Question about Panasonic Washing Machines
Panasonic washer, drum is still full of water after wash. It shows U on the panel after the wash
    Top Expert:
  • Panasonic Master
  • 64,733 Answers
You either have a bad pump or power control which isn't telling the pump to work
Posted on Nov 08, 2019
  • 2 more comments
  • Jonathan Simpson Nov 08, 2019
    Is it time for a new washer or is it an easy fix
  • ray gallant
    ray gallant Nov 08, 2019
    not easy nor cheap
    Many thanks for your swift answer
  • ray gallant
    tis what i do nightly
6ya staff
SOURCE:
Anonymous
SOURCE: washer stops during wash cycle
you may a pluse cycle where the washer will stop for a couple of min, this cycle is for perm press to minimize wrinkels
Posted on Nov 22, 2007
IFIXALL
Archie Ferrarini
  • 869 Answers
SOURCE: washer instructions need manual
You have a clogged pump.Find access to inside the machine,locate the pump and clean it out.
Posted on May 24, 2008
barkencoa
Barry Coates
  • 3463 Answers
SOURCE: washing not being spun properly or machine emptying fully
If it has a filter, remove and clean, check for blockage and or obstuction in drain hose
Posted on Dec 12, 2008
Anonymous
  • 5 Answers
SOURCE: the pump on my hoover washer hnf7148 has been
This particular model has a problem with the circuit board(control board,PCB) it does everything but drain, its very easy to replace and costs around £52
Posted on Oct 06, 2009
shawnryan111
  • 121 Answers
SOURCE: Maytag Washer LA7300 Water leak bottom of drum
This page will help http://www.appliance-repair-it.com/Maytag-tub-seal.html
Posted on Sep 03, 2010
Wot does code F-05 mean on a hotpoint ultima washer mean?
It means water level switch jammed on full.
You need to check and clean pump filter.
Remove lower rear panel of washer.
Locate and remove large black hose fastened to bottom of drum.
Remove and clean plastic filter inside the hose
Reassemble and water test..
Feb 15, 2011 | Hotpoint Ultima WF860 Front Load Washer
Error f0-05 showing during cycle
Error code F05 means water level switch is stuck on full.
Remove large black hose on bottom of drum.
Remove and clean plastic filter inside hose.
Refit and test.
Mar 31, 2010 | Hotpoint Aquarius WMA42 Front Load Washer
Water didn't shut off
There is a part called a air-dome that is connected to the lower section of your outer drum. The part where you put your clothes in is called the inner drum.The air-dome has a small tube connected to it which travels up the drum to a level sensor in the control panel that turns off the water when the washer is full to the point water level is set.This is usually on top loaders.
Feb 06, 2010 | Kenmore 23822 Top Load Washer
F05
F05 means pressure switch jammed on full.
Remove and clean filter inside hose.
Refit and test.
Please rate my solution.
Thankyou.
Feb 03, 2010 | Indesit W 123 Front Load Washer
Hotpoint ultima washing machine showing fault code f-05 and door will not open.
Error code F05 indicates pressure switch jammed on full.
Remove hose onto pump, and check for blockage or obstruction here as well.
Make sure there is no water in drum before you start.
Thankyou.
Jan 26, 2010 | Hotpoint Ultima WF860 Front Load Washer
Hotpoint aquarius wma58 1400. Full of washinh. Full of water.
pull your washer out. put near door if poss then put the waste pipe down to floor level to empty the water. if there is to much water in the drum it will not spin try your pump
Jun 21, 2009 | Washing Machines
Washing not being spun properly or machine emptying fully
Dec 12, 2008 | Tricity Bendix AW1400W Front Load Washer
My Hotpoint Aquarius WF210 washing machine drum is not rotating
I think the belt has come off or has been damaged.
To open the machine slide out the machine. On the back panel lower 1/3 you will see a plastic panel remove the screws and the panel will come away. Inside you will see the belt. I suspect you will need to reattach the belt of remove it and buy a replacement.
Sin é
Jan 13, 2008 | Hotpoint Aquarius WF210 Front Load Washer
Washing Machines Logo
29 people viewed this question
Top Panasonic Washing Machines Experts
Eric Taylor
Marvin
Marvin
Are you a Panasonic Washing Machine Expert? Answer questions, earn points and help others
