 2011 | Washing Machines
Clothes dryer not drying properly
If you use sheet type dryer fabric softener, take the lint filter out and run cold water over it. If it holds water, it can't do it's job to remove moisture. Wash the filter with soap and rinse until it passes water without holding it. Inspect where the filter goes for a blockage of lint. Check the exhaust to make sure the pipe or termination is not holding lint. You did not mention if your dryer has all the bells and whistles or is it a basic dryer. If your dryer has a simple dry setting, run it on that to see if it is a control issue or just blockage.
Nov 10, 2009 | Heating & Cooling
My lg front load washer stops and give me an error message OE
The LG error code OE simply means "the pump is blocked". Presumably the water isn't being emptied properly. As with all error codes it is possible that there is a cause other than the exact description in the error code explanation but basically this error means as far as the washing machine is concerned it thinks the water isn't pumping out. A pump, or filter blockage is the most common cause but it could be caused by other faults such as a faulty pump, or even a blockage in the drain hose or somewhere else in the system etc.
LG themselves have some information on this error code..
http://lgknowledgebase.com/kb/index.php?View=entry&EntryID=6273
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Jul 27, 2009 | LG WM-2277HW Front Load Washer
GE top load washer w/no lint trap leaves excessive lint
Most US-sold washers made after the mid 1980s don't have lint filters. The manufacturers weasel-word around it by saying that the lint "goes down the drain", leading people to optimistically assume that there is a self-cleaning filter in there somewhere. There usually isn't and whatever lint doesn't go down the drain is filtered by your cloths (but whatever does might clog your septic system). As a result of this scam, it's much harder to hang-dry or iron-dry clothes that haven't been hand washed. And, if you think spending $2000 on a pair of matched "front-load" style machines will solve this, you might be wrong; many of those washers still have no lint filter.
Jan 08, 2009 | GE WBSR3140DW Top Load Washer
Hoover 600md washing machine lint filer
Nov 10, 2008 | Hoover Washing Machines
WTV74307GB
the warning does not strictly mean filter only
there is a lint blockage somewhere in the vent system and there is only a single response the dryer knows to make
fan
fan housing
duct
outside vent
could all be sufficiently blocked to set off the warning
Oct 19, 2008 | Dryers
Spots of Grey lint left on clothes after washing
Have you cleaned the filter on the front bottom of the machine?
May 11, 2017 | Bosch Washing Machines
Washing Machines Logo
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
Marvin
Marvin
