Question about Parrot Blue B250xt Bluetooth Wireless Headset B250-xt
I recently purchased a blue parrot B250xts. I love these headsets but the new headset volume doesn't turn up loud enough to even hear the person on the line barely. Yes I've turned the volume up on headset and media volume all the way. It's very frustrating nc I've purchased 2 new headsets with the same issue. Any input would be greatly appreciated. Thanks.
6ya staff
SOURCE:
Peter Denton
Peter Denton
  • 16 Answers
SOURCE: New Phone Causing Echo
It sounds like your microphone volume is too loud. Get someone on a call with you so they can tell you how it sounds as you adjust it. Turn down the mic volume by pressing the + & - buttons on the earpiece together once which puts the earpiece into mic adjust mode. Then decrease the mic volume by pressing the minus button a few times until it sounds right. The earpiece will automatically revert to normal mode within a few seconds.
If this doesn't work it may be that you need to adjust the compatibility setting for the new phone. This is the small black dial on the base station. The most common setting is 'A' but you may need to experiment with other settings for that phone.
Posted on Nov 05, 2008
Anonymous
SOURCE: 3200 LS installed in '07 Chev Sub-Parrot Won't Power Off
try switching the red and orange wires. one is constant and one is switched. you can try by just reversing them at the inline fuses. hope this helps.
Posted on Jan 03, 2009
Dragazarth
  • 8 Answers
SOURCE: mic not working when headphone plugged in
Try changing the Windows Default Audio devices
  1. Go to control Panel
  2. Sounds and audio devices
  3. The Audio tab
  4. Then change the Sound Recording Device to Logitech Headphone INPUT
Hopefully this will work
Posted on Apr 07, 2009
Anonymous
SOURCE: blackberry curve works with headset but not when headset removed
I have this same exact problem!! here is what works for me to fix it.. i plug the hands-free headset half way into the phone and then tilt it down (to push the jack up toward the front of the phone). After that i am able to use the phone regular again (speakerphone and internal earpiece works again.) I find that i have to do this once a day. There seams to be a short or something on the whole jack piece.. sometimes i actually just use my finger to wiggle the outside of the 3.5mm jack on the phone and that fixes it to! but i also found that there is replacement pieces like this on EBAY..
http://cgi.ebay.com/FLEX-CABLE-EARPHONE-JACK-FOR-BLACKBERRY-CURVE-8900_W0QQitemZ350187872475QQcmdZViewItemQQptZPDA_Accessories?hash=item350187872475&_trksid=p3286.c0.m14&_trkparms=72%3A1205|66%3A2|65%3A12|39%3A1|240%3A1318|301%3A1|293%3A2|294%3A50
Posted on Apr 12, 2009
Anonymous
SOURCE: Parrot CK3000 Evolution
after a reset try to push the parrot in pairing with your phone.< for any G3 phone the below should work. The menu could be differnet on yours this is for a nokia G3 phone. Object Push: * From your phone go to MENU / COMMUNIC. / CONTACTS * Select the desired contact to send * Go to OPTIONS / SEND BUSINESS CARD / VIA BLUETOOTH / ALL CONTACT DATA * Phone will search for available bluetooth devices * Select from the list Parrot Product and press SELECT * wait until the contact is transferred. After contact is sent, it is neccessary to register "Contact's Name"
Posted on Jun 15, 2009
6I can't get the parrot to pair with my new iphone
turn on bluretooth then delete all pairings then turn on headphones and use phone to search for new devices
May 30, 2015 | Parrot Blue B250xt Bluetooth Wireless...
Can't hear when someone is talking to me on my Blue parrot B250xt
be sure you have your media volume turned up. You can also call VXI they offet excellent tech support
May 21, 2014 | VXI Corporation Blueparrott B250-XT...
My headset is dropping cals and shutting off.
when someone calls me I can hear them but they cannot hear me
May 20, 2013 | Parrot Blue B250xt Bluetooth Wireless...
Blue parrot b250xt when making a call cant hear it ring on parrot . When reciving a call you have to divert to hands free.
