Question about Sloan Home
Too high of pressure on flushmate at initial flush.
Sloan flushmate sounds like small explosion. I suspect too much air pressure what do I do to fix it.
Posted by Jerry Wooddell on
5 Related Answers
sct
  • 22 Answers
SOURCE: flushmate 503 - loud squeaky scary noises
Have you tried the "800" number on the tank label or visited the Flushmate Web site?
Could be related to the plumbing or the Flushmate. Technical support should be able to help you pinpoint the cause and, if it's Flushmate-related and under warranty, provide a resolution.
Posted on Sep 24, 2009
sct
  • 22 Answers
SOURCE: My sloan flushmate toil I think is backiing up.
You may have a leak in the discharge extension, lower supply, or drain valve. I suggest you call Flushmate's tech support line (on the Flushmate label) and see if they can help you out.
Good luck
heatman101
D. Floyd Kolb
  • 43501 Answers
SOURCE: I have a Sloan Flushmate
The only adjustment you can make is to crank your water pressure up...
But that probably will not solve your problem...
The best thing to do is to call the 800 number on the top of the tank and get technical assistance from them directly... they also will send you free parts if you need parts...
heatman101
Posted on Sep 08, 2010
rickead1
Rick Ead
  • 1998 Answers
SOURCE: my sloan flushmate toilet makes
this has already been answered on another site click here http://www.landscapetutorials.com/tips/flushmate-noise.htm
the repair is done by
Fortunately this problem is very easy to cure. Simply follow the instructions below.
  • Remove the ceramic cover from the tank on the back of the toilet.
  • Fill a one-gallon jug with water.
  • Pour the water into the toilet tank. Just pour it over the top of the black plastic Flushmate container. It will run down the sides into the bottom of the ceramic tank. See photo below.
  • Now flush the toilet. The noise should be gone.
if you have any further questions please message me back and please remember to rank how this opinion has helped it allows me to help others in similar situations in the future Thanks again Rick
Posted on Apr 28, 2011
sct
  • 22 Answers
SOURCE: The Sloan Flushmate is spraying
Without more specific detail about the origin of the spray (lower supply, discharge extension, drain valve, etc) it's hard to say what the problem is or exactly how to fix it. I suggest you call Flushmate Tech Support at 800-533-3460 (M-F, 8 - 4:30 ET). For best results, call right from the toilet.
They'll need to know the serial number, model number, fixture manufacturer, etc. to get you taken care of.
Best of luck!
Posted on May 31, 2011
How do I lower the water level in the toilet bowl of a Slone Flushmate? It keeps getting higher, little by little after each flush.
The flush valve may be defective but some tinkering with the refill level setting may work.
Jun 24, 2017 | Home
Hissing sound after flushing a flushmate
The washer that shuts the water off is failing. It shut stop incoming water completely when the tank is full.
Jan 11, 2013 | Sloan M-101526-F Flushmate?® Complete...
Flushmate 503 sprays water out of top of tank, apparently coming for under the flushmate system. The valve doesn't seem to leak. Iahve pressure tested it.
Turn off the water supply at the wall, flush the toilet to relieve the pressure inside the Flushmate, and call Flushmate Consumer Services at 800-533-3460 M-F, 8:00 - 4:30 ET.
They'll need to know the serial number and approximate date of installation of the Flushmate.
You could alos fill out a confidential "contact" form on the contact page of the Web site, www.flushmate.com.
If yu need to use the toilet in the meantime, you can "bucket flush" it by pouring 2 to 3 gallons of water into the bowl. This will generate a standard siphonic flush and won't give you the pressureized extractiopn but it will keep the toilet usable until a Flushmate support tech can diagnose the issue and provide a resolution.
Aug 17, 2011 | Sloan M-101526-F31 Flushmate?® Complete...
I have a Sloan Flushmate mod M-101526-F3. It seems to be laking the pressure to flush away the waste completely. Is there an adjustment that I can make?
heatman101
Sep 08, 2010 | Sloan M-101526-F42 Flushmate?® Complete...
I have a sloan m-101526 it works fine most of the time after sitting a length of time its like it loses its prime and has little power. flush it a couple of times and it works fine.
Sounds like it's losing air pressure as it sets unused. If you haven't already, I suggest contacting Flushmate technical support at the toll-free number on the serial number label. They should be able to guide you in identifying the source of any air-loss and recommending a solution.
If it's under warranty and replacement parts are needed, they'll send them at no charge.
Hope this helps.
Jul 03, 2010 | Sloan M-101526-F42 Flushmate?® Complete...
Sloan Flushmate M-101526-F3-Constant Filling
There is a lifetime warranty on the tank and a ten year warranty on parts. Call flushmate and ask. they will not tell you otherwise.
If you use any chemicals in the tank it will void the warranty.
Sep 25, 2009 | Sloan M-101526-F42 Flushmate?® Complete...
Flushmate 503 - loud squeaky scary noises
Sep 21, 2009 | Sloan M-101526-F42 Flushmate?® Complete...
My model# is M-101526-F.I purchase unit 7/2000.When I try to flush,I don,t have the pressure that I normally get.I do see some water in the tank.I also need to shake the handle to stop the filling process...
Have you tried the "800" number on the Flushmate label? Loss of air pressure may mean there's a leak in the cartridge, air inducer valve, or possibly even the tank itself.
The handle-shaking thing typically means the handle and rod are binding up and holding the cartridge down after the flush or that you need to increase the clearance between the rod and cartridge cap.
Flushmate tech support should be able to help you identify the cause of the air loss and advise you on the cartridge cap adjustment.
You can also view some helpful videos at www.howto.flushmate.com.
Good luck.
Aug 12, 2009 | Sloan M-101526-F42 Flushmate?® Complete...
I have a Sloan Flushmate, Model #M-101526-F3. The
Absolutely not! Because these tanks have air pressure inside them, and you can hurt yourself or somebody else. You need to get new one... take a look here Amazon com Sloan Flushmate tank. I hope this was helpful. cheers
Jul 10, 2009 | Sloan M-101526-F42 Flushmate?® Complete...
My sloan flushmate toil I think is backiing up. When I take the lid off and flush the toilet water shoots out the front side of the flushmate. What could the problem be or is it broken.
Good luck
Apr 14, 2009 | Sloan M-101526-F42 Flushmate?® Complete...
Home Logo
132 people viewed this question
Top Sloan Home Experts
Bill Johnson
john h
Are you a Sloan Home Expert? Answer questions, earn points and help others
