Question about Element Televison & Video
I need to replace my element on Cheminee Electrique
Portable fire place
2 Suggested Answers
6ya staff
SOURCE:
Anonymous
SOURCE: i have a napoleon wood fireplace, I just installed
an open fireplace is not going to heat your house only 5 feet in front of the fire place. 75% of the heat goes out your chimney and burns the wood very fast. sorry to say but if you are looking for heat you installed the wrong unit!
Posted on Jan 21, 2010
Boil element caught on fire and melted.
If element caught on fire, I would suspect stove needs cleaning. Do that then elements should not smoke for long. (I hope all moisture was removed from stove!!!)
Feb 11, 2014 | Kenmore Element Stove Burner Frigidaire,...
Schema electrique red rose 125 de 1989
Salut , Anonyme Je suis d?sol? que vous ne pouvez pas trouver le premier et le meilleur outil vous d?j? achet? pour votre Aprilia , mais ne d?sesp?rez pas pour un simple 10 $ , vous pouvez t?l?charger un de l'autre . Pour plus d'informations au sujet de votre question , s'il vous pla?t visitez les sites Web ci-dessous . Bonne chance et bonne journ?e .
https://www.tradebit.com/filesharing.php/search/0/1989+aprilia+125
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/gregg_c0ec1df182c7330e
Sep 09, 2012 | 1992 Aprilia Red Rose
Problem electrique
Je pense que vous avez mis cette question dans la mauvaise section. En outre, etre plus precis dans votre question.
Jun 25, 2012 | Video Game Consoles & Games
I have a napoleon wood fireplace, I just installed it in a fireplace. It seems like I can't get any heat out of it. I installed a cheminee liner up the cheminee. I think that the heatloss is going up the...
Dec 14, 2009 | Napoleon 36" Zero Clearance Top/Rear Vent...
The heating element is not coming on on my dryer. Is there a fuse or a switch of some kind oi/on the Dryer that I can check and replace or do I need a whole new Dryer?
this could be one of several things. First, the drier element could be bad. To find this out you will need to perform a continuity test on the element to do this get an electric meter and place the settings on ohms. Disconnect one side of the drier element and place one meter lead on one end of the element and the other lead on the other side of the element if you get a signal the element is good no signal then the element is bad needing replacement. Secondly, there is a high limit switch in the area of the element that is installed to prevent the element from overheating causing a fire. This high limit switch looks like a button bout the size of a dime. really no way to check this switch but if the element is good then more than likely this switch is burnt out given that the drier is receiving the correct voltage which was the third possibilty since the drier runs on 240 v if it isn't receving the proper volts the element may not heat up. As far as cost most of the elements and the hi-limit switches are inexpensive however they are hard to install thats where the cost comes in (labor) I would get an estimate before repairing
Good luck on repairs hope this helps
Dave
Sep 04, 2009 | Dryers
Element Melted - Turned White Hot/on fire and would not go out
You need to replace the element. Very easy to do. Cut power off at the breaker or unplug the stove FIRST (please!). Remove the two 1/4" screws securing the element to the oven cavity then two wires to the element just unplug. The wires can go either way. Call 1-800-626-2002 or go to the GE Appliance web site for the part. It is a WB44T10011 for the lower (bake) element and WB44T10009 for the top (broil) element.
Jan 02, 2009 | GE JBP80 Electric Kitchen Range
Oven element on fire
yes that's a common problem. but not because there was a fire on top of the element it mean that is bad. have you try the oven after the fire?
Dec 06, 2008 | Jenn-Air Kitchen Ranges
Baking Element Caught fire
this a common complaint when the element burns out it is scary to see but all you need to do is replace element
Apr 21, 2008 | GE Profile 30" Free-Standing 5 Burner Self...
funny same thing just happened to me and it all seams to be the bottom element of the same ovens around the same year, I bought mine in 99 also, I keep my oven very clean becasue i know the dangers it may cause, I think this is a major problem and it needs to be addressed.
Aug 19, 2007 | Maytag MER6772 Gemini Electric Kitchen...
Televison & Video Logo
19 people viewed this question
Top Element Televison & Video Experts
Joseph Hoffmann
Are you an Element Televison and Video Expert? Answer questions, earn points and help others