Seems like you have an issue that is very common. I had the same issue and phoned tech support (1 800 742 8588). The solution is to reset the headset. It is not printed in the manual 1 switch phone on and pair with headset. 2 when paired (blue light flashing) put the charger on the headset for exactly 10 seconds. 3 remove the charger. 4 the lights should be starting to alternating between red and blue. this means it is resetting. 5 as soon as the light quits to alternate, the headset is reset, and the problem should be solved.
This also fixes the Windows 6.1 audio problem.
Jun 20, 2010 | Parrot CAR PAICK3300 GPS Receiver
How to pair my blue parrot b250 with my phone lost my notes on how to pair
1. Turn headset off (panel 5).
2. Hold down the headset’s MFB until the red and blue lights
flash and you hear 2 rising tones, followed by 4 more tones.
Important: Wait for all tones and for both lights to flash. This
may take up to 15 sec. Release the MFB.
3. Follow the manufacturer’s instructions for putting your
cellular phone into Bluetooth discovery mode.
4. Wait 5-15 sec. while the devices discover each other.
When the phone discovers the headset, select “Pair” and
enter a passcode of 0000 when instructed. When pairing
is complete the headset’s blue light will stop flashing and
the phone will prompt you to ‘connect’ to the headset.
Enter “Yes” on the phone to connect to the headset. When
connected, the blue light will flash indicating that the
headset is in standby mode ready to receive a call.
USER GUIDE
Jan 03, 2010 | VXI Corporation Blueparrott B250-XT...
Wont audio to headset
The problem with the Blue Parrot headset not getting audio from the phone is a very frustrating one and it took several hours to diagnose the problem. (Especially the Samsung/ Windows side, in my case)
I have a Samsung I760 phone using Windows Mobile 6.1. After pairing, the headset is visible in the PHONE window, as it should. But upon dialling, the audio transfers from headset to phone.
While in a call, you can tap on the menu button and it should bring you to a menu that would allow you to transfer the audio from headset to phone and vice versa. But this action malfunctions in the Blue Parrot headset only. The Blue Eagle headset works fine.
MY SUGGESTIONS:
1) Chuck the hideously expensive blue parrot headset in the trashcan and buy yourself a blue eagle, available at truck stops everywhere
2) Pester the Blue parrot support staff for a replacement, or a solution at 1800 742 8588.
Make sure you understand the manual and especially point 13 dealing with the transfer of audio before you call them.
Other than this, the headset actually works fine.
Dec 15, 2009 | VXI Corporation Blueparrott B250-XT...
Loud Noise
IT will give the noise because of the following reasons
  • Due to signal distortion and also that you mieght be useing faulty bluethooth head set .
  • It also occur due to low bettry chargeing
Things to do !
  1. check your blue tooth head set with other Motorola cells
  2. replace your blue tooth head set
  3. clean the connector of the blue tooth cable
Please Rate !
Sep 05, 2009 | Motorola Mobility Motopure H12 Bluetooth...
Forgot how to sync my PLN-510 Headset with my phone, I recently purchased a new phone and need to sync my bluetooth with the new phone Pantech Slate C530. Please remind me
Hold the up volume and the talk button (the one on the side of the ear piece) down until the status light flashes red then blue.  This places the headsead into pairing mode.
Jan 05, 2009 | Plantronics 510 Voyager Headset - PLN-510...
Nov 04, 2008 | GN Netcom GN 9120 Professional Headset
Motorola H500 Wireless Headset Pairing Problem
If you turned it on and it was steady blue most likely you held the call button too long. The steady blue means it's ready to pair with a phone. Try repairing again and if you still don't hear anything, play with the volume buttons to the top and buttom of the headset the volume may be down. If that doesn't help I don't know what will.
Aug 20, 2007 | Motorola Mobility H500 Wireless Headset
Parrot Blue B250xt Bluetooth Wireless Headset B250-xt Logo
Top Parrot Radio Communications Experts
Ekse
yobo007
yobo007
Anthony Ward
Anthony Ward
Are you a Parrot Radio Communication Expert? Answer questions, earn points and help others
