The power is on treadmill but belt will not turn. The power to treadmill signals 0.5 will not go any higher
REM-10600T
5 Suggested Answers
6ya staff
SOURCE:
Anonymous
SOURCE: V-fit treadmill belt wont turn
call the threadmill cops. they will come and beat up that error
Posted on Nov 05, 2009
AJIN G
Electro Med Services
  • 6694 Answers
SOURCE: i started my reebok ice
First of all check the Fuse in the Motor control board. If it faulty then replace the same. If the fuse again blews the the you have to check the motor and its driver board. Using a car abttery you can check the motor. Connect the red wire from the motor to possitive terminal of the battrey and the black wire to the negative terminal. If the motor is ok the it will run without any trouble. If not then you have to replace the motor. If the motor is working perfectly then you have to check the motor control baord. It is available as modules. If you want to repair the motor control board then, You have to check the Driver circuit board for the motor. There is motor control IGBT Insulated Gate Bipolar Transistor) in this board .If the IGBT is short then the treadmill will not run or will run at high speed. . You have to check the OHMS between the seocnd and third of lead of the IGBT. If it shows less than 100 Ohms then the IGBT is short and you have to replace the same. Also you have to check the connection to the control pannel. Is there is any loose conatct. Remove the connection in the motor control board which go to the control pannel and reconnect it. Also check the speed sensor. In most of the treadmill you can find the speed sensor near the motor pully. Remove the speed sensor and clean it and the refix it. Remember one thing remove the power of the treadmill and leave it for 30 minutes then only oppen the treadmill. Because there is high voltage storage capacitors in the motor control board which will hold charge for some time even after the power is disconnected. i have added the picture of IGBT for your refference
ajin_g_95.jpg ok
Posted on Sep 18, 2011
ercupa190
ernesto cuadra
  • 12223 Answers
SOURCE: loss of speed signal
Dear Sir:
Use the calibration software for easy diagnose and troubleshooting.
Most of them is coming from under the Hood of the motor for instruction follow the steps, or use your user manual.
Adjust the speed sensor see the diagrama, and tight the wires from the sensor.
2_17_2012_12_19_32_am.gifsincerely. God bless you.
ernesto cuadra
managua, nicaragua. c.a.
Posted on Feb 17, 2012
ercupa190
ernesto cuadra
  • 12223 Answers
SOURCE: more imfo for my question,my reebok rem 10600t
you have another element in Short circuit.
Can be any other component, like capacitor, diode, transistor. etc go to
www.treadmilldoctor.com
and get the new one.
God bless you
Posted on Sep 18, 2013
I have a A2105. When I turn on the power it starts by it shelf runs on 1 and when I run on a higher speed after a while it goes back to 1
this is a problem with Console Control with CPU, you must replace.
However you must sure if the signal coming out from the control motor to the upper board are o.k Otherwise time to replace the control board since, they send the signa from the inverter to CPU.
Feb 11, 2015 | Nordic Track Nordictrack A2105 Treadmill...
Tip
How to reset/recalibrate your treadmill after replacing drive or incline motor,...
Make sure you recalibrate your treadmill after installing ANY controller, motor or console. You can NOT over calibrate your treadmill. You want to make sure you adjust your pedometer for the correct operating speed and incline adjustment. First plug in your treadmill, do not stand on the walking belt. Hold down the "Stop" and "Speed +" key and insert the safety key or magnet, let go of the two keys. Now press "Stop" key once. This puts you into the level 2 of calibration. Press the "Speed +" key slowly until you see 85 on the console, (at this point the display is going to show the percentage of motor usage and also the actual walking belt speed) at 85% motor usage your top speed should be between 10 and 10.5 MPH or (of 12 and 12.5) depending on the treadmill. You must know your treadmills top speed. (Important the motor may be damaged if you set the maximum speed higher than the maximum speed that your treadmill is made for). If the speed is higher than 10.5 or 12.5 then you need to turn the potentiometer down to the correct level. The adjustment is made with a phillips screwdriver, and the adjustment point is on the motor controller. It is a little square metal box with a yellow plastic adjustment screw inside. If the speed it to low you need to turn the potentiometer higher. Once the speed is correct you are done calibrating the speed. Press the (-) speed key to lower the percentage to (0). Next press the incline (+) button, this will make the incline motor go all the way to the maximum incline and come all the way down to the level position. Then remove the safety key and the treadmill will reset into the normal manual mode. Double check that the treadmill is operating at the correct speed and incline motor works correctly, by running maximum settings. Once you are done, be sure your treadmill is properly protected from surges from power spikes that can destroy the work you just performed.
Hope this helped.
on Dec 08, 2011 | Nordic Track Exercise & Fitness
I have the 1750 Commercial Treadmill and the screen is "froze" on the program for the sd card or WiFi. When I push on the stop button or unplug and replug in the power it still is STUCK on that screen. ...
use this steps and fix it. God bless you
Step 1
Plug the power cord into a UL 1449 single-outlet surge suppressor and then plug the surge suppressor into an electrical outlet that is not GFCI-equipped if the power does not turn on. If the treadmill is plugged in and the power still does not work, make sure the key is in the console and that the Reset/Off circuit breaker has not been tripped. Press the switch to "Reset" if it has been tripped.
