Why is my chromebook thick pad not charging - Computers & Internet
Posted by Terry Finley on
Larry Ng
  • Computers & ... Master
  • 5,931 Answers
The battery is bad.
the most common cause of portables failing is this, as is dropped or drowned.
Posted on Dec 10, 2019
How to enable the touch pad on an HP Chromebook 14 running Linux Mint 17 via John Lewis' BIOS?
Applications > system tools > preferences > system settings > mouse and touchpad > enable touchpad.
Please try and let know.
Sep 29, 2014 | HP Pavilion 14-c010us Chromebook 14-C010US...
2010 dodge caravan minimum rotor thickness
Auto Parts Stores have books for that spec
Sep 12, 2014 | 2010 Dodge Grand Caravan
Can you use a mouse with the chrome book?
Which specific Chromebook do you have? The Samsung Chromebook has USB ports on the back of the unit (below the hinge for the screen). The Acer C720 Chromebook has one USB port on each side. Most basic mice should work. (Some gaming mice and mice with unifying adapters might have issues.) Some report needing to disconnect and reconnect the mouse after turning on the Chromebook to get it to work. Other models can connect to a bluetooth mouse, like this: http://www.amazon.com/Logitech-Cordless-Optical-Bluetooth-Charcoal/dp/B000BDH2Y8 . Enable Bluetooth and then synch the mouse using the PIN provided in the documentation.
Please note: adding these external devices may reduce the length of time that you can use the Chromebook before recharging the battery.
I hope this helps.
May 12, 2014 | AOL Computers & Internet
My Acer C7 Chromebook will not charge. I noticed the problem around 10 this morning and let it charge thinking i forgot to charge it. When I checked it around 1, it still said 1%. Is there anything I
If you left it on the charger before this last time, you may have over charged the batteries. If not, get another charger for it to see if that is the problem.
Feb 02, 2014 | Acer C7 Chromebook
Acer chromebook c7 wont charge
You may need to replace the battery, especially if you have had your Chromebook for awhile.
Nov 07, 2013 | Acer C710-2487 4096MB 11.6" Chromebook
How to change rear brake pads in 2008 dodge caravan?
In this tutorial, we learn how to check the brake pads on a 2008 Dodge Caravan, check the thickness of the brake pads on the car to see if they are thick enough. The rear pad is surrounded by a gold piece called the "shoe" and the rotor. The front pad has to be inspected by laying on your back and looking for the pad to see how thick it is. If the thickness is not enough, you need to replace it as soon as possible. Make sure the brake pads are up to t
May 12, 2011 | 2008 Dodge Grand Caravan
Total vehicle maintenance of 2001 nissan frontier
power steering flush antifreese flush brake fluid flush check pads thickness replace belts oil change change transmission fluid check ac charge and check for fluid leaks check the timing replace timing belt check lights check the shocks struts check tire pressure and thickness
Sep 15, 2010 | 2001 Nissan Frontier Crew Cab
The trackpad does not work anymore. How can I fix it?
You would need to take the phone apart and replace the trackpad. You can find a trackpad on ebay for about $12-15. If you are interested you can contact us and send it in for us to fix it. If you buy the trackpad yourself we would just charge you for labor, otherwise we would charge you for the trackpad + labor.
www.usedcellphoneshop.com
May 18, 2010 | RIM BlackBerry Bold 9700 Smartphone
Computers & Internet Logo
20 people viewed this question
Ekse
Marvin
Marvin
