Question about Candy Washing Machines
CANDY ALISE GVW585TWC-S washer/ dryer shows ERROR code E05 - in spin mode drum is rotating left/right but it does not go into spin cylce, short of time period end indicates E05
Data: pump is pumping drum empty, drain pipe & pump filter is clean, water level switch is switching and level pipe to switch is clean - Any data what could be faulty?
6ya staff
SOURCE:
Anonymous
  • 52 Answers
SOURCE: Washer won't spin and drain
Sounds like your drain poump is failing. It's spinning lighter loads but not able to take a full load. I woule definately replace the drain pump,
Posted on Feb 28, 2009
Anonymous
SOURCE: whirlpool duet sport wfw8300sw00 f-21 error
Unplug the machine. Unscrew the 3 screws under the front edge of the washer. The service technician manual is attached to the panel that slides down and off. Find F21 code. See suggested procedures. Note: My drain pump filter had a baby wash cloth in it along with some change that was disrupting the flow. It is exceptionally easy to remove, clean, and reinstall. Just line up installation notches when reinstalling. Whirlpool should have mentioned this filter in the User & Care Guide, but I could not find it anywhere in there.
Posted on Mar 20, 2009
barkencoa
Barry Coates
  • 3463 Answers
SOURCE: washer drum doesn't spin, no draining of liquid
If you have got rid of all the water, and it still will not spin, then the odds are it is the brushes in the motor that need replacing.
Quite a common problem
Posted on Jan 19, 2010
Testimonial: "I will tell repairman from Sears ( coming Friday ). i'll ask him to check brushes before he pulls motor. "
Anonymous
  • 56 Answers
SOURCE: GE WBVH6240 Front load washer. Pump running while empty
you would need to go into the fault codes and read them. the tech sheet should be under the lid or in the kick panel
Posted on Feb 07, 2010
ladiestch
ladiestch
  • 19 Answers
SOURCE: drain pump keeps running
Probable motor control board problem.
don't buy a GE anything!
Posted on May 03, 2010
Hi, My Candy washer/dryer has stopped working. I get a light on either 1000 or 1400 spin, and a light on 15 minutes and nothing else. There is no water entering the machine.
you may have to take the top off in order to see if the water inlet valve is operating as that's where the water fills from
eric
Dec 29, 2017 | Candy Washing Machines
Candy Alise 1000es
Hello, Here is the location for the manual that you need. Candy Alise 1000 ES User Instructions
Aug 25, 2014 | Washing Machines
LG washer IF82 code. What does it mean? This is a washer not a dryer.
LE error is hall sensor is bad or bearing not letting motor turn
Aug 05, 2014 | LG WFT1071TP Top Load Washer
My washer/dryer isn't drying clothes
this is all i could find on the internet and that is the manual not sure if its going to be of any help to you but you could go to this link and download the manual and see if it does help you out.
i think its the first one on the page.
candy alise go4w464 washer dryer not drying clothes Google Search
Oct 31, 2017 | Candy Washing Machines
Hi i have candy go washing machine it shows error cond e05 What to do?
E05 indicates that the pressure switch is stuck on full, this may be that your pump is jammed or blocked. Remove the filter and clean it out, also try to fish around in the tube that leads up to the drum. If this doe snot remedy the fault have it repaired by an engineer or someone whom has a rudimentary understanding of the mechanics of a washing machine.
Jan 08, 2011 | Candy GOY105 Front Load Washer
Candy CNW156 washer/dryer: spins empty, won't spin under load
If the belt and the motor are OK, then tell your friend to check the motor coupler, the MCU (motor control unit).
See also the following link : It doesn't spin.
Dec 01, 2008 | Candy CNW156 Front Load Washer / Dryer
Candy alise 1000 formula stainless
Click on brand name (below FIXYA) on this website, type in your model No & search. You will get a shortlist; click on your model,below the page u will get Manual/Guides. Click on the blue, you have your manual on line.
Or click on "washing machines" above to find your brand.
Jan 01, 2008 | Washing Machines
Washing Machines Logo
27 people viewed this question
Top Candy Washing Machines Experts
peter gittos
peter gittos
Gerry Harvey
Gerry Harvey
Marvin
Marvin
Are you a Candy Washing Machine Expert? Answer questions, earn points and help others
