Question about Fisher and Paykel Washing Machines
Fisher and Paykel GW712 stop when it gets to the rinse cycle and after this draining water from the full to the quarter. Can you tell me please what do I need to do?
I checked the error code (from Google) and I think it is 5? From left to right there are two lights on 6th and 8th The pump and the drainage area were clean.
6ya staff
SOURCE:
aborcass
Ron Coons
  • 2651 Answers
SOURCE: Fisher and Paykel Smart Dribe 608
not familliar with that exact model number ( we dont have that over here in the US) we have simalair f&p gwl10- gwl11) that problem sounds as if either the pump is bad and overheating before pumping all the water or a diverter valve is not fully closing allowing water to remain in tub.
Posted on Mar 29, 2008
Krazytech
Franklin Ouchida
  • 725 Answers
SOURCE: my fisher and paykel smartdrive
with no error code ... I would check you drain pump or drain hose... you first may want to try a shop vac connected to the end of a drain hose .. let me know if it helps
Posted on Dec 15, 2008
appldoctom
Thomas Malailua
  • 311 Answers
SOURCE: fisher paykel will not complete rinse spin cycle
will sence it will spin once the water is out .that must mean your pump is restricted.unplug go to buttom of washer find pump and clean out
Posted on Dec 31, 2008
BIKER T
Terence Fourie
  • 909 Answers
SOURCE: Fisher & Paykel washer GW712 won't spin
There is an issue with your drainage area. Best to remove the pump and check for the obstruction in the line or at the impellar.(If the water is not completely drained, the pressure switch wont send a low level to the timer to allow a spin).
Posted on Sep 14, 2009
Anonymous
SOURCE: I have a fisher paykel ecosmart wash cycle but when
Tip the Washer and check the hoses.... my husband just found 2 pennies stuck in one of the hoses in my F&P GWL15
Posted on Oct 04, 2009
I have a Fisher & Paykel GW712 (approx 2003), will work up until the first orange rinse light. It does a small drain but then the 3rd, 6th & 8th lights come on (left to right) & it beeps continuously.
thats an error code for the drain pump, if it drains a bit of water then stops the drain pump is faulty (usually overheating coils from corrosion especially if you get a hot metal smell when it happens) dont keep doing it as it has tendency to blow the control board, you will need to replace the drain pump
Feb 04, 2017 | Fisher Washing Machines
My fisher & paykel washer will not move to rinse cycle
Fisher & Paykel GW712 AU 93200-A STOPS @ THE RINSE CYCLE & THE SPIN CYCLE?
Oct 12, 2011 | Fisher and Paykel IWL12 Top Load Washer
MY FISHER AND PAYEL GW 712 WASHING MEACHAINE IS NOT SPINNING AT ALL
I have a Fisher & Paykel GW712 and had same problem and fixed it today the drain pump motor had failed although it worked for 1 full cycle. when I tried to wash a second load the water would not completly clear from the machine I finally replaced the pump and now works correctly the pump is easy to install ensure machine is disconnected from power first
Mar 27, 2011 | Fisher and Paykel (IWL12)
Water not pumping out F&P GW712
If you can hear your pump running then your drain hose might be clogged, if not it is probably the pump and will need more in depth troubleshooting.
Oct 25, 2009 | Fisher Washing Machines
Sep 14, 2009 | Fisher Washing Machines
Stops before rinse cycle... won't drain or spin.
The REGULAR CYCLE button turns the drain pump on or off. The REGULAR LED will turn
on when the pump is on. This feature can be used to drain the tub. You could get a bucket and lay the hose on the fllor. Gravity will drain it down.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Sep 07, 2009 | Fisher and Paykel GWL11 Top Load Washer
My fisher and paykel smartdrive 708 stops at rinse/spin cycle with machine still full of water
Dec 15, 2008 | Fisher and Paykel Fisher Paykel Intuitive...
Washing Machines Logo
32 people viewed this question
Top Fisher and Paykel Washing Machines Experts
Archie Ferrarini
Archie Ferrarini
Gerry Harvey
Gerry Harvey
jimorris77
Are you a Fisher and Paykel Washing Machine Expert? Answer questions, earn points and help others