Sponsored Links
Gym Equipment Choose from 1M+ Verified Suppliers. Contact Directly & Get Live Quotes! www.alibaba.com/Gym-Equipment
Step 2
Check the Reset/Off circuit breaker if the power switches off while in use. Wait five minutes and switch the button to reset. Check that the power cord is still plugged in securely; pull the plug out and plug it back in after five minutes. Pull out the console key and reinsert to see if the machine will turn back on.
Step 3
Place the chest pulse sensor tightly right underneath your pectoral muscles or breasts for it to operate properly. Position it lower or higher on your chest if it does not work properly. Wet the electrodes with a saline solution. Walk near the walking belt's center within an arm's reach of the console.
Step 4
Remove the console key and unplug the treadmill to loosen the walking belt if it slows when in use. Turn the rear roller bolts counterclockwise with the hex key 1/4 of a turn until you can lift the walking belt's edges 3 to 4 inches from the platform.
Step 5
Remove the key and unplug the treadmill to adjust the walking belt if it is off-center or slips when in use. Loosen the rear roller bolts with the hex key and reposition the walking belt. Tighten the roller bolts. Walk on the treadmill to determine if the walking belt is centered. If not, loosen the roller bolts again and make adjustments until the walking belt is centered.
Step 6
Recalibrate the incline system if the treadmill's incline does not adjust correctly. Press the "Incline" button and remove the console key. Wait a few seconds and replace the console key. The incline will automatically recalibrate by moving to the maximum incline level and then the minimum level.
Step 7
Press the "Stop" button for a few seconds to turn off the demo mode if the console display stays lit after you remove the console key.
Read more: http://www.livestrong.com/article/241157-nordic-track-treadmill-troubleshooting/#ixzz2geWlKdPR
Oct 02, 2013 | Nordic Track NordicTrack COMMERCIAL 1750...
Incline reads 0.0 but is not all the way down
Renee, Here is how to recalibrate the incline motor. Read all of it It will be good to keep.
Plug in your treadmill, do not stand on the walking belt. Hold down the "Stop" and "Speed +" key and insert the safety key or magnet, let go of the two keys. Now press "Stop" key once. This puts you into the level 2 of calibration. Press the "Speed +" key slowly until you see 85 on the console, (at this point the display is going to show the percentage of motor usage and also the actual walking belt speed) at 85% motor usage your top speed should be between 10 and 10.5 MPH or (of 12 and 12.5) depending on the treadmill. You must know your treadmills top speed. (Important the motor may be damaged if you set the maximum speed higher than the maximum speed that your treadmill is made for). If the speed is higher than 10.5 or 12.5 then you need to turn the potentiometer down to the correct level. If the speed it to low you need to turn the potentiometer higher. Once the speed is correct you are done calibrating the speed. Press the (-) speed key to lower the percentage to (0). Next press the incline (+) button, this will make the incline motor go all the way to the maximum incline and come all the way down to the level position. Then remove the safety key and the treadmill will reset into the normal manual mode, when you re-insert the safety key. Matt
If you need further help, I’m available over the phone at https://www.6ya.com/expert/matt_8dbc24bf722649ac
Dec 04, 2011 | Nordic Track NordicTrack Treadmill, A2550
Belt slipping and moving
Here is a basic procedure that will work for the majority of treadmills out in the market:
If the walking belt has shifted to the left, first remove the key and UNPLUG THE POWER CORD. Using the allen wrench, turn the left rear roller adjustment bolt clockwise, and the right bolt counterclockwise, 1/4 of a turn each. Be careful not to overtighten the walking belt. Plug in the power cord, insert the key and run the treadmill for a few minutes. Repeat until the walking belt is centred. b. If the walking belt has shifted to the right, first remove the key and UNPLUG THE POWER CORD. Using the allen wrench, turn the left rear roller adjustment bolt counterclockwise, and the right bolt clockwise, 1/4 of a turn each. Be careful not to overtighten the walking belt. Plug in the power cord, insert the key and run the treadmill
Jul 15, 2010 | Treadmill Doctor Weslo Cadence Dx10...
I have a Proform 380 Treadmill. When the treadmill is on the belt rubs on the left side.How do I center the belt?
If the walking belt is off-center, first remove the key and UNPLUG THE POWER CORD. If the walking belt has shifted to the left, use the allen wrench to turn the left rear roller bolt clockwise 1/2 of a turn; if the walking belt has shifted to the right, turn the bolt counterclockwise 1/2 of a turn. Be careful not to overtighten the walking belt. Plug in the power cord, insert the key and run the treadmill for a few minutes. Repeat until the walking belt is centered.
May 24, 2010 | Proform 380 CS Treadmill !
Reebok REM RE 103011 Ice Treadmill hand book needed
Most probably you will get the rem-re-103011 manual here
Oct 19, 2009 | Reebok Exercise & Fitness
Televison & Video Logo
16 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
