Question about iLO Televison & Video
I am trying to hook up a Roku to my ilo tv but it is saying no singal I don't understand why
Posted by Tiffany on
3 Related Answers
Anonymous
  • 3 Answers
SOURCE: my Ilo tv
You cannot program a Direct TV remote for an Ilo.
Posted on Jan 24, 2008
Anonymous
  • 126 Answers
SOURCE: I'm trying to hook my hp laptop to my hd ilo tv
you have to tell your laptop to do either a dual screen or use the external screen (TV) instead of the built in one. If your using a Windows based computerit will be located in the control panel to change this setting
Posted on Dec 03, 2010
SOURCE: WELL???? PDP4210EA hooking up to it?
I was able to find a service manual online which lists the inputs for that TV as the following:
  • RF connector (cable/antenna)
  • Composite (yellow video, red/white audio)
  • S-Video
  • Component (red/green/blue video, red/white audio)
  • D-Sub (analog PC connector)
  • DVI (digital PC connector)
Your Playstation would need to be plugged into either the component or composite connectors depending on which Playstation you have. The Playstation 1, Playstation 2, and Playstation 3 all can use the same composite cable, and the Playstation 2 and Playstation 3 can both use the same component cable. The Playstation 4 only uses HDMI, which your TV doesn't support, so you would need to use an HDMI to component converter (under $20 on Amazon).
As for the Roku, same rules apply, but it again depends on your Roku model.
Posted on Oct 24, 2017
Installing an inside antenna
You can leave the input from the Roku hooked up, hook the antenna to the round connector that says antenna or cable on the tv then select cable or antenna as the input on the TV and select auto scan and let it scan for live chanels and store them...you can switch back and forth between the HDMI input for the Roku and the cable/antenna using the input button on the TV, you won't need to unhook or re hook anything to go from one source to the other.
Mar 16, 2018 | Roku Televison & Video
  • S-Video
Oct 24, 2017 | iLO Televison & Video
I AM TRYING TO HOOK UP A ROKU TO AN OLDER TV USINGMODULATOR. i GET BLACK LINES. nO PICTURE? WHAT AM i DOING WRONG
Forgive me I am out of touch with modern techno stuff but I think this is some media streaming gizmo if so then your TV would need possibly HDMI or at least a 15 pin svga port found on flatscreens. Most older TV's would have an aerial socket, scart and phonos of one sort or another (with the odd BNC and DIN type thrown in).
Now if this is so, I doubt you will manage it at all your ROKU is chucking images out at a rate that is far beyond any old system to work with. A modulator say those £30 thingys that have a scart or phonos can only cope with basic video or rgb.
Your ROKU would have to "slum" it down to RGB or COMPONENT level before you could get that converted down to say a modulator with basic video by then its quality would be very gone. To understand deeper look for the word Scaler in up and down this is a device to alter images from one format to another found in say TV systems, though for you I would get a more modern flatscreen that has suitable sockets to match your ROKU plenty of say older models with less features than their newer cousins and have still older style connectors for older secondary equipment (video) to work with.
I am working a bit by guesswork over what you have there to work with, some convertions are easier less complex than others.
Hope this helps a little.......
Feb 15, 2015 | RCA Televison & Video
How to hook up
You do not need a smart tv in order to use the roku. Basically the roku device makes your TV Smart. The basic connection is just an hdmi cable, and some type of internet connection. Depending on the Roku you have, you can either go with the built in wireless, or you can hard wire the internet. The same type of cable that you would use to hook up a computer to your router.
Aug 02, 2014 | Roku Televison & Video
Dvd player and analog tv
You're not trying to use the "Tuner" in the ILO are you? Bypass it and use the A/V cables from the "out" of the converter box. I think mine also has the coax type cable from the "to tv" to the ILO, then from the "to tv" on the ILO to the television. Either way should work. Mine works great, its a zenith and I have successfully recorded to discs in my ILO. Just change the Source back to the DVD source to watch a dvd or select the corresponding A/V connections that are hooked to your convertor box to watch/record television.
Aug 12, 2008 | iLO DVD Recorder DVDR05
No picture
I have my television outputs connected to the inputs on the ILO. I then select that set of inputs with the SOURCE button rather then using the built in tuner. Make sure you connect the Video closest to the audio inputs(or... least confusing, try the three front inputs) Hook antenna to tv
Jun 28, 2008 | iLO DVDR05 DVD Recorder
Ilo 32 in television
I need to hook up remote for Direct TV and Ilo is not listed as a choice what do I use?
May 26, 2008 | iLO 3200 32 in. LCD Television
My Ilo tv
Jan 22, 2008 | iLO 3200 32 in. LCD Television
Televison & Video Logo
Top iLO Televison & Video Experts
Lee Hodgson
Lee Hodgson
CoppellTVRepair.com
matt martin
matt martin
Are you an iLO Televison and Video Expert? Answer questions, earn points and help others
