Km4000 i GET FLASHING lED BUT NO RUN? - Televison & Video
Flashing LED light
Did you drop it? If you did, bust it out of the shell and take the actual hard-drive out. Then get a slaver (aka: a disk cradle/dock). Those run about $20 at most. Otherwise, there might be something wrong with the cord or your USB drive.
Mar 01, 2014 | Seagate (ST3100203U2-RK) (ST3100203U2RK)...
Delonghi EC850 coffe mashine red light are flashing
I have a Delonghi Figaro and the red led flashing means:
The unit has run enough times to likely be scaled, this is a reminder to run weak acid (vinegar or citric acid) through to descale. Then rinse twice with clean water.
Scale will slow the brewing process so if it's brewing slowly you should do this regardless of the LED.
The LED can be reset by pushing <Prog.> and <On.> at the same time.
Of course, none of this is in the manual.
Sep 14, 2012 | Coffee Makers & Espresso Machines
I was trying to backup my server while exchanging DLT tapes, the tape in use light stayed on and the serve would then alternate to four flashing lights and then back to flashing "Tape In Use...
Try the following action to resovle your issue:
1. Run the Drive Assessment Test in HP StorageWorks Library and Tape Tools.
CAUTION: Running the Drive Assessment Test overwrites the tape. If it is not possible to
overwrite the tape, run the logs-based Device Analysis Test instead.
2. Check the backup logs.
3. Verify that a supported configuration is being used.
4. Check for media damage:
o Incorrect label placement
o Broken, missing, or loose leader pin
o Damaged cartridge seam
o Usage in incorrect environment
5. Check for software issues:
a. Check the backup software.
b. Check that virus scanning software is not scheduled to run at the same time as the back-up.
6. Verify that a tape can be formatted.
Tape Error LED is flashing:
1. Reload the suspect tape. If the Tape Error LED stops flashing, the problem has cleared.
2. Load a new or known good tape. If the Tape Error LED stops flashing, the problem has cleared.
3. Reload the suspect tape. If the Tape Error LED flashes, discard the suspect media as faulty.
From my experience, most of the time it is a bad tape, using a new tape usually solves the problem. If after inserting a new tape and the problem exist, you may need to update your firmware/backup software.
Good Luck
C2Solutions
Jan 13, 2011 | HP Compaq ProLiant ML350 G3 Server
No wireless connection for laptop. Linksys router - model #wrt160n v2
you can run a direct line to that router and go to the cisco web site and get the information you need to run that router. its a pdf format and is 2.56 Meg. Try this
SecureEasySetup (Orange/White) The Cisco logo is the Router's SecureEasySetup button. It
lights up and will stay orange when the Router is powered on. The color orange indicates that
the Router is not using the SecureEasySetup feature, while the color white indicates that the
Router is using the SecureEasySetup feature. When the Router enters SecureEasySetup
mode, the Cisco logo will turn white and start flashing. After the Router has generated
the SSID and WPA Personal key, the Cisco logo will stop flashing and stay white.
To clear the SSID and WPA Personal key, press and hold down the Cisco logo for five seconds.
The Cisco logo will flash slowly as the Router resets itself. The Cisco logo will turn orange to
indicate a successful reset.NOTE: SecureEasySetup is a feature that makes
it easy to set up your wireless network. If you have SecureEasySetup devices, run the Router's
Setup Wizard CD-ROM and follow the onscreen instructions to use SecureEasySetup.
Power (Green) The Power LED lights up and will stay on while the Router is powered
on. When the Router goes through its selfdiagnostic mode during every boot-up, this
LED will flash. When the diagnostic is complete, the LED will be solidly lit.
DMZ (Green) The DMZ LED indicates when the DMZ function is being used. This LED will
remain lit as long as DMZ is enabled. WLAN (Green) The WLAN LED lights up when
the wireless feature is enabled. If the LED is flashing, the Router is actively sending or
receiving data over the network. 1, 2, 3, 4 (Green) These numbered LEDs, corresponding with the numbered ports on the Router's back panel, serve two purposes. If the LED is continuously lit, the Router is successfully connected to a device through that port. A flashing LED indicates network activity over that port.
Internet (Green) The Internet LED lights up when there is a connection made through the
Internet port. A flashing LED indicates network activity over the Internet port.
Good luck
Nov 26, 2010 | Computers & Internet
Flashing LED on Samsung SBC-N1 Charger
LED flashing is unable to charge
Sep 05, 2009 | Samsung Cameras
Second Led on HDD is flashing Red
you can run "chkdsk /r" coomand to recover your harddisk.
Also if you can delete partition and then create new partition thehn format it so all errors are fixed .
Jul 16, 2009 | HP Compaq ProLiant DL380 G3 Server
Blinking panel button lights
That has to do with your computer for your body controls, such a/c, heater, wipers, etc...
Most common problem is drinks spilling into the computer which is right between the cup holder. It will eventually cause a problem with a/c most likely.
Jun 24, 2009 | 1998 Dodge Caravan
Dont know what red light is flashing for because ive lost the ins
hello the red ligth is flashing, because to much coffee or u need to clean the machine cleane with sal and liqued soap thanks
Feb 24, 2009 | DeLonghi EAM3200 Espresso & Coffee Maker
Gaggia Syncrony Compact
If you are in decalcify circle you have to finish it before the machine goes to ready again.
When you decalcify the machine, there will comes water for a short period, then it hold up for a couple of minutes then it will run out little more water. So will the machine do to the water tank is emty.
May 18, 2008 | Gaggia Syncrony Espresso Machine
Televison & Video Logo
16 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
